Prius 2013 Hybrid Gear Shift Issue
Discussion in 'Gen 3 Prius Main Forum' started by Addi, Sep 13, 2017.
  1. Addi
    Addi New Member
    Pakistan
    I am having very strange issue with the Auto shifting of Gears. Gear will only change to the next when I leave the accelerator. If I keep pushing the accelerator without taking my feet out of it, the gear will not change. For example on straight highway, if I push the accelerator and don't take my feet from it, the gear will not change and I can feel from the engine sound that's its getting heavy but as soon as I will leave the accelerator and push it again, the gear will change and I can feel the car is getting lighter and the gear has changed. Anyone can please help what is this and how to recover from this issue and why the Gear is dependent on stepping accelerator. Appreciate it.
  2. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    There are no gearshifts in a Prius. It sounds like the electric motor is not doing much. It could be an issue with the high voltage battery pack. You'll need either a dealer to check it out or try to find something out by yourself using an OBDII adapter and the torque app.
    Or it could just be how a Prius drives. When you accelerate briskly, the engine will rev up and when you let go off the accelerator it will go to low revs.
    Are you new to Prius driving?
  3. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    That is how it should work, as there are no gears. When you push it, the engine revs up to give you max power. When not, it goes low rev or even shuts down
  4. Addi
    Addi New Member
    Pakistan
    Thanks Maarten28 for the reply. Actually I have been driving it for last 2 years. How I found this issue as my fuel consumption has gone up. Before this issue I was getting 25Km/L and now it has drop down to 13KM/L. Also in hilly areas (uphill road) the car takes lot of power to go up however before it was very smooth.
  5. Addi
    Addi New Member
    Pakistan
    Thanks 4est for the reply. That's an issue when I push the accelerator without taking my step out of accelerator, it remain stay at the current position (it does not revup) unless until I take my step away from the accelerator then it revup.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    How many miles on your Prius? What maintenance has been done? Have you noticed any issues with the HV Battery (or checked the fan to ensure its clean)?
    Keep us posted (y)
  7. bisco
    51,154
    could be too hot for the battery, and the software will limit use. what is the outside temperature, and do you park in the sun?
    Raytheeagle likes this.
  8. Maarten28
    415
    224
    Netherlands
    Then I really suggest having the HV battery checked.
