Prius 2009 Air conditioning issues
Discussion in 'Gen 2 Prius Technical Discussion' started by Brian2024prius, Jun 20, 2024.
  1. Brian2024prius
    Brian2024prius New Member
    Quetta
    Greetings,
    My Prius 2009 gen 2 has been experiencing air conditioning issues for the past month.
    I have been a consistent reader of priuschat since, and I have visited two air conditioning repair shops and two electronic testing businesses. Additionally, I have replaced four compressors.
    The issue arose when I observed that the air conditioning would cool when travelling on open roads at a speed of 30-40 km/h, but not when driving at a lower speed or while the vehicle is idle. Consequently, I visited an air conditioning repair shop. After two days of working there and replacing two compressors, I withdrew from my spot due to my observation that the shop was also replacing compressors for all customers. The inverter coolant pump was not functioning, as indicated by the subsequent electronic testing shop and YouTube research. Subsequently, we replaced it, and it is now operational. Next, I visited another air conditioning repair establishment, where they also desired to replace the compressor. We pursued this course of action once more, but without any success.
    Additionally, we have verified that the condenser is not obstructed at some point in the month. Nevertheless, we observed that the pressure switch was not operating the two fans behind the radiator and condenser at full capacity when the AC was activated. Consequently, we installed a manual bypass switch to determine whether cooling would occur. The system did cool, but only for a day.
    Subsequently, it failed to cool, and it resumed chilling for two hours. Presently, it is not cooling.
    The "Aircon Gate status," "Aircon Consumption Power (KW)," "HVAC OBD Request," and "RES / ACC Switch" were all null when I read them using the Car scanner app, which I acquired. It is possible that the software is incorrect or the OBD2 is not compatible. I am capable of extracting a reading from other readings.
    Today, I activated the air conditioning unit; however, it failed to chill. I did, however, observe that the compressor was likely altering the sound, and as the sound fluctuated, a small amount of refrigerant was visible in the sight glass. Video link: "liVirePr1cQ" (add this in front of youtube shorts).
    On Saturday, I intend to return to the air conditioning repair establishment. Encourage them to read both the high and low pressure sides and assist them in obtaining the anticipated pressure readings. Additionally, I will ask them to inspect the AC amplifier and pressure switch, despite the fact that the compressor appears to be functioning in the aforementioned video.
    Please feel free to share any suggestions you may have, and I will also implement them on Saturday.
    Meg&Bear likes this.
  2. Tombukt2
    Tombukt2 Senior Member
    13,867
    2,520
    Durham NC
    So just on the low side if you put one of those stupid cans with the gauge on top of it you remove the gray cover on the fat hose marked l for low side and you click the can in place You've not even punctured a hole in the can yet You're just using the gauge what do you see cars not running what's the number on the gauge Is the gauge buried past its reading capability? It should be on a non-running air conditioning system of this type there is no high and low side with the vehicle and the system not running so you're high and low side ports should show the same pressure Very close to 100 lb 9088 somewhere in there It's off the scale of the low side gauge that came with the can correct? If so have someone else get in the car bring up the screen for the heat and cooling put it on LO fan on high blowing out the vents at your face and then have them hit the air conditioning AC and make it yellow The minute he hits the AC and makes it yellow you will hear the compressor start The gauge that's connected to the can that's connected to the car should now pull down to about 36 PSI very quickly. The hose that this gauge and can are connected to should now start getting cold In a few seconds you should notice some light changes on the gauge but nothing really significant it'll bounce around a little bit 36 to 40 maybe down to 32 You should also in your sight glass generally see no bubbles maybe every 10 seconds a bubble might float by the sight glass moving away Is this happening? The hose is getting cold noticeably so almost freezing everything seems to be working correctly now it's inside your car you're not getting any cold air but the fan is running maybe you need to check the electric device that moves the damper door from heat to cold or something along those lines. If only some of this happened you can get a real set of gauges and connect up to the high side where you should see something like 36 lb on the low side that side should start getting cold but then again when you have your full game set hooked up if you're high side is not pumping up 250 somewhere around there on a 90° day and it's extremely lower gauge reading than that 140 then your compressor may not be up to the task of creating the refrigeration cycle.
