1. Carlos Cracco
    Carlos Cracco Junior Member
    Brasil
    I have a 2016 Prius, when removing the multimedia center for checking, the air conditioning plug was also disconnected, from that moment the air conditioning fan turned on, the air conditioning stopped working, the seat heater stopped working, the windows They stopped working, the HUB doesn't work, it doesn't show the temperature on the panel, any suggestions?
  2. kiwiscoot
    kiwiscoot Member
    60
    30
    Christchurch New Zealand
    2019 Prius Prime
    I guess you didn't disconnect the 12V battery before you did this? The car would've sensed the disconnect.
    Try disconnection the battery, press the start button, wait some minutes and reconnect the battery. Switch the car on and run the windows down and up from each of the doors to calibrate them again.
    52,886
    did you reconnect the air conditioning plug
