Prius AC blows hot only when outside > 77 F
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Docholo, Nov 23, 2017.
  1. Docholo
    Docholo Junior Member
    23
    Have a 2005 model, the AC cools very well if it is under about 77 degrees F. outside. Dealer techs have verified that it makes a great drop in temperature relative to ambient if the outside is cool.
    Plenty of refrigerant at the right pressure according to them and the gauges all read normal when they see the car during the cool weather.
    However, I have to deal with the AC when it is above 77 outside.
    If it is warmer, the vents blow uncooled dry air from either outside or inside depending on the recirculation setting. I can hear the AC compressor whine, but it isn't doing anything to the temperature of the air coming through the vents at all.
    The techs can't diagnose the problem because they only see the car on days when it is cold.
    My hypothesis is that since the compressor works fine at low outside temps and there is plenty of refrigerant, there must be something unusual with the sensors feeding the AC ECU, the AC ECU, or the actuators that the ECU's drive.
    I have a copy of the tech manual but there isn't a diagnostic fault tree for how to diagnose the compressor running but no cool air coming out of the vents due to other valve settings. I don't have a fancy OBD code reader...yet.
    Thanks for any ideas,
  2. bobodaclown
    bobodaclown Member
    216
    72
    Are all the venting actuators working correctly? Is the AC line from the compressor getting cold? Are the electric fans up front working properly?
  3. Prodigyplace
    12,710
    11,848
    Central Virginia
    Where in the world are you located? How many miles on the car?
    @Elektroingenieur is usually good at directing where to find the troubleshooting trees but access usually varies by country.
    Without location information any advice may be severely limited. :(
    52,773
    are you using a/c manually, or auto?
  5. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Try setting the temperature to max cold to rule out the problem with most of the sensors.
    Try to start with 8 bars of HV-battery and turning the AC to max cold then. If the temperature is colder then (when engine is not running) you probably have temp door that’s not going all the way to cold.
    Also check that fans are running when the problem is present. As bobodaclown suggested.
  6. Docholo
    23
    Those are all good ideas, it will take me awhile to figure out where the lines/doors are and how I can observe them.
    The questions I can answer easily are
    I have tried all different combinations of manual with A/C on and off, automatic at regular temperatures and max-cold, and different combinations of recirculation on and off.
    I am in Los Angeles CA with 147k miles on the prius. Outside weather was 96 deg F with about 17% humidity.
  7. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    change the ac filter behind the glove box... if its clogged the volume of air will not flow enough to cool the car as it heats up..
    or your HV battery is getting weak and the computer is limiting the ac as it draws the most power.
  8. valde3
    2,002
    750
    Finland
    It should be pretty simple to test for a temp door that doesn’t close all the way and HV-battery that’s weak and limiting AC at the same time.
    When it’s hot enough that problem exists:
    Turn the AC to max cold and force charge the HV-battery at the same time. Force charging is done in drive (e-brake on for added safety) left foot on brake and right on accelerator. When the HV-battery gets to 8 bars stop force charging (stop pressing accelerator and press the park) but keep the AC on until the battery goes down to 2 bars.
    If the AC was cooler when you were force charging and it goes from 8 to 2 bars pretty fast then you probably have week HV battery. If it’s cooler when the engine was not running (especially after it hasn’t run for a minute) then you probably have blend door not going all the way to cold.
    But first check that the fans are running.
  9. Elektroingenieur
    2,515
    3,288
    Three Touring
    This is a good starting hypothesis.
    I’d recommend using the Toyota Techstream diagnostic software, or the older Toyota Intelligent Tester. With one of these tools, you can read any diagnostic trouble codes that might be stored in the Air Conditioning Amplifier. You can also use the Data List and Active Test features, to check the reading from each sensor and exercise each actuator. This can save a lot of time troubleshooting individual circuits.
    As you may know, generic OBD II scan tools designed for engine and emissions diagnosis won’t have these Toyota-specific capabilities—you need something that can communicate with a Toyota air conditioning ECU.
    It sounds like @Docholo already has the Repair Manual.
    If not, the Los Angeles Public Library sponsors access to the ChiltonLibrary service, but unfortunately, the material there for the 2005 Prius is incomplete. In this case, it’s not a great loss—as @Docholo correctly mentions, the closest Problem Symptoms Table entry is “Temperature Control: No cool air comes out,” which has a long list of possible causes, the first of which have already been checked:
    Prodigyplace likes this.
  10. Docholo
    23
    Is the only way to do this to use a Techstream and analyze the ultra-special OBD codes? I believe there are a set of button presses that goes into a mode where actuators are moved, but I don't know how to judge if a move was a success or a failure.
    The metal tubing going into the sight glass is 98 F with the car off but the engine warm. If I turn the car on and the ICE runs for 30 seconds because there are 8 bars of charge, the metal tubing on the input to the sight glass becomes 111 F after running the A/C with no ICE for about 3 minutes. This is the tube coming out of the condenser going to expansion valve/evaporator.
    This probably isn't useful information because I do not know the temperature of the tube going from the evaporator into the compressor because it is hidden inside the engine as near as I can tell.
    At least one of the fans comes up to full bore the moment the A/C is clicked on based on sound. I can't see the side of the fans to judge whether more than one fan is running. I believe the fan(s) are as loud as they traditionally have been.
    I did the force charging gag, with everything max-cold. With the ICE on, the temperature coming out of the vents is 0.8 deg F hotter than with the ICE off for a long time. This does not seem significant.
    I changed the AC filter behind the glove box. It was clean. At 8 bars charge, the AC acts the same as if it was at 3 bars charge.
    Thanks all,
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Probably the front condenser is completely bug clogged.
  12. Docholo
    23
    I got into the actuator/sensor check mode that communicates through the MFD. The only DTC is 21; this is the solar sensor which I believe is quasi-normal. It was late afternoon.
    I moved to actuator check step 2 which is where the compressor is at 7500 RPM (sounds like it too) and the air mix-damper is supposedly -10% or "cool". If I probe the suction hose between the evaporator and the compressor right around the "L" I get 101 degrees. If the bubble sight (the "H") is 111 degrees, that means there is some change in temperature either side of the condensor/compressor pair.
    I did a more careful measurement of fresh air input temperature to vent temperature in the above state. The outside fresh air going in was 92 degrees and the air coming out of the vent was 84 degrees. The ICE was essentially off since the catalytic converter has stayed warm all afternoon. Eight degrees of temperature drop is something but not enough to deal with socal.
    I still need to figure out a way to see the radiator fans visually and to double check the hot/cool mixing actuator.
    ukiltmybrutha likes this.
  13. Docholo
    23
    I pulled the front grill and took some pictures of what I believe to be the front of the condenser:
    I do not see a lot of biological debrie but it does look like the bottom half of the radiator has a lot of the fins folded over. I see that some people online try to to straighten these out, but it isn't clear if that actually works in practice.
  14. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Yeah thats bad right there. Good portion of the condenser has all its fins bent over. Looks like your missing the bottom plastic fod cover which is really important as it keeps road debris from beating the face of the condenser up like you see here.
    You can buy a fin comb and try to straighten out those fins. That and the coils need a good cleaning. Use only microbial coil cleaner. Lowes sells a spray can in the ac filter aisle that works real good. Green can. Buy 2 cans lol. Not sure where you live.
    Its basic ac maintenance like you should do to your home ac unit both the compressor and the air handler evap coil. If not the compressor runs really hot+ short life + hot air.
