Prius 2010 - Long term parking
Discussion in 'Gen 3 Prius Main Forum' started by sp00ky, Sep 29, 2012.
  1. sp00ky
    sp00ky Junior Member
    23
    Sweden
    Hello,
    My wife and I will be going on a one month trip and will have to park
    our 2010 Prius for that whole time. Has anyone had to park theirs for
    a long time? Are there any precautions or preparations? Should I get
    someone to drive it occassionally? Any other ideas?
    Thanks,
    P.S. My Prius is equiped with SKS and VSS1.
    Car will be parked in winter peridod (15/12 - 11/01), that means low temperatures here in Sweden :)
  2. Metalman
    Metalman Member
    107
    17
    Summer, KY; Winter FL
    I don't know what the SKS or VSS1 are, but we left our 2010 Prius for five months (electronic key fobs out of range of the car). All that was done was an oil change and the 12 volt battery was left on a battery maintainer. The first time the engine was started, it stumbled a bit for a few seconds. The drive battery didn't even drop one line on the gauge over five months.
    As far as the low temps. are concerned, if the batteries are fully charged, they won't freeze and the low temperature will reduce the discharge rate.
  3. sp00ky
    23
    Sweden
    SKS - Smart Key
    VSS1 - Toyota original alarm
    Unfortunately, I will no be able to leave car connected to battery maintainer. Car will be parked outside on airport long term parking.
    52,862
    we have left our 04 and 08 for up to six weeks at a time in winter, but unheated garaged, not outside. the 2010's have notoriously bad 12v batteries. i would keep a compact jump starter in the car or disconnect the 12v (not the easiest thing to do at the airport) or be prepared to call for a jump start if necessary when you get back. if you have to do that, keep an eye on the jump jockey to make sure he connects to the correct posts under the hood. reverse polarity can be expensive. all the best!
  5. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    The owners manual has recommendations, but here is the problem: In five months, the 12V battery might die. "Might," but you should be prepared.
    When this happens, you must open the door with the metal key. You might need to jump start the car, which you can do with another car or a portable unit. It doesn't take much power to jump a Prius, because the 12v system doesn't turn the engine.
    With a dead battery, opening the rear hatch is difficult. But there are connection points under the hood for jump starting. The manual will show you these points. Be certain that positive (Red) goes to positive and ground goes to ground.
    Once it starts, all will be well. If you are thusly prepared... Most likely the car will just start, but if not, your inconvenience will be minimal.
    One last thing: On some Prius models, you can use the touchscreen to disable SKS. This will help prevent battery drain. Failing that, perhaps SKS has a fuse you can remove before storage, but I'm not familiar with the effects of removing the SKS fuse (probably none)