    Meg&Bear and ANDRAS RIMELY like this.
  3. Brian2024prius
    Quetta
    Thank you, Tombukt2.
    I will conduct these tests during my visit to the air conditioning repair business on Saturday. This will provide me with assistance and a second set of somewhat expert eyes. In the event that we are unable to locate anything on Saturday, I will acquire a set of AC pressure gauges to experiment with the following week.
    I have recently returned from a two-hour journey that necessitated three to four frequent stops. I attempted to activate the air conditioning system approximately eight to twelve times; however, it failed to generate cold air. Nevertheless, it was successful in an attempt and was able to provide cooling for a period of 15-20 minutes. The cooling system was not particularly effective during the late evening drive, as it was only ablel to reduce the ambient air temperature from 30°C to 16°C. I have installed a temperature sensor on the vent, and I also verified that the sight glass was free of bubbles (see the linked video: "7kIV_3QBt1A").
    The issue may be primarily related to a jammed damper entrance. We tested the damper door once in the previous month, transitioning from a hot (52°C) to a miserable (30°C) environment, and it functioned properly. It is possible that the damper door contains three compartments: cold (approximately 6°C), recirculation (ambient air temperature), and hot (approximately 52°C).
  4. Brian2024prius
    Quetta
    Here is an update.
    Additional information is provided below.
    I was able to visit the workshop on Saturday. Fault detection was unsuccessful.
    The symptoms that were observed on Saturday were as follows.
    • During the initial car ride in heavy traffic, the cooling system operated for 30 minutes.
    • Cooling was interrupted for 30 minutes; however, it resumed operation upon reaching highway velocities.
    Therefore, I returned to the workshop and installed two push fans in front of the condenser. The air conditioning is now functioning in heavy traffic, as I tested it yesterday and today.
    (image during mid-work)
    The following week, I will evaluate the performance of this configuration.
    Additionally, I have observed the sensor depicted in the image below, which is suspended near the condenser. Is there anyone who is aware of its precise nature and location?
  5. Tombukt2
    13,867
    2,520
    Durham NC
    That's the outdoor temperature sensor there's a little place for it to stick into the metal on the piece that goes from the upper core support to the lower core support generally right past and under your latch mechanism I think and cross the middle of the radiator down to the lower core support or crossmember and there you'll see a little rectangular square cutout and I believe that temp sensor goes there this is what tells you your temperature on the MFD when you're sitting inside the car and you'll know it's 105° outside Don't know if it has a whole lot to do with the air conditioning but I imagine it tells the air conditioning computer The temperature which it might need to know. I find this interesting that pusher fans or puller fans or anything fans are making everything happen usually I'm flying down the road reasonably quick enough to air flow is the least of my air conditioning issues of course unless the fans aren't running but I guess it speed with the air on they're running but even if they were switched off if you had a switch to do that as long as you're maintaining 40 miles an hour plus you should have ample cooling of the freon just by the movement of the car not when you stop at a stoplight but when you're going down the road say 35 37 up.
  6. pasadena_commut
    pasadena_commut Senior Member
    3,069
    956
    Southern California
    There seem to be different issues going on here. The initial failures were probably due to the inverter pump not working. As the inverter overheats it shuts things down, and one of those is the A/C. Now that the pump is working. ..
    Wait, stop. Is it an OEM pump? If not don't assume that the problem is fixed, the non OEM pumps have a very high failure rate. At least check that the coolant in the inverter reservoir is agitated now and the next time there is an A/C problem (I had a Dorman pump which would fail to start sporadically, it was like having a dead inverter on some drives and a working one on most others.)
    Back to the A/C. Is it losing refrigerant? You do not want to run it when it is low on refrigerant, that will destroy the compressor. If it is leaking and the shop cannot find the problem in the engine bay then it is likely a bad evaporator. That is built into the center of the dash and is both an expensive part and a PITA to replace. Many hours of work to do so. First priority though - be sure that there is refrigerant in the system if it is turned on. Also be aware that the Prius has special needs with respect to its A/C system, it cannot just be recharged with a can of freon from the auto parts store.
