Prius 2017 electric package noise
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Matella, Feb 11, 2024.
  1. ColoradoBoo
    ColoradoBoo Senior Member
    1,323
    938
    Monument, Colorado USA
    If it hasn't been done, your 2017 is due for coolant change and transmission fluid service. (Just drain and fill.) Any car mechanic should be able to handle those for you. You might, also, want to get the brake fluid and pads checked.
    Doug McC likes this.
  2. Matella
    Matella Junior Member
    Toronto
    Changed everything and it makes the noise again.
  3. Danno5060
    Danno5060 Active Member
    397
    204
    Wyoming
    If it's the high-frequency squeal you're hearing, it may be a side effect of how the inverter works. In that case, it's normal.
    Instead of creating a pure sinusoidal output of varying frequencies to drive the AC electric motors, the inverter works by generating Pulse Width Modulated outputs. The switching is done at a high frequency, which can generate noise at those frequencies (as well as harmonics, spurious frequencies, and harmonics of spurious frequencies).
    Matella and Doug McC like this.
  4. Matella
    Toronto
    Thank you
