Prius as a taxi?
Discussion in 'Gen 3 Prius Fuel Economy' started by thethought321, Sep 3, 2012.
  1. thethought321
    thethought321 New Member
    Hi all,
    I've had a 2011 prius for about 3 months now, reaching 11,000. From what I've researching the engine break-in millage is 5,000-10,000. I constantly check that I have the correct pressure on all tires, along with proper maintenance.
    I bought the car with 2,000 miles (practically new), my problem is that in all that time I'm only averaging anywhere from 32-38MPG (300-360 miles each tank). It cost me $35-$40 every time I tank the prius up, way better than my old Lincoln town car but there's about a $15,000 difference.
    I paid $21K for the prius no nav, no leather, all basic functions and for that kind of money I could have easily gotten a camry or escape that doesn't require much effort to get the same MPG's.
    I use this car as a cab in NYC and driving style is as follow:
    In city: 25-35
    Highway: 55-65........even 85 at times but I know that the MPG consequences for that.
    Acceleration in city: super hard to coast with this car, lots of red lights and turns (constantly stopping).
    Acceleration on highway: get around 50-55MPG coasting at speeds of even 65MPH, however when I have to accelerate the MPG's drop to 5-20MPG's.
    All in all I don't know if something is wrong with the car or maybe my driving makes the high MPG's impossible to reach, but any advice would be most helpful.
    Is the prius really worth its money? I mean I literally have to be driving 7-15MPH to get the 50+MPG's.
    I suspect something might be faulty because it's had 2 owners before me, on top of which I've seen and spoken to many other co-workers with 2nd gen prius's and they do way better than my "upgraded version".
    Any who, again any advice would be great, (e.g., using a diagnostic tool, inspecting certain parts under the hood).
    Thanks in advance!
  2. fuzzy1
    10,688
  3. thethought321
    - Have you read This Thead Yet?
    Yes
    - What fuel economy are you getting and how are you determining fuel economy? (trip computer or manual calculations)
    Trip computer
    - What fuel economy are you expecting and why?
    42-45 at the very least, because I don't put much abuse on the gas pedal. Again I have to go extremely slow just to get 60+
    - What are the approximate outside air temps?
    75-90 degrees
    - How long are your trips?
    Depends, sometimes short and sometimes long (used as a cab). On long trips I get 40-50 miles back and forth. On short trips I go no more than 4 miles.
    All together I get 120-150 miles daily.
    -How old is your 12v battery? What is the voltage reading of your 12v battery after sitting over night? (Method Here)
    Practically new, don't know the voltage after sitting over night
    -Have you had your alignment checked? Any pulling or abnormal tire wear?
    yep, and nothing abnormal
    - How much of it is city vs. highway? Roughly what's the average speed in overall and and of each segment? Is there a lot of stop and go driving?
    Out of the 120-150miles I get daily, I'd say 40% is city the rest is highway. City: avg speed is 25-35, Highway: avg speed is 55-65. there is a lot
    of stop and go driving.
    - What's the terrain like of your drives? (e.g. flat, gentle hills, steep hills, etc.)
    Quite bumpy sometimes but flat for the most part
    - What are your tire pressures?
    F:40,R:38
    - Is your oil overfilled? (i.e. above the full mark on the dipstick)
    Nope, also running synthetic
    - Make, model, year, engine and transmission of previous car? (e.g. 08 Honda Civic Si 2.0L 4 cylinder, manual transmission) What did you actually get on the same trips/commute? (Please give us actual numbers, not EPA ratings.)
    Ford, Lincoln town car signature series, 2006, v8, don't know the transmission specs
    - What region/state are you in? (if you haven't set your location)
    Astoria NY(most of the time),Manhattan (frequently), JFK,LGA,NWR airports (frequently),Brooklyn (sometimes) and other areas of the queens borough. I always touch the highway when
    I leave Astoria.
    - How are you trying to drive (e.g. trying to stay in electric only?) and how hard are you braking?
    I try for the most part to coast and when it's not possible I hover a lot but never touch the end of the ICE, as far as breaking goes I would like to think I'm
    very precautious and never slam the brakes.
    - What modes are you using, if any? "normal", EV, power, eco?
    Normal:City, Eco:Highway
    - Are you "warming up" the ICE (internal combustion engine) by letting it idle after powering on?
    Not really, really rarely
    - Are you driving using D or B mode?
    D
    - HVAC settings? Are you using the heater, AC, auto mode, etc.? If using auto, what temp is it set to?
