Prius 2010 Oil Change Interval Revised? Not yet... (closed)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Sphyrna, Sep 4, 2009.
Thread Status:
Not open for further replies.
  1. hotbrass
    hotbrass New Member
    312
    34
    Cowtown
    Yep! Just like the say on the Amsoil web site:
    "• Replace AMSOIL Ea oil filter at the time of oil change up to 25,000 miles or one year, whichever comes first (other brands at standard OEM* intervals)."
  2. philobeddoe
    philobeddoe ΜΟΛΩΝ ΛΑΒΕ
    575
    107
    Los Angeles
    the Amsoil site recommends a Mann filter with changes at 7500 miles
    Purolator and Wix also make a filter, which I've heard are good for ten
    Toyota has a filter of unknown origin
    you see the thing is, the better the filtration of the filter, the sooner it needs changing, as it will "fill up" and switch to bypass, where it is no longer filtering
    a good oil suspends contaminants, a good filter then filters them out
  3. hotbrass
    hotbrass New Member
    312
    34
    Cowtown
    Mann does not have an oil filter for the 2010 Prius, yet.
    Amsoil recommends the WIX 57064.
    How do I know, I asked.
  4. philobeddoe
    575
    107
    Los Angeles
    ---> Part Detail
    ---> Part Applications
  5. hotbrass
    hotbrass New Member
    312
    34
    Cowtown
    OK. The Corolla 1.8l engine is cross referenced in the part detail for the Prius 2010 oil filter.
    So that means you could use a Mann ML1009?
  6. triumph1
    triumph1 Member
    275
    Based on past oil analyses (my personal), you'd be perfectly safe going with 20k OCI's on a Wix filter with Amsoil.
  7. philobeddoe
    575
    107
    Los Angeles
    yes, or ...
    AC-Delco PF1768
    Carquest 84064
    Fram CH10358
    GM 19185485
    Hastings LF640
    Luber-Finer P980
    Napa 7064
    Purolator L16311
    Security CF6311
    Toyota 04152-37010
    Toyota 04152-YZZA6
    Warner WP980
    Wix 57064
  8. hotbrass
    hotbrass New Member
    312
    34
    Cowtown
    So which is rated for the highest miles? WIX?
  9. Indyking
    Indyking Happy Hyundai owner...
    1,280
    I don't know... Indy, Chicago, Madison (WI)... it
    Exactly:
    That means if you have the Amsoil oil & filter, both should be replaced at 25K or 1 year, BUT if you have the Amsoil oil and the OEM filter, you should replace the OEM filter every 5K, which is the official recommendation from Toyota. Now, what is the point of replacing the oil every 25K if you still have to take your Prius to the dealer to replace the filter every 5K and still top it off with the Amsoil oil every time you replace the OEM filter? I bet we would better off with just paying the standard Toyota OCI every 5K…
  10. philobeddoe
    575
    107
    Los Angeles
    i think your answer is in post #506
    respectfully, i don't think it's that outrageous to have a filter or two on hand ... and to pop one out and replace it every ten to twenty thousand miles, and then pour six ounces of oil into your crankcase
    i'm sure if you can't do it, you have a friend or neighbor who'd do it in trade for whatever it is you do well
    or start a Prius group in your neighborhood from members here on the board, and get together every six months for an oil change and filter change mod party
    it's not really that big of a deal
  11. Indyking
    1,280
    It would not work for me. Last time I tried to play mechanical technician I almost ruined my car's engine. As simple as it appears to be, I would rather give it to the dealer. If he screws up, fine, I'm covered. If I screw up... there goes my Prius and thousands of $$$.
    triumph1, thanks for letting me know that you can run the Amsoil up to 20K in a wix filter with no problems, but my point is:
    The whole idea of using Amsoil is to increase the OCI substantially, from the Toyota’s recommended 5K to 20K or more. If you do that, you likely void Toyota's warrant in case of engine failure (rare event but I know at least one person who had this happening). However, Amsoil does come with warrant, but their warrant will also be void if you don't change the filter according to Toyota’s recommendation, which is 5K.
    So, unless Amsoil comes up with a filter for the new Prius, you've got to change the filter every 5K otherwise you are very likely uncovered by any warranties…
  12. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    if the oil is better and has a higher rating, why can't it be used?
    I intend to use a regular Toyota Oil filter.
    REading this whole thread will educate quite a bit.... if you see my earlier posts, I was quite bewildered as I"ve never used synthetics and until many of the oil guru's provided links for me to study and bounce from I didn't appreciate just how far we have come with oils.
    Oil rarely runs out of its time because pf the filter failing, it has more to do with the additives expiring and so the "toxins" if you will, that are suspended in the oil, will start to go back to the metals in the engine if ran too long and also develop sludge.
    So if you don't use your oil past the time of expiration of its additives, your filter has little to do.
    Using a better synthetic is always a good move, regardless of the filter used.
    I personally still have not adjusted to the idea of a superfine filter for long durations and I'm concerned it may plug up and then offer "no" filtration and or bust the membrane.
    And yes, everyone wants you to buy thier filter, including Toyota, but that doesn't mean a whole lot.
    I intend to start with at least 15K.. may even 20K, test my oil and go from there.
  13. windstrings
    6,280
    378
    Central Texas
    If there a way to do that without losing 1/2 a pint of so in the messy process?
