Prius 2011 with 29MPG trouble!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MomaniSM, Aug 14, 2018.
  1. MomaniSM
    MomaniSM Junior Member
    JO
    Three Touring
    Hi folks
    I have recently my Prius 2011 (100 mile) dropped mileage from 38 to 30 and sometimes 28 mpg !
    nothing hase been changed since the last month niether the oil :)
    I have techstream with MVCI cable (obdc to USB) cable and can connect to ECU to change some customization setting like buzzer, alarm, security alarm and so on.
    I tested batary blocks voltage using batary drain and showing no issue on any cell, and while driving batary showing very good level at all times.
    I dont have check engine light one, but I feel the problem is with gas engine, i might be the sparks (lately changed on 80k mile), or sensors (fule, intake air, ... etc).
    Here comes my question: is there a parameter/setting file or a guide for techstream application to read all performance counters and compare it with normal range to report the issue.
    52,773
    have you checked all the usual suspects, air filter, tires and pressure, etc.?
    MomaniSM, NutzAboutBolts and ITBland like this.
  3. Jkan2001
    Jkan2001 Member
    201
    63
    Dallas TX
    Bet it's the 12V gone bad, test it when the car has been parked a while. Nothing else would cause that drastic of a drop.
    MomaniSM likes this.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    The onboard computers are doing that......all the time.
    If they see a problem, a light lites and a code is set.
    But they can't see EVERYTHING.
    In addition to what was already mentioned, a dragging brake can kill your gas mileage.
    So can a failing 12 V battery.
  5. MomaniSM
    JO
    Three Touring
    Sure, today i smell fule from exhaust after engine started
  6. MomaniSM
    JO
    Three Touring
    Breack check and tires run freely, 12 v battary... I will change it and report, what Amp to choose for the new battery
  7. sam spade 2
    7,035
    2,804
    2017 Prius c
    Batteries can be tested. No need to change it blindly.......unless maybe if it is 7 years old or more.
    If you do need a new battery, you should get one that is made for THAT car.
    The size needs to be right, as well as the type of posts.
    BUT.....if you are smelling raw gas from the exhaust, that likely means that there is a problem with the fuel system.
    Maybe an injector or two stuck partially open.
    This may require the services of a mechanic.
    danlatu, MomaniSM and Mendel Leisk like this.
  8. Mendel Leisk
    42,257
    Is "JO" Jordan? No offense, but it's a struggle deciphering acronyms sometimes.
    How many miles does the car have, on the odometer?
    What kind of driving are you doing typically?
    I assume no warning lights?
  9. MomaniSM
    JO
    Three Touring
    How to test battery?, I have multimeter, and it showing 12.3 today morning after overnight idle; is that good?
    For the stucked injectors, I suppose that will fire a warning light right? but no light showing on the dash.
    #9 MomaniSM, Aug 24, 2018
  10. MomaniSM
    JO
    Three Touring
    Yes dear, JO is Jordan country in the middle east, the car having 104K mile and no warning lights on my dash.
    driving conditions ... i think it is hard to classify, it is all city drive in Amman, but Amman city having many hills and mountains in addition to heavy traffic ... but I used to have ~40mpg, my friend having 45mpg, and some guys reported 50mpg
    HV battary tested and all cells reported consistant voltages (discharge test)
  11. MomaniSM
    JO
    Three Touring
    My test results
    Mode $06 report generated by Torque for Android
    Vehicle VIN: Not present
    Vehicle Manufacturer: Unknown
    Vehicle Calibration ID: Not present
    Test report:
    MID:$01 TID:$91
    - O2 Bank 1 Sensor 1
    Max: 2.18359mA Min: 0.70312mA
    Test result value: 1.46094mA
    PASS
    MID:$01 TID:$93
    Max: 3.99757V Min: 0.03697V
    Test result value: 0.09943V
    PASS
    MID:$01 TID:$94
    Max: -0.04014V Min: -3.9977V
    Test result value: -0.07674V
    PASS
    MID:$01 TID:$95
    Max: 343ms Min: 0ms
    Test result value: 0ms
    PASS
    MID:$02 TID:$08
    Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
    Max: 1.19V Min: 0.585V
    Test result value: 0.664V
    PASS
    MID:$02 TID:$8b
    Max: 998ms Min: 0ms
    Test result value: 49ms
    PASS
