Prius annoyances
Discussion in 'Prime Main Forum (2017-2022)' started by Zed Ruhlen, Jun 13, 2019.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Cars rear windows are not behind the rear wheels in terms of placement, so they don’t get the “road wash” effect like that of a van or SUV;).
    The Jeep Cherokee I had awhile back was terrible for that in the rain and wet winter road season. But their electrical system issues allowed it to run all the time with the dimmer switch set to anything other than “dim”:cool:.
    One of its more redeeming qualities (y).
  2. Trollbait
    12,814
    The angle difference isn't steep. If sedans were liftbacks, they'd have rear wipers.
    The squared off back end means more turbulent air which leads to to more rain, snow, and dirt getting deposited on the window.
    Raytheeagle and Mendel Leisk like this.
  3. mister2cool
    mister2cool Member
    98
    52
    New Jersey
    2020 Prius Prime
    So I have had my Prime for 2 months now and I have been meaning to start a discussion on some things I find to be very annoying\puzzling but I guess this is the perfect place. I am going to skip all the ones I see people have discussed, such as door locks, shifter knob, dash location, etc.
    #1 on my list is remote AC. I turn it on in the cold morning to warm up the cabin but why does it shut off the moment I open the door? By the time I strapped in the baby all the warm air is already gone. My wife's Inifiniti OEM remote start turns on AC or heat base on outside temp and climate control setting. It would even turn on heated seats, steering wheel and defroster. You go in the car, press start button, and all controls are handed off to the key in your pocket seemlessly. It doesn't stop when you open the door car and then make you start it again. As security measure, her car would shut off if you touched anything inside other than the Start button while the car was started by remote start. Why couldn't Prime do something intelligent like that?
    #2, Why is it necessary to turn the car off when I plug or unplug the charging cable?
    #3 is trunk lighting. It is definitely the worst I have ever seen. My Previous Gen 2 actually had a cabin light much close to the back so when the hatch is open you got some of that from the top in addition to the small one on the side. In the Prime, the one on the side is all you got and it's almost completely useless if you had anything in the trunk. Luckily I think this could be an easy DIY fix.
    #4, no mirror turn signal. Almost every other car has a signals on the mirror these days but we can't have one.
    #5, DRL using actual headlight. I have the Limited and there are literally 16 LED lamps facing forward, 2 lowbeam + 2 highbeam + fog + 3 vertical on each side, and why do they have to choose the 2 most heavily used ones, and probably the most expensive to replace, as DRL? The 3 in the vertical lamp\turn signal seem to be the best choice. I understand not every model has those spots filled with LED's, which is another retarded decision to skip them. They would probably add $10 to cost and would make all the models look so much better.
    #6, Auto highbeam seem to have a narrow vertical field of view. I live in a hilly area and there were several times already when I am going down even a small hill, camera doesn't seem to see oncoming cars just beyond the hill, resulting in highbeam remaining on and blinding others.
    #7, I got seatbelt sensor on every seat, and an AC selector to choose driver only or all the seats. How about linking the two so it would switch off driver only automatically when there are more people in the car????
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Toyota has seen those 'drive away with the gas nozzle' videos and worries you will drive away with the charger and burn down your house. They are sensitive that way.
    jerrymildred and Mendel Leisk like this.
  5. mister2cool
    mister2cool Member
    98
    52
    New Jersey
    2020 Prius Prime
    Well that would make sense if they won't let me start the car or go into gear with charging cable connected.
    So the situation kinda connect to #1.. knowing that AC will shut off the moment I open a door, in the morning I tried to go and start the car first and then strap in the baby, then unplug the car and go. But the car would shut off when I disconnected the charging cable. When I come home, it's the reverse. I stop but keeps the car running, go plug in and then get the baby out and go inside.
    Worst part is that it doesn't shut off all the way, but goes into ACC mode... First few times it got me in the morning wondering why the car wouldn't go in gear.
  6. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    Are you saying your PRIME lets you start the car or go into gear with charging cable connected?:confused:
  7. Zed Ruhlen
    Zed Ruhlen Active Member
    247
    138
    Hood River, OR
    2018 Prius Prime
    See, I'm not the only one who questions the inexplicable UI choices. That trunk lighting is something I had meant to add. Hell, my 1967 Datsun had a trunk light and if there was ever a car built to be cheap it was that one.
