Prius 3 parking lock actuator
Discussion in 'Gen 3 Prius Technical Discussion' started by Pricop Alex, Dec 16, 2019.
  1. Pricop Alex
    Pricop Alex Junior Member
    Netherlands
    Hello all!
    I have an Toyota Auris HSD 2011, with 116 000 km (same engine like prius gen 3) and i have a problem with the parking lock actuator pawl. Sometimes, not everytime , when i change to D or R i get a violent sound and shake from that pawl ,like it is releasing very violent. It is normal? Can somebody tell me please what can be the problem? Thank you !
  2. Attila Fekete
    Attila Fekete Member
    164
    59
    Budapest, Hungary
    How do you park your car? “Handbrake” first and than switching to P or uou just switch to P?
  3. Pricop Alex
    Netherlands
    I stop the car and with the foot on the brake i press P only , without handbrake.
  4. Attila Fekete
    164
    59
    Budapest, Hungary
    I would try using the “handbrake” before P. If that helps, it’s normal working, just that “stick” thighten.
    Pricop Alex likes this.
  5. ASRDogman
    ASRDogman Senior Member
    7,963
    4,046
    The park position was not designed to hold the car. If you are on uneven ground, the gear will
    press against the paw.
    If you stop, put the trans in nuetrul, foot brake, then "p" when you stop.
    When you start, foot on brake pedal, start car, release parking brake, move to "drive, etc.
    See how that works...
  6. Pricop Alex
    Netherlands
    I tried to do in these ways but i still get the shock from pawl.
  7. ASRDogman
    7,963
    4,046
    mmm Have you checked your motor mounts? Maybe one is broken and it's the engine and transmission
    rocking back and forth?
  8. Mendel Leisk
    42,146
    Something is obviously not right. But I'm not sure why you are convinced it is the parking pawl. It could be but who knows.
    If it's practical for you: maybe start by checking there's no transaxle fluid leak, and that the level's ok. You need the car raised and level. Then remove the fill bolt, and feel with a finger: the fluid should ideally be level with the hole lip, or no more than 10 mm lower. When reinstalling the fill bolt torque to 29 ft/lbs. Preferably with new washer, but it should be ok to just reuse the once. You need a 10 mm Allen Key style "socket" for this.
    After that, dealership visit? Have them test drive it for starters. It would be easy for them to check for leaks and do the level check too.
    #8 Mendel Leisk, Dec 19, 2019
  9. mikefocke
    4,064
    1,852
    Sanford, NC
    I had a pLock actuator replaced after getting an error message and not being able to shift my car out of park. This happened 4 times. Several time I had to be towed to the dealer. It was so rare there were almost no references I could find anywhere on the net. The pLock pawl should retract when you shift out of Park but on mine it was not retracting. I thought it was a mechanical deformation but not so.
    While this was on a Prius v (the wagon) I thought this insight might help.
    You should stop, keep foot on brake pedal, shift to park and then engage the pLock and only after that remove your foot from the brake pedal. Especially important when parking on slanted ground.
  10. AzWxGuy
    AzWxGuy Weather Guy
    1,077
    554
    Tucson, AZ
    2021 Prius
    This doesn't sound like a typical P-lock problem related to a weak 12V battery. There is normally an MFD code displayed, "P lock malfunction when parking, park in flat place and apply parking brake securely". So, moving on from that, I'm wondering about idle speed. The throttle body can get gunked up to the point the throttle plate doesn't close all the way and additional RPM's will get distributed through the PSD (Power Shift Device, the "transmission" if you want to call it that) and could make shifting difficult as you describe. I guess check idle speed? Could be a problem in the PSD also, in the planetary gearing. Something dragging or not releasing. Don't know if there would be codes. Just some thoughts.
  11. mikefocke
    4,064
    1,852
    Sanford, NC
    Look at this thread especially towards the end and you will see they replaced some other parts and whether it was the parts or their having to reattach all the connections we will never know. 5th pLock Malfunction failure | PriusChat