    If the fans are not coming on that is another problem. But as Tombuk2 said, if the car is moving 40 mph or so the fans shouldn't matter because plenty of air will be forced through the radiator just by the motion of the car.
  7. Brian2024prius
    Quetta
    Another lengthy story pertains to the inverter coolant water pump. We replaced the pump approximately five times in the previous month, attempting to resolve the issue through OEM, car pull-outs, and Chinese replacements. Additionally, we investigated the radiator for potential blockages, opened the inverter to identify an obstructed line, and examined the lines that led to the engine motor. However, none of these measures proved successful. Then, while experimenting with the original water pump, I applied 15 volts to it, causing it to begin to rotate. I then tested it in a water bucket, and the pressure and water flow were satisfactory. Upon reinstalling it in the vehicle, it was once again unresponsive. However, after numerous attempts, we were able to eliminate air from the system, which subsequently enabled it to begin pumping water. The reservoir is currently experiencing a significant quantity of water movement, and I am consistently monitoring approximately a dozen temperature readings associated with the inverter on a mobile application. All temperatures are currently within the acceptable range.
    The refrigerant is not being lost by the air conditioning unit. I am aware of this because the cooling capacity has not fluctuated over the course of 2-3 weeks; it either functions or it does not. Due to the implementation of the pusher fans, it has been operational for the past two days. However, the refrigerant may be either low or excessive. In order to resolve this issue, I am in search of a workshop that possesses the necessary equipment to extract refrigerant, purify it of any air, quantify the quantity recovered, vac the system and subsequently inject precisely 420 grammes into the system. I have yet to locate any workshops. In our city, there are two Toyota service centres; however, I am uncertain as to whether they possess the requisite equipment or if they will examine a 2009 model (it is possible that the service centres are exclusively dedicated to warranty services).
  8. Tombukt2
    13,867
    2,520
    Durham NC
    I have never had to go through any of that nonsense at all here in the US so maybe there are problems in other parts of the world usually the system is low on refrigerant and I top it off with the system running till the sight glass is almost clear at full tilt generally that is resolved every issue in the five that we've had here in the last several years all of them are still working today none of them have had to be drained new oil put in and refilled by any special equipment measuring grams or pounds I think these cars hold about 1.2 lb of refrigerant gas 134a something along those lines so that's about one can and a shot out of the second can if you will so there's always that I mean if you want to pay for those services and that's what you have to do because you can't do this or what have you then well by all means sometimes people make this stuff way too much technical than it really needs to be refrigeration and air conditioning in the Prius is very similar to a belt driven compressor off the crankshaft It's just now we have the luxury of pumping the freon gas for the refrigeration cycle with an electric motor pressures and all that still have to be almost identical to the belt driven crankshaft driven compressor so this really not much difference in the whole mess unless you have a leak in the evaporator or some other hard to get to location which is going to render you and a 3000 plus dollar repair might not be worth it and you've added pusher fans to push more air through the puller fans or did you remove the puller fans from the factory and add pusher fans and if so why I don't think your add-on I can't even think of the big name now of the company that everybody uses for the electric fans I have a few of them hanging here but the name's not on them anyway. I can't imagine adding another big fan in front of the condenser pushing through the two polar fans mounted behind the radiator it just seems like not a thing You're almost adding more blade blockage and whatnot but that's just me the Toyota fans have always been ample they're relatively inexpensive now if you remove the polar fans and you want to put spax that's the brand name. Then by all means have at it I think you can get high or CFM and more air flow and two spax with the special fittings that pull the fan right up to the radiator or core surface that might be the ticket but I've never needed that in the 100° heat in North Carolina so I can't imagine.
  9. ChapmanF
    19,038
    Hey, that part's actually true kinda—'cause the gen 1 Prius did have a belt-driven compressor off the crankshaft, but even gen 1 already had the subcooling condenser design, which is why the proper refrigerant charge had to be given as so many grams past the sight glass clearing up, and why it was already so easy to charge wrong if not evacuating and using a scale.
