PRIUS 2ZR COLD START MISFIRE BLOWN HEAD GASKET 2010-2015
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Georgina Rudkus, Dec 15, 2020.
  1. rjparker
    rjparker Tu Humilde Sirviente
    10,164
    6,319
    Texas Hill Country
    Get it diagnosed to be sure. Gasketmasters operates in your area replacing head gaskets for less than that. But an engine swap may reduce oil burning, a likely root cause on the 2010-2014s. $2600 is cheap for anywhere in the US, almost questionable in the Bay Area.
    I might consider getting advice here:
    https://lusciousgarage.com/
    Jag29 likes this.
  2. Mendel Leisk
    41,495
    My guess is the $2600 option would involve a high mileage "salvage" engine, perhaps on the verge of similar problems as you currently have.
    Jag29 likes this.
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,468
    2,434
    Taylors, SC
  4. rjparker
    10,164
    6,319
    Texas Hill Country
    That is why my go to advice for this epidemic on high mile Prius engines is to have a low mile (less than 100k?) engine rebuilt even if it is $2000 more than a mechanic's head gasket quote. Eliminate oil burning and oil leaks as well. At least for the next three or four years. In Jag29's case, 118k miles is still a candidate for a head gasket - assuming it was not an oil burner, the head and egr are cleaned and a provision for extended pcv hosing is added. The decision is not easy for the average owner. That is why a good hybrid mechanic's testing and advice is warranted.
    Jag29 likes this.
  5. Georgina Rudkus
    3,468
    2,434
    Taylors, SC
    I just find this stuff interesting from an engineering standpoint.
    My car hasn't reached 25k miles in nearly nine years of ownership. I purchased if with cash savings in Feb. 2012. Immediately, I started saving for the next. So, I already have enough for the replacement, if needed.
    If it was me, I would buy a completely rebuilt engine for under $2k and install it myself, and be done with it.
    Ultimate_Combination, Jag29 and Grit like this.
  6. Mendel Leisk
    41,495
    If your pockets are a little deeper, and you don't like surprises, a new short block and machine shop rebuilt head is not that much more. It is more complexity than just dropping in a salvage engine, granted.
    It'd be interesting to know if any-and-all new short blocks come with the revised pistons/rings. Almost moot though: either way you should be good for at least another 100K miles.
    Georgina Rudkus likes this.
  7. Georgina Rudkus
    3,468
    2,434
    Taylors, SC
    There are complete rebuilt engines with heads available on eBay for about $1800 delivered.
  8. Mendel Leisk
    41,495
    That seems too good to be true? Not sure.
  9. Jag29
    Jag29 New Member
    Vallejo
    Thanks for all of your reply. Update I just change the ignition coil yesterday. Start the car this cold morning, the noise and shake vanish. So i bought a coolant to put in on level. I’m gonna observe it for another couple of days or week. If the check engine come back again, then probably I have to decide. I appreciate all of your advice and comments
  10. DarkenMoon
    DarkenMoon New Member
    Reno, Nevada
    Hopefully this Imgur link will work.
    The blue highlighted part is what the video ID is. I found one of the videos ID already by looking through old posts.
