Prius 2010 excessive oil consumption
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by amritdiane, Dec 15, 2015.
  1. amritdiane
    amritdiane Junior Member
    wisconsin dells, Wisconsin
    My Prius has been diagnosed as failing an oil consumption test and needing a new engine block and valves.
    It has 111,000 miles on it and has been perfectly maintained before I purchased it last October.
    It is also getting poor gas milage. Any suggestions?
  2. Mendel Leisk
    42,355
    What sorta oil consumption?
  3. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    you can buy a lot of oil for the cost of a new engine block /
    BION
    StarCaller
  4. stephane
    stephane Prius v owner
    120
    64
    Quebec Canada
    2013 Prius v wagon
    seem like a more and more common problem think that engine need a better oil than the toyota 0w20
  5. frodoz737
    frodoz737 Top Wrench
    4,808
    2,561
    33
    "Assuming" everything is as you say...that means 1 liter burned per 600 miles according to Toyota Corporate. For the block and valves to fail said test at that mileage you "almost" certainly had a catastrophic loss of oil quantity/pressure and/or an extreme over-heat event due to lack of fluid/s...which was "likely" caused by poor/no monitoring or mechanical failure. Unless you want to buy a new engine assembly or take a chance with a used one...I would get rid of it. Neither option is cheap when you include installation, so consider "your" big picture.
    #5 frodoz737, Dec 15, 2015
  6. JC91006
    16,936
    8,647
    If it's burning that much oil, you probably should get rid of it or get another engine (used)
  7. RRxing
    RRxing Senior Member
    2,564
    1,842
    NEPA
    How do you know it was perfectly maintained since you bought it used?
  8. bisco
    52,863
    welcome to priuschat! details, please!(y)there will have to be massive failures for toyota to do anything. at this point, we don't know if there is a defect, the oil is bad, or how the vehicle has been treated and maintained. you call 51 mpg poor?:confused:
    #8 bisco, Dec 16, 2015
  9. Former Member 68813
    3,524
    983
    US
    i'm thinking there will be an avalanche of similar posts coming soon as average 2010 model approaches or exceedes100,000 miles. We should have at least a sticky post with links to useful info. i can work on that if admin promises a sticky, otherwise, that would be a waste of time (because people don't search in this forum).
  10. RRxing
    2,564
    1,842
    NEPA
    I just changed my oil (DIY) at 91K miles. Didn't notice any loss of oil... Just saying - YMMV
  11. CR94
    CR94 Senior Member
    2,832
    1,243
    Northwestern S.C.
    Not necessarily. This kind of complaint is becoming alarmingly common, and I see no basis for your assumption that it is not caused by some serious design deficiency in the engine. More data is needed on exactly what the oil-guzzling Prii have in common in their history--- if anything besides design and mileage.
  12. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Wonder if this is why the previous owner got rid of it
  13. frodoz737
    4,808
    2,561
    33
    While I was very careful with my wording in "all" of post #5, "some serious design deficiency" could be defined as mechanical failure by most lay people and Mechanics. I would leave that Legal Definition to the good graces (sarcasm) of high dollar Corporate and Government Lawyers .
    The Prius engine/s are aluminum and thus less little tolerance to oil abuse/neglect and over-heat events. Example: Remember the Vega engine? The Astre was Pontiac's version of the Vega and had essentially the same motor, but with steel cylinder sleeves. The sleeved motors did not have the same mass oil consumption issues the non sleeved version, but were still less tolerant to abuse when they went ≥ 2 qts low.
    Time will tell, but my recommendation is what I would do.
    #13 frodoz737, Dec 17, 2015
  14. Former Member 68813
    3,524
    983
    US
    for the record, prius engine has iron cylinder sleeves/liners. i don't believe there is such a thing as steel cylinder sleeves.
    #14 Former Member 68813, Dec 17, 2015
  15. JStrenk
    JStrenk Active Member
    203
    101
    Ravenna
    What test did they do to come to this diagnoses?
    I'm getting near the end of my 120,000 mi warranty and if there is a test, I'd like to have it done before my warranty is over.
    New block and valves? Do they actually know what is causing the consumption or just replacing everything that can cause oil loss?
  16. bisco
    52,863
    we don't even know if there is consumption.(n)
  17. frodoz737
    4,808
    2,561
    33
    I pondered wording when I stated that, so whether the sleeves are straight up iron or another ferrous alloy, the point made is they are not tolerant to abuse or neglect. Case and point: When I had my "Holy Crap" moment at about 100,000 miles, my oil consumption went from not measurable to about 3/4 liter per 5,000 miles. Had I not been anal about religiously monitoring and maintaining my vehicle prior to that, I would likely be be dealing with the same situation many others have reported...as it relates.
    Holy Crap | PriusChat
  18. Former Member 68813
    3,524
    983
    US
    it's amazing how those "Holy Crap" moments cluster at about 100,000 miles.
    this is what i'm going to do near 100,000 miles (i'm slightly over 70,000 now):
    remove/replace spark plugs.
    do piston soak over at least a weekend.
    drain/replace coolant.
    clean the entire EGR system.
  19. CR94
    CR94 Senior Member
    2,832
    1,243
    Northwestern S.C.
    By "serious design deficiency," I meant any feature or combination of characteristics of the engineering design which causes, directly or indirectly, serious mechanical failure that could not reasonably be expected. For example, high oil consumption by an engine that has never been abused or neglected, especially if it begins abruptly.
    The Vega had the ferrous sleeves too, in its final year or two. GM advertised the durability tests prototypes of those sleeved engines supposedly had survived---with very careful attention to maintenance, no doubt.
  20. oldasdust
    oldasdust Member
    356
    47
    illinois
    My 2011 with just over 90,000 as i posted is using about 28 ounces , just under a quart at 1,200 miles so it is starting and i check every 2 weeks , prior it did not burn any so as more gen 3's get over 100,000 i think you will start to see oil burn , i'm not saying it will be accessive but as the miles climb it will progress . My 2002 Civic i used synthetic Mobil 1 and let her go at just over 150,000 and it did not burn oil i changed oil and filter every 5,000 .
