Prius annoyances
Discussion in 'Prime Main Forum (2017-2022)' started by Zed Ruhlen, Jun 13, 2019.
  1. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    Maybe that's because PRIME can be charged only if the car is OFF... ;)
  2. mister2cool
    mister2cool Member
    98
    52
    New Jersey
    2020 Prius Prime
    LOL yes.. so I come home with my kid, I always plug in the car first before I shut off the car so I can keep the air running. Of course the car shuts off when I connect the charging cable but I had to do that in the dark..
    Salamander_King likes this.
  3. Salamander_King
    11,024
    8,977
    New England
    Wow, that's a news for me. I knew the car would not let me START if the cord is plugged or the charge port door is open, but stopping the car from READY when the cord is plugged is a function I did not know.
  4. mister2cool
    mister2cool Member
    98
    52
    New Jersey
    2020 Prius Prime
    Yup.. it actually shuts off all the way, not just removing READY.
    drash likes this.
  5. Zed Ruhlen
    Zed Ruhlen Active Member
    247
    138
    Hood River, OR
    2018 Prius Prime
    I get that, but traveling down the road with a full battery and the heater on should not trigger the engine to come on when I am in EV mode. The best economy in this situation is to keep the engine off. Let ME decide when to engage the engine. I get that using the HVAC is going to reduce my range and I am perfectly OK with that. What is the point of an EV mode if it doesn't go EV?
  6. bisco
    52,801
    have you considered the possibility that something is not right with your car? unless the temp in oregon goes below 14f, i can't see any reason for the engine to fire in ev mode, unless you press the front defrost button.
  7. Rob43
    Rob43 Senior Member
    1,373
    1,050
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    This.
    It took me a while to figure this out. Once the front defrost button is pushed, the ICE runs on my Prime Advanced until I turn off the car.
    I've learned Not to use it unless I absolutely have to, once I cycled the car off & on at a Red light just to get back to EV mode.
    Rob43
  8. Marine Ray
    Marine Ray Senior Member
    1,139
    949
    Sparks, NV
    It should go back to EV mode once you've turned the defroster off. My understanding is that the engine starts it will run through what is called a warm up cycle (59°C) when its done with the cycle it will go back to EV mode with defogger still on but when engine temp is below 59°C it will start engine again.
  9. Marine Ray
    1,139
    949
    Sparks, NV
    Also, if you don't want the ICE to turn on what to do is set the HVAC to blow at the feet and the windshield and just press auto to defog instead of pressing the defogger button. Might be slower but it works.
    Rob43 likes this.
  10. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    I do this 95.37% of the time.
    Rob43
    Raytheeagle and Marine Ray like this.
  11. Zed Ruhlen
    247
    138
    Hood River, OR
    2018 Prius Prime
    I literally never use the front defrost button. Like I say, it makes no sense.
    Mine won't go back to EV after it starts the engine unless I turn off the car and turn it back on again. I've done that at stop lights multiple times.
    Sometimes it does get below 14, like 5 days a year. Usually it is in the 30s in the winter here. It's entirely possible that something is wrong. I already have a bad seat sensor in the rear and now the TMPS has stopped working. How do I know? Because I put on my winter tires that don't have sensors and the light isn't coming on.
    #271 Zed Ruhlen, Dec 19, 2019
  12. fuzzy1
    10,689
    By any chance are your summer wheel rims stored close to where you park the car at home? Are you driving the car more than roughly 15 minutes at a time while away from home?
    Several members here have revealed that their TPMS systems can get refreshed from detecting the registered wheel/sensor sets stored next to the car in their garage. This likely varies with how long the car is powered on while sitting next to the wheels, some cars may not be turned on long enough there to catch all four signals.
    And, it appears that when the registered TPMS sensors initially go undetected, the car has to run a significant distance or time before the initial TPMS warning is flagged. (I think I have gone about 10 miles / 15 minutes in my Subaru, not sure on the Prius.) And this is per trip segment / power-on cycle time, so if the car takes only short trips, it is possible to go the entire winter without a TPMS warning. However, once it takes a trip long enough to give a warning, then subsequent trips produce warnings very quickly.
  13. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    I bet you are 98.6 % sure of that:p.
    Rob43, Marine Ray and bisco like this.
  14. Zed Ruhlen
    247
    138
    Hood River, OR
    2018 Prius Prime
    The factory wheels are stored in a shed in the back yard so maybe 50 feet away from where I park. Last night I drove for 1/2 an hour 3 times. I've driven a fair amount since I swapped tires. I am confused though. What is the point of a system that doesn't detect an out of normal condition for half an hour? I mean you going to drive half an hour on a flat tire before the system detects it? My Sienna throws the light within seconds of starting out after I swap tires.
  15. fuzzy1
    10,689
    When a sensor is present and reporting pressure, a low pressure condition is reported immediately. The significant delay is for not receiving any reports at all from a given sensor.
  16. Zeppo Shanski
    Zeppo Shanski Active Member
    307
    189
    Chicagoland
    Please excuse me if this has been covered. I just went to the end without much reading.
    I live in Chicagoland where winters can be really freakin' cold. It's not winter yet and I'm really freakin' sick of freezing my tukas off going to work. ... I've got a rather ample tukas and its 25-miles to work. Why do I get such sucky heat? ... and how can I fix this issue?
    TIA FOR ALL / ANY HELP.
  17. bisco
    52,801
    block heater
    make sure coolant temp is apprpriate
    check heater core flow
  18. Salamander_King
    11,024
    8,977
    New England
    As far as PRIME is concerned, switching to HV provides plenty of heat. That's why I drive mostly HV during winter months. Even though it is acclaimed as most efficient automobile electric heater, a pathetic heat pump never warms up the cabin temp high enough.
  19. Tideland Prius
    16,674
    1/2hr isn't long enough. I didn't get my low TPMS light until about 40-45 mins of run time.
    Usually, my light stays off in the winter because my all-season tires are nearby so the car detects it.
    Also, you're confusing two different scenarios.
    The first is the light coming on because the system can't detect a signal.
    The second (Sienna scenario) is the light coming on because of low pressure.
    I'm pretty sure if you park your car in the garage/driveway and leave it on, go into your shed, release the air in the tire, the car will detect a low pressure much sooner than 30 minutes.
  20. mistermojorizin
    mistermojorizin Active Member
    310
    137
    usa
    2019 Prius Prime
    My first winter with a prime, so it's all new to me. But my ice will turn off eventually, after being enabled by pressing defrost. Just pressed off on the ac and waited like 20 min.