    I didn't realize the DRL used the regular headlights. Guess they stay off for good now.
    At least your seatbelt sensors work, the rear ones in my car were messed up from the beginning and the dealer STILL hasn't managed to get replacements. That was 16 months ago...still waiting. I had to use Carista to turn off all the warning beeps.
    Yeah, I still don't understand the remote A/C algorithm. It's the one time I wish I had a way to interact with the system from my phone.
  8. Zed Ruhlen
    247
    138
    Hood River, OR
    2018 Prius Prime
    I think the "rising belt line" is hideous. Of course every car uses the design cue now since car companies are incapable of making their designs unique which is why a Camry/Accord/Fusion/Everything GM makes/Optima all look virtually identical.
  9. ctscoob
    ctscoob Junior Member
    56
    36
    CT
    2020 Prius Prime
    For #5, I wouldn’t think worrying about the cost to replace is a big issue. They are LEDs which generally have a significantly longer lifespan than non LEDs.
  10. Zed Ruhlen
    247
    138
    Hood River, OR
    2018 Prius Prime
    Well sure except they are super expensive and non user serviceable according to sites I've looked at so I'll just leave the DRL off.
  11. fuzzy1
    10,690
    If these LEDS are well designed and manufactured, then their life expectancy should be much greater than the car they are built in to. Failure is vastly more likely to be from external mechanical damage than from hours of use.
    Have factory LED DRLs or headlights on any other Toyotas displayed any pattern of premature failure from full-time use? (Yes, many of us have our LED DRLs on full time.)
  12. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I would have valued my safety higher than a light fixture, but to each his own. I am sure I have burned a tank of gas in a decade of driving with my headlights on, but no one hit me.
    Bob Comer, fuzzy1 and GSK like this.
  13. bisco
    52,803
    i have never had drl's or used my headlamps in the daytime, and no one has ever hit me either
    Data Daedalus likes this.
  14. ctscoob
    56
    36
    CT
    2020 Prius Prime
    My thought too.
  15. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    I'd like to add a vote for DRL's. The prime is my first car with DRL's, but my last car was a gen 3 prius and I kept my lights on all the time. Making sure people notice me is worth the extra wear on the lights. (the gen 3 lights never failed anyway)
  16. Tideland Prius
    16,674
    Considering I’ve never changed my Gen 3’s high beam bulbs (used as DRLs for almost 10 years), the LEDs will be fine.
    2014 Corollas use the low beams as DRLs in Canada. If there’s a problem, you can be sure a recall will be on the way. So far, I haven’t seen a blown headlight (even on taxis).
    fuzzy1 likes this.
  17. Salamander_King
    11,024
    8,977
    New England
    I know DRL is required in Canada, but is there any states in the US that requires DRL? I don't think ours do. In many states, having wipers on requires the headlights to be on. I counted 20 such states according to this source. Headlight Use - AAA Digest of Motor Laws However, I have not driven any car that has wiper switch to automatically turns on the headlight.
    #177 Salamander_King, Nov 18, 2019
  18. mister2cool
    mister2cool Member
    98
    52
    New Jersey
    2020 Prius Prime
    LOL.. good point.. I never actually tried. :rolleyes: It lets me start but the message is displayed on dash that charging cable is connected so I haven't gone further to put it in gear.
    Yeah DRL is not required in US. I don't disagree that DRL is useful for safety and the cost of any parts is worth it if it might save your life one day. My point was simply that there are plenty of LEDs to use for DRL and I question the choice they made. Yeah I wished for headlights linked to wipers for a long time as well..
    Salamander_King likes this.
  19. Mendel Leisk
    42,293
    Tideland Prius likes this.
  20. Salamander_King
    11,024
    8,977
    New England
    Try it. I bet the car will not start (go to READY mode) if your PRIME is unmodified. However, now you mentioned it, I am not sure if it acccuary goes to Non-READY modes, such as ON mode or ACC mode. My guess is that it won't, but I have not tried that either.
    Like you stated in your previous comment, the choice of using the main head light for DRL is probably due to the fact that other trims do not have other LEDs. For designing and manufacturing, it would be much easier and cost effective if all three trims used the same DRL circuitry. Also, I suspect that neither the accent lights nor the fog lights are suitable for DRL function to be visible by other cars? Don't know.
