Prius 2016 4th Generation: How to remove door panel" and my speaker install.
Discussion in 'Gen 4 Prius Audio and Electronics' started by orangebang, Sep 10, 2016.
  1. zorro18888
    zorro18888 New Member
    Singapore
    On the left is the connector to the tweeter, the right is the connector from Redwolf. The tweeter connector cannot be inserted into the Redwolf.
    This is the stock tweeter connector. I would assume the that purple (-) and Pink (+) wires comes from the front speaker and are then
    wired together at each tweeter location. See pic below
    Connection at the tweeter end.
    Question:
    1. can I cut off the stock tweeter and Redwolf connectors and solder the pink & purple wires to the positive and negative wires of the Redwolf?
    2. When #1 is done, I will connect the redwolf + and - plugs to the tweeter's + and - terminals.
    Will the above work?
    #41 zorro18888, Jun 3, 2020
  2. Mambo Dave
    Mambo Dave Active Member
    641
    307
    2019 Prius
    L Eco
    Thank you. The road noise levels of both the pavements used around here, and of the Gen4 Prius itself, are such that I can no longer stand listening to even podcasts over the OEM speakers. I may try upgraded from RF speakers like you bought just to see if I can hear things more clearly at 80 MPH.
