Prius 2010 just bricked
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Sean Keeley, Nov 3, 2021.
  1. Sean Keeley
    Sean Keeley New Member
    Ky
    I
    So I have a 2010 Prius, new12v battery.
    I stopped the car and got out. Locked the doors. Came back about two minutes later, unlocked the doors with the fob, got in, and I have no power whatsoever. It's not like the battery died. It is like it got hit with an empty and nothing electric has any response at all. Locks don't respond, the security light doesn't flash, doesn't show that it knows the key is there, it's just a complete brick. What could cause it to go to full stop like that in literally a matter of seconds?
  2. JC91006
    16,827
    8,600
    If you have a 12v battery and getting no response from the car, chances are you have something loose on the battery connections
  3. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Or a dead new battery
  4. rjparker
    rjparker Tu Humilde Sirviente
    10,467
    6,564
    Texas Hill Country
    Or the inverter failed. Happened exactly that way with me. If it is the inverter Toyota may fix it free.
  5. Hi_prius3
    Hi_prius3 Junior Member
    46
    Honolulu,HI
    Any updates? Did you get your car started again?
    I’d like to know how things worked out.
