Prius 3rd gen Doesn't start
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Chamara Somarathna, May 2, 2018.
  1. Chamara Somarathna
    Chamara Somarathna Junior Member
    Sri Lanka
    Hey I got a 3rd gen prius and I couldn't close the trunk properly couple of days back and the car was parked since. Now the car is not starting, no head lamps, no horn, no hazard lamps and the break paddle feels tight too. interior lamps are lighting but kind of weak. what might be the problem
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,788
    Bay Area
    Replace your 12v battery
  3. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    By leaving your hatch open, the 12 volt battery used to turn on the computers does not have enough juice to do this:(.
    But buying a new 12 volt battery and checking it’s voltage prior to placing it into service shouldbget you back on the road:).
    Keep us posted (y).
    Chamara Somarathna likes this.
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Trunk needs to be closed all the way.
  5. Mendel Leisk
    42,292
    For starters the hatch light: is it set to be on whenever the hatch is open?
    You might be able to recharge the battery, but it will not last that much longer, after a drain like that: likely best to replace.
    #5 Mendel Leisk, May 2, 2018
  6. Chamara Somarathna
    Sri Lanka
    Thank you sir
    Thank you very much sir, and you guys are so gracious thanks for that too
    Yeah I didn't have much experience on this kinda stuff, Thanks
    The hatch light was turned off when the hatch is opened. Thank you very much for your kind assistance.
    #6 Chamara Somarathna, May 3, 2018
    Mendel Leisk and Raytheeagle like this.
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I'm one of those who closes car doors, trunks, hatches and hoods gently as I can. But for this hatch, don't hesitate to put use some force closing it, manual says it also therefore it was built durable to use with some force.
  8. NutzAboutBolts
    1,756
    1,788
    Bay Area
    When replacing your battery, you can manually open your trunk for easier access. You can watch that video on our YouTube channel. Don’t struggle like what I did the first time when I changed my battery, all cramped up in the back jerry rigging my body to replace the battery lol.
    jerrymildred and Raytheeagle like this.
  9. Mendel Leisk
    42,292
    I have some heavy insulated gloves. When I've disconnected the negative battery cable from the post I stuff it into one of the gloves (to help isolate it), and the other glove I lay across the hatch threshold, covering the latch opening, so it can't inadvertently close.
    scona and Raytheeagle like this.
  10. Dead12VBattery
    Dead12VBattery Junior Member
    Amsterdam
    As the others said, the 12V is clearly drained. However, I had the same issue and jump starting then driving for 30 min fixed the issue. I haven't had issues with the battery since and the dealer even checked battery health and it was fine.
  11. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Ah, had to do "the military crawl." Raytheeagle would put it.
    NutzAboutBolts and Raytheeagle like this.
  12. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Or the “crawl of shame”;).
    jerrymildred and NutzAboutBolts like this.
  13. NutzAboutBolts
    1,756
    1,788
    Bay Area
