Prius 20099 problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Priuslover09, Jan 9, 2020.
  1. bisco
    52,880
    do they make that in an ev?
  2. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Did u really?
  3. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    52,880
    it looked like him:unsure:
  5. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
  6. bisco
    52,880
    an electric jeep pickup
  7. bisco
    52,880
    nice! i'm going to look into it(y)
  8. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    The Jeep or Prius?
  9. bisco
    52,880
    jeep, already have a prius
  10. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Ok
  11. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Those DTCs are only slightly more inviting than the last batch. Looks like you have some Hybrid Battery issues, and possibly a Cat problem, and a bunch of other fake business. Let me post up a few workups to get you started, we can add more later as things progress.
    Here is the workup for DTC P1150 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Repair%20Manual/04pruisr/05/2054m/cip1150a.pdf
    Here is the workup for DTC P3030 : https://attachments.priuschat.com/attachment-files/2019/09/174200_DTC_P3030.pdf
    Here is the workup for DTC P0A80 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Repair%20Manual/04pruisr/05/20zmw/cip0a80.pdf
    Could post the workup for P0A94, but there are like 15 of them depending on the 'detail code'. Do you know which subcode (or INF), then we can narrow it down quite a bit.
    Before you get too excited (or disappointed) with the above prospects, you may want to find a proper scanner that can read the subcodes (aka INFs or detail codes) for the scanned DTCs. Many here will recommend a mini-vci cable and techstream.
    Raytheeagle likes this.
  12. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
  13. bisco
    52,880
  14. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    I took my car to Crownsville automotive they fixed all my problems. Still have the P0000 code. Took in earlier today fixed my car before closing. Replace battery. And replaced all other problems as well.
  15. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Sounds great.
    Just to clarify, the only fix needed was the 12v battery replacement?
  16. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Nah it was hybrid dc Converter cat converter the 3 tires low on air the water pump and airbags sensors and the muffler but I still have p0000 code that won’t erase
  17. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    they changed the oil as well
  18. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Wow. Curious what was the approximate total out the door?
    #38 SFO, Jan 16, 2020
  19. dolj
    dolj Senior Member
    8,652
    4,404
    Wellington, New Zealand
    Just FYI P0000 is not a valid code. With what are reading the codes?
  20. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Isn’t that fault code?
