Prius 2011 - Steering rack removal without removing the subframe
Discussion in 'Gen 3 Prius Main Forum' started by Mushtaq M, May 18, 2024.
  1. Mushtaq M
    Mushtaq M Junior Member
    Pakistan
    Active
    Hi Everyone,
    Looking for some advise and help here. I want to replace steering rack to fix the play / rattle on passenger side in my 2011 prius ( RHD).
    So far what I have gathered is as per the manual and a few other threads here. Subframe needs to be removed.
    As I will be doing this on my drive way I donot feel very confident removing the heavy subframe.
    I have come across this YouTube link reportedly removing rack without removing subframe on toyota yaris. I have had look and my prius has bolts around same position as in this video. 1)Would it make sense to think this is doable on. Prius.
    2) any obvious risks and blockers with the approach on the youtube video .. see link below
    3) any help by sharing your own experience would be much appreciated.
    Thanks in advance
    MM
    Josephyoneyo and douglasjre like this.
  2. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    You're only undoing the subframe on one side so you're not going to have to muscle it back up into place You see how it's coming apart like a spring using a long bar to pry the part just to pull the rack out as soon as he lets go it pops back up into place so pretty normal operation I haven't removed the rack in the Prius I've done it plenty and Corollas and other cars from the Toyota line up over the last 40 some odd years they build them tight now so lot of times you're going to have to undo a frame member or a subframe assembly to finagle a part out of these tight places
    Josephyoneyo likes this.
  3. ASRDogman
    ASRDogman Senior Member
    8,066
    4,089
    Why not just change the inner tie rod? That's likely what is loose.
    And why are there only 4 luck nuts, not 5?
    Tombukt2 likes this.
  4. Mushtaq M
    Pakistan
    Active
    Hi ASR,
    I have changed the inner tie rods 2 years ago. Change it again only to realise the play kow is excessive in the rack ( passenger side)
    Car makes rattling/ thud noise because of this.needs a new steering rack recently confirmed by the alignment company where I took it after changing the inner tie rods.
    Thnx @Tombukt2 ,
    Yes agree it's just one side I am undoing the bolts. This is not an area I have worked before hence seeking advise if there is anything else I need to be aware of like supporting engine( don't see in the video). Any alignment issues if not done correctly.
    Lastly am I likely to bend any parts of subframe or unknowingly pull out any electrical connectors by not being aware of following this approach on a Gen 3 prius?
    Hi @ASRDogman see my reply above
    #4 Mushtaq M, May 19, 2024
    Josephyoneyo and ASRDogman like this.
  5. Tombukt2
    13,864
    2,519
    Durham NC
    No but you're going to need a long steel bar that will help you hold the crossmember open while you're pulling the rack out usually I get my jack to where it's not so high I can put the bar in between the crossmember and the subframe and literally step on it with my foot while I'm using my two hands to pull the rack through the hole just the best use of my foot in the digging bar to hold the subframe down doesn't matter if you bend the subframe a little bit when you push it back up and put the bolts in it it'll straighten right out not suggesting you should try and be bending the subframe It is going to tweak a little but nothing serious nothing that's going to create any alignment issues at all.
  6. Mushtaq M
    Pakistan
    Active
    Thnx, It will be a couple of weeks before i try this out. Will update here.
  7. ozmatt
    ozmatt Active Member
    637
    263
    Australia
    I just done a RHS rack end aka inner tie rod on one of our Prius last week, with the play being only on one side and not the other I would be sceptical about the rack being the problem, the ram it's self is a simple worm driven rod that goes from one side of the rack to the other
  8. Tombukt2
    13,864
    2,519
    Durham NC
    Some people buy the whole rack outer tie rod into outer tie rod end and everything in between ready to go remanufactured at one point I was getting these things for like I don't know $198 or something $219 and at a shop just one side replacing the inner and outer tie rod end or the rack end and the outer tie rod end is almost a $300 job at a regular job shop close to it If not over it and some markets so I'm getting the whole rack for half of that job and then yes I'm stuck putting it in but that's okay I just took a car in today and the guy told me he couldn't do the alignment because the inner and outer tie rod ends were bad on the right side he's full of you know what there's nothing going on over there I just put new struts on the car and everything The steerings is tight as I don't know what there's no slop no play no clunking nothing car doesn't pull nothing there's no way the inner and outer tie rod and any of them are bad but alone the whole side.
  9. Mushtaq M
    Pakistan
    Active
    I have replaced the rack play and the clunks when going over uneven surface has now gone. I will write on teh challenges i faced when removing the rack
    ozmatt likes this.