    MID:$02 TID:$8d
    Max: 5,995ms Min: 0ms
    Test result value: 1,605ms
    PASS
    MID:$02 TID:$8f
    Max: 2.0984 Min: 0
    Test result value: 0.17934
    PASS
    MID:$21 TID:$a9
    - Catalyst Monitor Bank 1
    Max: 9.99393 Min: 0.24979
    Test result value: 0.26657
    PASS
    MID:$31 TID:$bd
    - EGR Monitor Bank 1
    Max: 655.34998kPa Min: 0.8kPa
    Test result value: 16.17kPa
    PASS
    MID:$35 TID:$81
    Max: 9,490ms Min: 0ms
    PASS
    MID:$3d TID:$c9
    - EVAP Monitor (0.020")
    Max: 32.767kPa Min: 0kPa
    Test result value: 0.308kPa
    PASS
    MID:$3d TID:$ca
    Test result value: 2.552kPa
    PASS
    MID:$3d TID:$cb
    Test result value: 1.804kPa
    PASS
    MID:$3d TID:$cd
    PASS
    MID:$42 TID:$91
    - O2 Heater Monitor Bank 1 - Sensor 2
    Max: 33,214mOhm Min: 0mOhm
    Test result value: 24,565mOhm
    PASS
    MID:$81 TID:$81
    - Fuel System Monitor Bank 1
    Max: 0.04596 Min: 0
    Test result value: 0.01025
    PASS
    MID:$81 TID:$82
    Max: 0.499 Min: -32.768
    Test result value: 0.089
    PASS
    MID:$a1 TID:$0b
    EWMA Misfire counts (average) for last 10 drive cycles - Misfire Monitor General Data
    Max: 65,535Count Min: 0Count
    Test result value: 0Count
    PASS
    MID:$a1 TID:$0c
    Misfire counts for last/current driving cycles(calculated) - Misfire Monitor General Data
    PASS
    MID:$a2 TID:$0b
    EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
    PASS
    MID:$a2 TID:$0c
    Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
    PASS
    MID:$a3 TID:$0b
    EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
    PASS
    MID:$a3 TID:$0c
    Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
    PASS
    MID:$a4 TID:$0b
    EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
    PASS
    MID:$a4 TID:$0c
    Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
    PASS
    MID:$a5 TID:$0b
    EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
    PASS
    MID:$a5 TID:$0c
    Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
    PASS
    MID:$f0 TID:$12
    Manufacturer defined MID -
    Max: 45,016 Min: 6,472
    Test result value: 65,520
    FAIL
    End of report.
  12. bisco
    52,773
    12.3 is low, start by replacing it, then move on to more complicated things if the mpg doesn't come up.
    best way to buy a 12v battery is to find a seller that matches it to a 2011 prius. otherwise, you might have fitment issues, cross polarization or vent tube problems.
    that being said, a 2011 with 100k needs an intake and egr circuit cleaning, and an oil catch can f you can manage it.
    mjoo and Mendel Leisk like this.
  13. MomaniSM
    JO
    Three Touring
    Battery changed, mpg now 32, i need to proceed with other, EGR clean, but what is oil catch can, is it the same of cleaning the engine from inside using engine cleaning fluids
  14. Mendel Leisk
    42,257
    An oil catch can is a container with with air inlet and outlet, and a labyrinth of some sort. The idea is to take in air with oil-mist, and capture the oil portion, just allow the air to exit. You need to periodically empty it of the oil/water/gas it accumulates.
    It's typically spliced into the hose between Positive Crankcase Ventilation valve (mounted on the crankcase side wall) and the intake manifold. The object is to reduce the oil mist being dumped into the intake manifold.
    mjoo and bisco like this.
  15. bisco
    52,773
    see the thread 'oil catch can, eliminate that knock' by @danlatu
    #15 bisco, Sep 4, 2018
    mjoo likes this.
  16. Mendel Leisk
    42,257
  17. bisco
    52,773
    thanks!
    Raytheeagle and Mendel Leisk like this.
  18. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    A clean EGR system and intake are definitely important for fuel economy.
    There are also reports of fuel pumps failing sometime after 100k. They begin with worse fuel economy. What happens is the fuel pressure is too low to properly spray and vaporize the fuel. So some fuel escapes without being burned in the engine.
    There is a schrader valve that you can connect a gauge to and check the fuel pressure.
    Pixel XL ?
    Mendel Leisk and Raytheeagle like this.
  19. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Where’s the schrader valve located?
  20. MomaniSM
    JO
    Three Touring
    Can we find the fule pressure using techstream, and what shold a good reading is?
