Prius 2nd Gen Warning Lights & ODB Code help
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Scott Miami, Jan 16, 2025.
  1. Scott Miami
    Scott Miami Junior Member
    Hello, My trusty Prius started with persistent Brake and ABS Warning Lights after startup. It seems to drive fine and I've checked brake fluid levels. A dealer wanted me to tow the truck in in order to get diagnostic codes, as he couldn't tell me if it would be safe to drive until then.
    I have since bought an OBD3 reader, compatible with the Prius 2nd gen that covers ABS codes. The entire electrical a/c system had been replaced about 1 year ago. Here is the readout analysis:
    ABS/VSC/TRAC
    · C1343 Current Hydraulic System Malfunction (RR)
    EMPS – Electric Motor Power Steering
    · C1532 Current ECU Malfunction
    Air Conditioner codes
    · B1413 History Evaporator temperature circuit or Evaporator fin thermistor
    · B1421 Current Solar Sensor Circuit (passenger)
    · B1433 History Air outlet damper position sensor circuit
    · B1441 History Air Mix Damper servo motor circuit (passenger)
    · B1442 History Air inlet Damper control servo motor
    · B1443 History Air out damper position sensor circuit
    Can I safely drive this car about 30 miles, or should I pay for towing?
    What does the "Current" versus "History" readout mean?
    Can one determine what the fix would be from just those codes?
    Thanks much,
    Scott
    52,891
    are the brakes working okay?
  3. Tombukt2
    Tombukt2 Senior Member
    13,875
    2,521
    Durham NC
    Seems to drive fine means you went forward farther than 100 ft and backwards farther than 50 ft and the car stops and the pedal seems like it's supposed to be and now you're going to drive it down secondary roads to the dealership for exactly what reason you have the codes? Seems like there's no reason till it's ready to be fixed. The whole electrical system was replaced I doubt it in a Prius that would have been totaled if it was generally speaking You mean a wiring piece of harness or something was fubar and had to be replaced certainly I don't think many people are going to rewire a generation 2 Prius generally speaking.
  4. Scott Miami
    Yes, I've driven it a few miles.
  5. Scott Miami
    I don't quite understand your comment; my technical knowledge is 2/10. The Prius only has 125k miles in 20 years, and it works fine. I've already replaced the high voltage battery, and the air-conditioner system (since the aluminum element degrades near the coast and leaks); both were done for a fraction of the dealer price. The dealer wanted me to buy a new car, but I just use the car for when I'm in Miami; it has no rattles and feels solid The only other mechanical things that needed replacing have been the inverter cooler pump (twice) and 12V battery (three times).
  6. bisco
    52,891
    i think you can drive it on back roads. leave plenty of stopping room, and be prepared to stomp on the brakes if they go into failsafe mode.
