Prius 2013. Horn not honking when locking car
Discussion in 'Gen 3 Prius Main Forum' started by Eagle1995, Oct 8, 2022.
  1. Eagle1995
    Eagle1995 New Member
    Baltimore
    2013 horn not honking when locking prius lights flash doors lock horn stopped honking
  2. Tombukt2
    Tombukt2 Senior Member
    13,863
    2,519
    Durham NC
    I don't know if that means something or somehow you turned it off I thought I saw it when I was running tec stream one time. The alarm settings that is
  3. Tombukt2
    13,863
    2,519
    Durham NC
    My two owners manuals for my 13 go into detail about this I have to pull them out and take a look but there's a quite a bit of info on what you want to happen when you push buttons on the remote and how to make that so. I try to avoid the remote as much as possible and just stays in the car whatever.
    52,857
    my 12 has never honked, just a beep. is that an aftermarket alarm?
  5. Elektroingenieur
    2,515
    3,288
    Three Touring
    Does the horn sound as expected when the button in the center of the steering wheel is pressed?
    If not, troubleshoot the horn using the Repair Manual (more info) and Electrical Wiring Diagram. If so, then the 40 A P/I 2 fuse, integration relay, and high-pitched and low-pitched horn assemblies are good, and I’d suggest checking for a problem with an aftermarket alarm system or its wiring.
    As @bisco mentions, the factory-installed wireless door lock control system uses the horn only as the panic alarm. There is an entirely separate wireless door lock buzzer, above the left front fender liner, that can be set to beep, or not, when the doors are locked or unlocked.
