Prius 2024 purchase: Miscellaneous features questions
Discussion in 'Gen 5 Prius Main Forum' started by pgb205, Feb 25, 2024.
  1. pgb205
    pgb205 New Member
    earth
    Is remote start available and how does that work(I plan to get model with phone unlock)?
    Do I just have to be near/inside the car with my fob/phone to control it?
    XLE Model comes with self-opening hatch. I want to make sure that it can self-close AND lock with no human input. Meaning I press button on fob and hatch unlocks and opens fully. I press button on fob again and hatch closes and locks with no assistance.
    Is there option to turn off daytime running lights? I will be camping with the car and often it helps to have the car ON and running and yet be in a blackout mode with all lights off. I want to make sure the Daytime running lights can be turned off.
    Climate mode: Does the car need to be started and in this special mode to work with temperature settings set? How does that work in real world? Can I expect to be comfortable in 20F when camping (My understanding is that I can expect to draw half gallon overnight in most conditions).
  2. Paul Gregory
    Paul Gregory Senior Member
    2,338
    614
    Alberta
    2024 Prius Prime
    XSE
    The remote start feature in the app is buggy. When driving in HV mode, the car shows 34% charge while parked. Trying the remote start results in this message, "Car start not possible because it must be at more than 30% charge." So, as a work around, I drive in "Charge" mode to give it at least a 40% charge. This way, I am able to start it once. When I try a second time, I get the message, "Car start not possible because car may be remote started only two times in a row." In this climate, one 20 minute cycle is not enough, so I wish it would start at least twice. It doesn't.
    Too many restrictions to be very useful.
  3. David W. Griffin
    David W. Griffin Junior Member
    I have an LE, not an XLE but my daytime running lights are controlled by a setting on the left stalk so they are easy to turn off.