    AC@67-71 Fan speed:usually half the bars, sometimes two away from max
    - Are you using the factory tires and wheels? If not, please indicate tire make, model and size (e.g. Goodyear Assurance Fuel Max 185/65R15).
    Factory
    - If reporting a mileage drop, did anything significant change on your car (e.g. accident, hit a curb or big pothole throwing off alignment, oil change/other maintenance/repairs, changed tires or wheels, etc.) or your commute?
    I was rear ended (just broke the bumper and bent the support assy (Chassis wasn't touched), but didn't touch any other parts) about 3 weeks ago but I fixed it with a local dealer and there wasn't any change in MPG's, overall driving,
    and steering.
  4. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    I hope the other cab drivers on this list will find this thread. I suspect they will be able to help you more than us random folks.
    However, I have a few questions that may help:
    What other vehicles have you used as taxis?
    Compare their actual MPGs with the MPGs advertised. The ratio there might be similar to what you get with the Prius compared to the advertised MPG.
    The "instantaneous" MPG you see doesn't really tell all that much--accelleration always takes you quite low, as you will see in any car that shows it--it's worse in NYC (I'm a former east coast city kid, though I never had a car when I lived in NYC) because of how inconsistent freeway speeds can be. If you are getting good mpgs when on the highway at steady speed, I will bet the car is OK.
    I'm going to bet this has been a bad summer for MPG in NY--has it been hotter than average, and have you been using a lot of AC? In the city, I bet you use a lot of AC for the distance travelled, making it even worse.
    Where do you do most of your driving? Manhattan vs. Queens can make a lot of difference.
  5. PriusCamper
    PriusCamper Senior Member
    13,417
    5,416
    Pacific Northwest, USA
    Your car is doing great considering circumstances... City driving, especially cab driving, doesn't give you much time to focus on improving MPG, but the more you learn about how to pulse&glide, as well all the factors that go into keeping the car in tip-top shape I'm sure you'll see your city mpg creeping up into the low 40's. Oh and apply that same vigilance you have for tire pressure to also making sure your oil level is never too full after oil changes which can lower MPG.
    Also the higher the tire pressure the better the MPG, but of course too high of tire pressure you'll lose a soft ride and more important safety and stability. But many driver's on here keep their tires a bit higher than recommended for better mpg. I was able to get my tires all the way up to 51psi before it became unsafe. I keep 'em around 48/46 now!
    You also need to talk to other Prius Cab drivers on here for perspective. I was talking to a guy last week who had some cool stuff to say about Prius cab driving here: Newbie Prius Cabbie Here! | PriusChat
  6. kgall
    kgall Active Member
    984
    152
    OK, I just saw your new posting, and I have a hypothesis:
    You say you run AC at 67-71, auto. That's a huge difference from the ambient summer air. Try running at closer to 75.
    You also say you average 25-35 in the city.
    But in Manhattan and Brooklyn I bet you spend a lot of time stopped or crawling. Now Priuses are good because they can shut down the gas engine sometimes in those conditions, but you lose some of that benefit with a lot of AC, because the power that the AC draws still has to come eventually from the gas burned.
    Plus, no matter how you slice it, the EPA's so-called city driving cycle isn't as much stop and go as real life.
  7. fuzzy1
    10,688
    Do you spend much time stopped, or standing at the curb or in a taxi waiting line, with AC running? If so, this will really clobber apparent MPG. See kgall's reply.
    But if the fuel penalty of the AC is expressed metric style (liters/100-kilometer, or gallons/100-miles), the cost won't look so bad. And if you figure the cost in gallons/day, it will still be much better than any non-hybrid taxi.
  8. walter Lee
    1,126
    376
    Maryland
    I agree.
    The AC is set way too low and its going to automatically trigger the ICE to keep it running.
    Resetting the AC to 78 F probably will signficant help the overall MPG.
    Limiting the top highway speed to 55 mph or 60 mph would help too.
    If you are sitting waiting for a fare/passenger unless its really realy cold outside (say 32F) it doesn't pay to turn off a Prius for 30 minutes and then turn it back on because of *startup* cost involve in a cold start.
    This might sound counter intuitive but if your HV battery is persistently low -- around two to three bars most of the time then you should set the Prius in Normal or Power Mode.
  9. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    What is your average speed on an actual tank... if I do commuting only I am getting 17-19MPH you probably even less and sweet spot for the prius is around 50-55 under load !!! So if you go a lot to the airport (off peak) you can get a lot better mileage then purely in city. But it is relative ... you can tell quickly if it worth it for you ... you know how much per mile the gas cost in this car and the crown vic ...
