Prius 3 overheating and HV battery
Discussion in 'Gen 3 Prius Technical Discussion' started by Boursine P3, Jun 12, 2020.
  1. Boursine P3
    Boursine P3 New Member
    Senegal
    i have prius 3 Gen3
    and facing with these issues:
    the light of coolant water is ON, i checked the radiator, the thermostat, and dirites, but it is not fixed
    water refulling is ok; there is not lake of water coolant
    the second issue , it is displayed check your hybrid system
  2. AzusaPrius
    AzusaPrius Senior Member
    2,255
    942
    This will display check hybrid system light. Just check what codes it has, most likely the waterpump is bad, that is an easy fix or maybe the thermostat is stuck.