  10. Mushtaq M
    Pakistan
    Active
    An update for others
    I replaced the old rack over the weekend. This is not as straightforward as the video in link above on Yaris. But at the same time doable with a few extra bolts removed on the other side of the sub frame
    Key takeaways
    1) remove front wheels and support the car on the axle stands behind the sub frame . This will position the sub frame to open up ( at the rear only - not like entire frame is coming down) easily and for the rack to come out ( i had stupidly put one axle stand on front reinforcement rail supporting the sup frame
    2) After you have have disconnected the rack from intermediate shaft and rack bolts removed. YOUR MAIN OBSTACLE is the rear lower engine mount ( 2 bolts and 2 nuts can be easily undone from under the car) ( see picture attached)
    3) you will have to lower rear side of the sub frame by removing the rear brace on sub frame ( 3 bolts) and one upper bolt on each side. keep the Sub frame supported and gradually lower until the engine mount and sub frame separate enough for the rack to come out. ( see picture attached)
    Additional requisite points for above to work
    1) lock steering wheel with seat belt with wheels point straight ahead
    2) Disengage U joint from inside the car. Rubber boot on the pinion is hard is best pulled from inside the car by first separating metal rim in it
    3)Match marks on the joints and shafts of the rack important for things to go back easy
    4)separate tie rod ends ( i removed them out completely) and separate the drop links as they resist sub frame from dropping lower.
    5) keep the sub frame and Engine supported as you remove the bolts.
    6)partially lower sub frame just enough to get the rack out. REMEMBER the sub frame is still connected the knuckle via the control arm( ball joints). So only lowers at the rear end. This is more manageable than dropping the whole heavy sub frame like others suggest including how the manual suggests . See attached picture on how much space is to be created for the rack to come out
    7) There is 10 mm bolt X 2 holding a wiriness harness bracket at the rear of the sub frame. Disconnect this bolt or at least be aware and keep an eye as you lower the sub frame. You don't want to snap the wire thats connected to this bracket. I removed just on 10 mm bolt.
    8) two trolley jack would be helpful.
    I never though i could ever do this. But had no choice the cost in parts and labor. as i had decided to go for an original low mileage rack over an after market ( questionable quality). I had to do this myself in case if the part wasn't working. I had done the ground work and found reputable local used car parts suppler. He didn't let me down.
    #10 Mushtaq M, Jun 4, 2024
  11. Tombukt2
    13,864
    2,519
    Durham NC
    Yes this can be very similar these antics on most front wheel drive cars where the rack penetrates through the little holes like that but glad you got it and I thought rebuilt racks were relatively inexpensive from outer tie rod end to outer tie rod and the complete assembly usually when I go to look and we're talking $200 rebuilt by AI cardone or whoever the big rebuilder is handling these at the time not generally a lot of mistakes to be made some racks when you have them out on the ground you'll see a big adjusting nut they may have done away with that by now for the generation 3 which is why you're replacing the rack more than likely but excellent work my friend Glad you made it through.
    Michael Cyr and Mushtaq M like this.
  12. Mendel Leisk
    42,349
    Late, but worth a watch. There’s a part 2 as well.
    Josephyoneyo and Mushtaq M like this.
  13. Mushtaq M
    Pakistan
    Active
    very detailed video on Subframe. This would have been a good to watch before i took on the job.Its not late for someone planning on the same job
  14. ozmatt
    637
    263
    Australia
    Good job Mushtaq, I am very interested to learn how the rack can encounter play only on one side because the ram runs from one end of the rack to the other, it does not make sense to me how only one end of the (common to both sides) ram can have play but not the other unless its actually coming from one end aka tie rod?
    Matt
  15. Mushtaq M
    Pakistan
    Active
    @ozmatt
    My inner tie rods failed two years ago..replacing the tie rods at the time fixed the issue. But about 12 months ago I started to hear a light knocking noise when going over uneven roads. This gradually got louder. I initially thought suspension and found no issue with suspension arms and bushings (infact change dropl links and)
    Later thought this could be strut mount and removed and reassembled the left strut mount with no broken component.
    Finally when I was looking to install new inner tie rods noticed the play only on the passenger side. The garage at wheel alignment said it has ti be fixed as the play was too much.
    Hence I started this job. After 12 months of annoying noise when going over bumps... narrowed it down to play in steering and now its fixed.
    I have since been investigating on the old rack. There is a plastic bushing that appears to be loose or broken.
    Long story short you will have to go in an order to eliminate the issue. In my case I did everything before it was narrowed down to play in the rack..
    I hope that helps
  16. Mushtaq M
    Pakistan
    Active
    One last point to complete the thread.
    My car went in for a wheel alignment this week. Following the rack change the steering wheel was slightly offset . At the alignment when the realigned the steering wheel . It triggered an error C1290 - Abnormal zero point steering angle sensor value( ABS Skid light ON).
    This was eventually resolved by recalibrating the steering angle sensor at the garage. All working fine.
    I am not sure how this could have been prevented.
  17. Tombukt2
    13,864
    2,519
    Durham NC
    There's an alignment procedure for the clock spring when you have the steering wheel off it drops out some people turn it backwards a turn or a half and get it off kilter and hence bad readings . They take it off align the red slot with the Red Dot put it back and Wella.