    No not at all I am driving in NYC. Not that much in the city but Queens I commute from LI to Midtown everyday and over 40,000 miles my average is 51.6 MPG (at least 90% of that is the commute) so ... yes accelerating is an issue this is a 1.6L engine and so much the battery can do but you should be able to do better .... also it makes a huge difference when the car is "heavy" with 4/5 people with cargo ...
    Nothing under the hood you can fiddle really, but if you use the proper tire pressure what Toyota puts on the door !!! that is t0o low for high millage and that is the best and easy way to increase MPG ... I use 42.5 front 40 back which is higher then "proper" and I can tell when the shop adjusts it down ... 3-4-5 MPG at least....
    And as others point out A/C in summer and heating in the winter will be taking quite a bit you mpg down but since you are a cab you can't just roll down the windows I guess there are some rules.... for the winter you should consider blocking the lower grill (it is safe but you may want a scangauge or similar monitor for peace of mind... btw the SG helped me get a much better driving ... I was driving prius for 4 years when I bought and increased my average 5-6 MPG easily not sure if it paid itself or not. Probably :)
    But there are tons of priuses in the city as cab you can ask some fellow cabbies and let us know what they average ??
    The driving technique IS the key more patience more mpg (that perhaps an oxymoron in NYC traffic)
  10. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    It all depends on your personal situation and the local traffic you drive in. My first 12 month average was 49 mpg UK which is about 41 mpg US. On a hard day shift I'd get about 46 mpg UK or 38 mpg US and the lowest daily mpg I had was in winter where it was 41 mpg UK/34 mpg US for a shift. On a run out of town I'd get from 55 mpg to 65 mpg UK (46/54 US) for a shift. On my days off I could get these right up to 75 mpg UK(62 US) but you just couldn't drive like that in the taxi world.
    I'd say your figures sound absolutely right to me. In the UK where we get many more diesel offerings and manual transmission is more popular (only because of fuel costs), I would still beat any of my taxi driver colleagues for fuel economy.
    One word of warning; keep an eye on your steering motor. I believe on the 15 inch wheels they use a different motor and it just doesn't seem to last. By 60,000 miles I was on my THIRD! All these were under warranty but at £1,500 a time it could prove expensive. If you start getting a regular judder on a fast lock to lock, then get it in asap.
    I'd also be curious how long your brake pads last. On here there are reports of people going past 100,000 miles on one set, but I only managed 30,000! Because of all the start, stop, start stop all day I'm sure they take a hammering. I guess if one just drives 100 miles a day on a motorway with little braking, you'll get them to last almost forever. I think the conditions of New York would be very similar to taxi work over here; very congested and always on your brakes.
    Update;
    I also ensure the correct 0w20 oil is used as using 5w30 reduces fuel economy significantly in town. I also found that paying extra for the LLR tyres is worthwhile as they pay for themselves in fuel economy savings. I also only changed my oil at the 10k mile intervals with no issues; the oil is still clean, the car doesn't burn any extra and sounds like new still.
  11. fuzzy1
    10,688
    Was that in an early 2010 model? I seem to remember a mid-year production change that put the higher end steering motor into all the cars.
  12. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    No it's an early gen3 purchased in Oct 2009.
    If they've corrected the steering on later models then that's good.
  13. fuzzy1
    10,688
    That would be the production I meant. On this side of the pond, the first Gen 3's appeared in May 2009, labeled as 2010s. Mine was purchased in June 2009.
    IIRC the steering change was to happened at about the same time as USB was added, which was to be about October 2009. With the pipeline delay from factory to dealer, you likely have the old version.
    Does anybody else remember any details of this change, including the timing?
  14. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I don't even remember the change, but do remember looking at a parts breakdown and seeing some countries only got the good motors from the start.
  15. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    We have a 3 model gen3 Prius range; t3, t4 and t-sipirit (Volvo own the rights to t-5). The t-3 gets the 'lesser' steering system whereas the others get the improved version. I understand the t-3 is similar spec to the Prius III sold in the US so do the I, II and III get the lesser system too?
    The gen3 was introduced here in late July 2009, but being released in 2009 was described as a 2009 rather than for the following year, hence prefering to call it a gen3 to clarify.
  16. thethought321
    Other vehicles I've used are; as stated before the 2006 town car 15/20 (not epa), regular 2010 camry 23/20, 2004 crown vic 10/17, 2008 infiniti g35s 20/25, 2009 hybrid ford escape 26/28, 2012 prius v don't know the individual averages but all together I get 41MPG. I've gone through this cars for the past three years with the same style of driving as my current prius and with relatively the same job routines.