  14. philobeddoe
    575
    107
    Los Angeles
    i'm no moderator, so pardon me ...
    but this has been covered a couple of times in the last 500 hundred posts
    if you are going to take your car to the dealer every 5k, and pay for dealer service, then you're best served by dropping it off, picking it up, and letting them do their thing
    if you don't trust them to used the specced 0W20, then you should bring it, or only pay them for the 5W30 they're actually using
    - by the way, there's nothing wrong with that 5W30, but it doesn't cost the $65 they're charging you
    fwiw, i help out a number of friends with their vehicles, some i just fill up with whatever dino oil is on sale at Pep Boys and a Pep Boys Proline Filter, and BAM!! ... it's about $9.99 total every 3000 to 5000 miles
    other friends get the Amsoil SSO 0W30 and an Amsoil EAO or Wix filter about once a year and off they go, at a cost of about $60-65
    taster's choice baby :thumb:
  15. triumph1
    triumph1 Member
    275
    I've had dozens of oil analyses conducted over the years, and have never seen a problem with running a quality oil filter up to 20k on a properly functioning, maintained engine. I am an Amsoil dealer, but I do use other oils sometimes when there is a good sale, or mainly for my other vehicles that don't get driven as much. I almost always get an oil analysis when I change it. I commute 100 miles daily, 6 days a week. I had an '01 Mercedes with a cartridge filter, and ran it to 20k with a Wix and Amsoil, no problems. In fact, the analysis came back with less wear metals than the previous run with an OEM Mercedes fleece filter. Many of my customers share their oil analyses with me. The few '10 Prius customers I've had went from 10-13k on an OEM filter, with no problems. The oil makes all the difference in the world- Pennzoil Platinum, Amsoil, Maxima, Motul, and even Mobil 1 would probably do O.K. In my experience, in the crap load of cars and motorcycles I've owned, many with cartridge type filters, Amsoil and Maxima are the stoutest when it comes to Extended oil change intervals.
    The first analysis I had on my Prius, I ran Amsoil SSO for 15k from 2k to 17k. It for some reason had 3% fuel dilution, and yet the oil still had a TBN of 4.1. You can't beat that. The fuel dilution has since subsided. The second analysis with Pennzoil Platinum came back with .05% fuel dilution, and a TBN of 3.3 after 10k. The run with Pennzoil Platinum was using a Pure one filter.
    You guys have very low miles on a new Prius, and assuming you keep up with the air filter, I doubt your filter is going to have a lot to filter out using good synthetic oil.......The ICE isn't running as much as a normal car.
    http://priuschat.com/forums/gen-ii-...ng/60559-10-000-mile-oil-change-interval.html
    http://priuschat.com/forums/gen-ii-prius-technical-discussion/64193-atf-change.html
    First oil change-
    Blackstone Labs.
    Miles on unit:17k
    Miles on oil:15k
    Make-up oil: .5 quarts.
    You've run this oil for about 88% of this young engine's life, and that's the reason that we are still finding high
    iron, copper, and silicon. We normally expect wear-in to be past by the time you get to about 10,000 miles, but when
    you run long oil changes from the start, the process takes longer. You'll get there eventually, though you could speed
    the process along by changing the oil at 7,500 miles next time. Note fuel at 3.0%. This is more than we like to see but
    hopefully it's from rings seating. The TBN read 4.1 showing some active additive left. Check back.
    ALUMINUM 5
    CHROMIUM 0
    IRON 18
    COPPER 9
    LEAD 1
    TIN 11
    MOLYBDENUM 1
    MANGANESE 1
    NICKEL 1
    SILVER 0
    TITANIUM 0
    POTASSIUM 3
    BORON 5
    SILICON 58
    SODIUM 6
    CALCIUM 3206
    MAGNESIUM 11
    PHOSPHORUS 594
    ZINC 711
    BARIUM 1
    cSt Viscosity @ 100°C 8.85
    SUS Viscosity @ 210°F 55.3
    Flashpoint in °F 315
    Fuel % 3.0
    Antifreeze % 0
    Insolubles 0.3
    TBN 4.1
  16. radiocycle
    radiocycle Active Member
    550
    78
    Vallejo, CA
    Don't forget the one I have: STP #S10358 (stamped, Made in Korea).
    Calling the 'Tech Hotline' I'm told to 'follow the OEM recommendation' regarding filter life.
  17. hotbrass
    hotbrass New Member
    312
    34
    Cowtown
    I do my own changes. I will let the dealership make my first change at their expense after they prove to me they are putting in the recommended fully synthetic 0W20. After that, they will never see me again for an oil change.
  18. philobeddoe
    575
    107
    Los Angeles
    there are ways to make it less messy
    in making it less messy, you can also recapture and reintroduce rather than lose the oil
    for example, on my kawasaki, the oil filter cap is drilled and tapped for a 10mm "drain plug"
    i can remove this plug and drain the "filter oil" before removing the cover and then the canister filter, insert a new filter, replace the cover, and pour that drained oil right back into the crankcase
    i would have to crawl under a 2010 to see ascertain the best way to accomplish this
    but you really should have a qt. of oil handy for top offs, and this is one of those instances ... after a filter replacement
  19. windstrings
    6,280
    378
    Central Texas
    I know someone is gonna ask again, so I thought I would put this one in bold!.. :D
  20. triumph1
    triumph1 Member
    275
    I understand you're skeptical, and you have every right to worry about your warranty. Can't fault you for that.
    I've just been doing this for far too long, and on far more expensive and powerful vehicles to know there will be no problem.
    All you have to do is check your oil, make sure it stays to the correct level, and you'll be fine. Hell, if you lived near me, I'd do it for you, it's so simple.
    You run more of a risk going to the dealer, than doing longer oil change intervals with a quality oil filter and oil- You have no idea what brand of 55 gallon drum garbage they're putting in, whether they even change the filter, much less whether they'll overfill it or not.
    I'd rather bring the quality stuff to a private mechanic and let them do it.
Thread Status:
