Prius 250K miles and replaced hybrid battery
Discussion in 'Gen 2 Prius Technical Discussion' started by 2GenPrius, May 30, 2020.
  1. dolj
    dolj Senior Member
    8,445
    4,290
    Wellington, New Zealand
    What is the code?
    Is that with the A/C on? If not, use the A/C to keep the cabin temperature below 82ºF. The cooler the better.
    Are you using Torque to monitor the inlet air temperature for the HV Battery?
  2. 2GenPrius
    2GenPrius Member
    188
    34
    22
    Californication
    There is no code, I was saying if the relay or blower were not performing correctly then it would throw a code, right? And yes, I am using Torque Pro to monitor the inlet temp, it's on the attachment I posted earlier. I turned the AC on but with that and running the fan speed at max 6 using the torque pro override, it's a bit much driving around town. I'm thinking of running it at 3 or 4 setting and seeing if that's better.
    Since this battery is a lot better than the last, I'm thinking I should do a recondition on it? Anyone in SoCal with a Prolong that can help?
  3. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    What do yo mean by 'a bit much', is it cooling too much?
    I would be leery about overriding the fan at any speed below 6 (max), as the vehicle won't be able to increase the fan speed as needed.
    Raytheeagle likes this.
  4. 2GenPrius
    2GenPrius Member
    188
    34
    22
    Californication
    I meant drawing amps from the system, therefore drawing down against the battery system. I hit two bars yday driving around town with the fan set to max speed (and max AC). I guess I'm just afraid of tapping out this battery too, which shouldn't be a problem if its a good battery.
