Prius annoyances
Discussion in 'Prime Main Forum (2017-2022)' started by Zed Ruhlen, Jun 13, 2019.
  1. Marine Ray
    Marine Ray Senior Member
    1,139
    949
    Sparks, NV
    Better yet like Tesla, it should open up automatically. But then our Prius Primes would probably cost more :)
    #241 Marine Ray, Dec 13, 2019
  2. drash
    drash Senior Member
    2,600
    1,340
    Upstate NY
    XLE AWD-e
    Ah, you mean for a Prius EV Limited or Lexus NX300p (Prime).
    Unsupervised!
  3. GSK
    GSK Active Member
    169
    107
    Baltimore, MD
    Wait, mine does indeed do this. I thought it was a great feature, having it light up as I approached it in the morning to unplug.
  4. bresna
    bresna Active Member
    193
    144
    Southern Maine
    Maybe they fixed it in 2020. Mine is a 2017.
  5. CharlesH
    2,798
    1,166
    Roseville, CA
    The Prime is designed for low emissions and efficiency, not to be religiously EV. This group went through that discussion with first generation Prius Plug In (PiP). Sometimes it is more efficient to use the gasoline engine, sometimes it is more efficient to use electric, so the hybrid system picks what it thinks is best in the current situation. The PiP did not have a pure EV mode; what was called "EV" was really like the EV Auto in the Prime, where if you accelerate hard enough the gasoline engine kicked in. But people wanted "pure" EV, so the Prime has EV mode, which uses electric no matter how hard you press the pedal. Most of the reasons for the gasoline engine to start in the Prime are related to heating things up to minimize emissions. Note that the Prime gets to operating temperature very quickly, since it has things like a coolant loop through the catalytic converter to capture heat from it.
  6. drash
    drash Senior Member
    2,600
    1,340
    Upstate NY
    XLE AWD-e
    Nope, charging light lights up as I approached the car with my key. However, for this to work the car must be locked.
    iPad ? Pro
    Tideland Prius likes this.
  7. Marine Ray
    1,139
    949
    Sparks, NV
    With my 2017 the charging port light turns on even when the doors are unlocked. If the doors are locked, both the interior and charging port lights turn on.
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    My '17 Premium just finished charging, so I went out to the garage with my keys. Car was not locked. Charging port light did not come on as I approached. I waited about 10 seconds to make sure. No light until I unplugged the EVSE. Then the light came on. Could there be a difference in behavior between trim levels? Seems like a silly idea, but it wouldn't be the first silly idea in a car.
  9. mistermojorizin
    mistermojorizin Active Member
    310
    137
    usa
    2019 Prius Prime
    I totally wish they put the wiper in.
    Just pointing out something I didn't learn until owning the car for a little while, that you can lean the rear headrest forward and out of the way with the push of a button and without having to take them out.
  10. Mendel Leisk
    42,354
    If it's like third gen, you're not missing much. Well except maybe in heavy snow. The rear wiper is puny, sweeps about 20%, of an expansive, steep sloping upper window.
    Driving in rain, I'll almost always leave our rear wiper off. Once in a while I might do a single swipe, look at the lackluster result, carry on.
  11. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    I checked on my 2017 PRIME Premium this morning, I can confirm that the charge port does light up as I approach if I have a fob with me, but it seems to work only if the car is locked for mine. If the car is unlocked, it did not light up. I did not check the interior lights, but IIRC at least on mine, it does not turn on the interior lights just by approaching to the car regardless of the car being locked or unlocked. I think it does turn on as I grab the handle to unlock it, but can't remember for sure. There is a custom settings for the interior lights illumination. That must be turned on for the interior lights to illuminate, but not sure if that is linked to the charge port illumination.
  12. Marine Ray
    1,139
    949
    Sparks, NV
    Could illumination also be tied to day or night?
  13. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    Dang - we still haven't figured out who's got it and who doesn't and why some don't have it.
    Could it be a techstream option that not all dealers know how to activate?
    Anyone with a Plus have it? Mine only lights up when the chargeport door is opened.Day and Night, i think anyways.
  14. Salamander_King
    11,024
    8,980
    New England
    Yeah, that's entirely possible. I checked mine this morning before dawn in dark. I am not sure if it lights up in daylights.
  15. Marine Ray
    1,139
    949
    Sparks, NV
  16. Trollbait
    12,831
    I'm guessing the #3 column means it is a dealer change setting item.
  17. Marine Ray
    1,139
    949
    Sparks, NV
    Yes, legend is on top portion of screenshot.
  18. Marine Ray
    1,139
    949
    Sparks, NV
    Here's only thing I could find in manual about charging inlet illuminating with key fob.
  19. CharlesH
    2,798
    1,166
    Roseville, CA
    Or by OBD2 tool such as Carista
    illumiN8i likes this.
  20. mister2cool
    mister2cool Member
    98
    52
    New Jersey
    2020 Prius Prime
    BTW, I notice that charging port light only comes on if the car is OFF.....
