Prius 4 Gen CCL and DCL
Discussion in 'Gen 4 Prius Technical Discussion' started by Abarnabe, Feb 22, 2024.
  1. Abarnabe
    Abarnabe Active Member
    172
    102
    Netherlands
    Does anyone know the max Charge Current Limit and max Discharge Current Limit for the 4 Gen Prius?
    The max value is usually at 35 °C and around 60% soc.
    The values are visible in the Hybrid Assist app by touching the battery symbol.
    I'm trying to compare the values between several prius generations.
    #1 Abarnabe, Feb 22, 2024
  2. andywhy
    andywhy New Member
    UK
    I know you posted this a while ago but I hope this is useful to you. This is from my gen4 based Lexus UX:
    Max Discharge: 22.5kW (30.1HP)
    Max Charge: 26.85kW (36HP)
    At 43 degC power limits fall as temperature rises. At 45 degC they're very restricted to around 4kW charge, 12kW discharge.
    Abarnabe likes this.
