Prius 2011 'Dead' today
Discussion in 'Gen 3 Prius Technical Discussion' started by grin19, Oct 31, 2012.
  1. grin19
    grin19 Junior Member
    17
    NC
    No warning ...would not start. 24,000 miles on a 2011 PRIUS. Tow truck jump started it and I drove 1/2 mile and emission light, then red lights came on and I lost power? Towed to the dealer. Any thoughts? This is my 1st hybrid and I have no clue what is wrong. The tow truck driver mentioned the hydrocell? Help appreciated.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Major bummer, sorry to hear about it. Without codes, it will be hard for anyone to diagnose.
    Fortunately is should be covered.
  3. bwilson4web
    16,512
    Fuel level or possibly fuel pump failure.
  4. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    So can you report back what the Dealer said is the problem? If it is a 2011 and less than 24K miles you get free towing to a Toyota Dealer. The car is also under warranty. Curious what went wrong.
  5. PaJa
    PaJa Senior member
    678
    116
    92
    Czech republic
    My guess is 12V ACC battery.
  6. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    I am thinking the same thing. It's the 12v battery in the back hatch area.
  7. Southern Dad
    Southern Dad Active Member
    350
    212
    58
    Monroe, GA
    I hate hearing that a 2011 with only 24k on the odometer has went down. Considering that my 2011 has 26k on the odometer right now.
  8. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    Did your dealership find what was wrong? Some owners of late model liftbacks have experienced issues with loose hybrid power cables and other Toyota quality spills. Please let us know what they found.
  9. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    What the hell is a "hydrocell"? Sounds like a wet sponge.
  10. damburke
    damburke Junior Member
    Northport, AL
    My 2010 with 10,000 miles on it would not start the other day. Called the dealer and got a tow truck out. The dealer had the TT driver try to jump it off with no success so we loaded it and took to dealer. The dealer gave me a rental so I could get home. The next day the dealer called for me to pick up my car. He said the 12 volt battery had gone bad and they simply replaced it free of charge because of warranty. He said that the newer batteries would sometimes go bad without any warning. If you are not familiar with exactly how to jump start your Prius I would highly suggest you learn. You will probably need to make sure your positive end of your cable that you attach to your Prius will fit on. I have a pair of cables from Sears that work perfectly.
    JMD likes this.
  11. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    Not solved?
    One post "of help" and then gone?