  10. Brian2024prius
    Quetta
    I have not altered the puller fan; rather, I have installed two pusher fans.
    During the peak afternoon sun, the outside temperature reaches 38°C (100.04°F), while the air conditioning only reaches a vent temperature of 12-15°C (53-59°F). In the evening or at night, the outside temperature drops to 28°C (82.4°F) and the vent temperature can reach 6-10°C (42.8-50°F). In my opinion, this is a minor decrease, as I observe vent temperatures of -6°C (21.2°F) in residential air conditioners. This, in conjunction with the necessity of installing pusher fans, prompts me to question whether the refrigerant level in the system is either low or excessive.
    Today, I contacted the Toyota service centre. They assured me that they possess the requisite equipment to fulfil all of my requests and scheduled an appointment for Thursday, which is two days away.
  11. Tombukt2
    13,867
    2,520
    Durham NC
    I guess I must be very lucky because I've had to empty a few and sometimes I have access to a vacuum pump sometimes not when I do all vacuum it down and when I don't sometimes I'm not even using 134a I'm using I've mentioned it here before but I can't remember what it's called now but it's nice cold refrigerant it works well and the 134A system a little bit less head pressure etc either way all of them work great I haven't had trouble with anything have it measured or been to a professional AC shop or any of that actually I don't think ever in my life oh well as long as everybody has cold air when they need it that's the main thing and hopefully you don't have to mess with your evaporator whichever car you have I'm sure they're all very aggravating won't like a Corolla which you can do in about an hour and 20 minutes
    ANDRAS RIMELY likes this.
  12. Tombukt2
    13,867
    2,520
    Durham NC
    If anything it would seem like you're a little low which would stall some of the refrigeration cycle I guess It wouldn't be a little low I guess it would be a bit low and you should note that in what you see in the sight glass foam bubbles etc so that tells you there is moisture in the system etc at this point a good vacuuming is probably in order and possibly a receiver dryer if that's a thing that can easily be done on the Prius I think you have to change the condenser or it would have to be squeezed in by somebody that knows how to work with the piping for most it'll just be a condenser replacement I think and then you would vacuum that new system down and shoot in whatever gas is your preference at the time and let it rip and then make sure you don't have any leaks inside the car tested extensively to make certain of this most of the a lot of these cars have this evaporator problem in a little bit of gas escaping equals very little cooling quite quickly like I say all four of mine which have had none of these heavy duty antics done to them at all all work fine in the North Carolina hundred to 110 plus degree temperatures in the summer I have no complaints It's not like a big general motors Cadillac or van or anything like that but it is quite adequate considering the fuel usage and what have you dress for the weather if this is your problem put on your suit when you get to your office maybe whatever
  13. Tombukt2
    13,867
    2,520
    Durham NC
    21.2° f coming out of the vents of an air conditioner no kidding that's pretty good even with sub cooling I think here in the US you know we're looking for I'm not even sure 39 to 45 generally speaking for a well-performing system I'll have to try this on my newest inverter type outdoor units they make some really cold air for sure I'm not exactly sure how cold but it's seemingly quite a bit colder than my 4 ton unit at the main house but I don't think it's going to be anything near 21.2°
  14. Brian2024prius
    Quetta
    I have some good tidings to share.
    On Thursday, I visited the Toyota service centre, where they extracted 220 grammes of refrigerant from the system. They observed that the system necessitates 450 grammes, as opposed to the 420 grammes I had previously stated, after inspecting the car's sticker. Therefore, we included 450 grammes in the pack.
    The assistant manager at the Toyota service centre was exceedingly cordial. He adhered to my instructions precisely.
    The cooling system is currently functioning exceptionally well, despite the elevated UV values and 40°C afternoon heat. Nevertheless, it is imperative that the vehicle not be permitted to become overheated while standing in the sun. In this regard, windscreen reflectors are a valuable tool.
    I am under the impression that the sole remaining action is to return to the service centre after a month and re-weigh the gas. If the weight is 450 grammes, everything is in order; however, if it is less, there is a leak.
    The service centre incurred a total cost of $25. Nevertheless, I reside in an economically developing region.