    As for the summer heat, there has been quite a number of unbearable days but when I'm driving with a passenger @ 70F and fanspeed having two bars before the max, my MPG drops to around 29.9-32.3.
    I do most of my jobs in the Queens area, going to the city is really mostly random. There are days when I'll keep going back and forth the whole day and days when I don't even go there. All in all the time I do spend there isn't too often.
    I've about every single video there is about pulse and glide, even text tutorials and I'm pretty sure I'm doing it right because I don't have any kind of problem getting great MPG on the highway. The problem is city driving I usually never get more than 36MPG and on a good day I get 38, the twist in all of this is that I should be getting higher MPG in the city vs, highway.
    In regards to the tire pressure, I was too scared to higher it more than 40psi because on the tire it said that was the maximum. I'll try bumping up the pressure.
    I have been talking to other cab drivers, which is way I find this so strange. Even cab drivers with the same 3rd grn prius, both private and medallion. I also read the thread you suggested and that cab driver gets around 42MPG, which are around the same estimates from other prius cabbies I've talked to.
    I'm gonna try and ease up on the AC and see what happens.
    I don't most of my driving in Manhattan or Brooklyn although it's not completely insignificant for the most part my driving is in the Queens area. The funny thing is I actually get higher MPG in traffic then I would get in moderate/no traffic at all(City).
    I do spend a good time on standby but I always turn the car off, or turn of the AC and lower the windows.
    Of course it's way better than a non-hybrid taxi but I spent 21K for a pretty basic car that gets 36MPG for the most part, if I wanted that kind of mileage I would have chipped in some more money and got the V. A driver I know that has that car and almost all the time averages a solid 35MPG.
    When done with a tank it's usually 20-25MPH averaged out.
    Again obviously this car gets way better mileage than a crown vic but for the price tag I would much rather buy a V which has way more room(ideal for a taxi).
  17. fuzzy1
    10,688
    What tire make & model does it have now? I thought it can with only three different models, all rated at 44 psi. It may list a 40 psi max for seating the bead, but list a higher figure (normally 44 or 51) for the road.
    If the max really is 40, then it probably isn't the OEM tire set, so may also not be low rolling resistance.
    But your good results on the highway suggest that the tires and pressure are not the problem. And at your current pressure, adding more will make very little difference. There seems to be something in your city conditions or style that we haven't yet puzzled out.
    Codyroo likes this.
  18. szgabor
    994
    175
    Oceanside NY
    What tire you have ??? I have the original stock Yokohama Avid S33D which have 45psi cold inflation pressure listed so I am running 42.5 and 40.5 I think all stock tire has similar psi rating certainly higher then 40psi there is something 40 on the tire but that refers to something else
    I drive through Queens on Queens blvd from Van wick to the bridge both way every day ... moderated traffic in rush ours is great the lights are synced. I managed more than once from Van Dam street to the supreme court without stopping (those are the lucky days but normally I can drive many lights without stopping ) BUT after 8 pm or weekend it is on purpose out of sync then I rather go GCPW..
    Good strategy I do that when battery is low and I am stoppped at red ... no point to charge the battery if I do not need it right then and I will have power soon moving..
    That is a good speed I rarely got that you must be "quick" then my average speed more in the 15mph .... in queens/manhattan PLUS I have a good 10 miles on sunrise ... I think you can improve ... do you have a SG device ?? you would be suprised how much that helps to see MPG/load/RPM and even temps...
  19. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    not using 0w20 oil I bet. I found that using 5w30 (by accident) caused my city mpg's to fall badly. The car was hesitant when the engine did fire up and power mode made no difference.
    Are you changing oil at 5k miles and using something other than 0w20 thinking you're saving costs?
  20. thethought321
    I'll double check the tire specs in the morning (I'm too lazy to check now since it's a couple blocks away lol), but they should be OEM. I mean I practically bought this car new, I doubt the tire set was switched out.
    I suspect that the stopping and going really and IS what hurts my MPG. I live in Astoria, and there are quite a lot of stop signs and traffic lights. There really isn't any way to drive around to find long streets, on top of which over here we have everyone honking at people who aren't going more than 30-35MPH. Going from 35MPH to O constantly is drying out the battery. Which makes me curious because a fully charged battery only lasts me about 10 minutes until it recharges itself. Bad battery maybe?
    I don't which one would be the best one to buy? Money isn't a concern. Also will it read the voltage of my battery?
    Yeah I change it every 5K and on it's first oil change I actually did use a 5w30 and left it running until the 10k, after a week of using that oil I knew I messed up so I'm now using the ow20 oil.
