Prius at 11,000 feet
Discussion in 'Gen 2 Prius Main Forum' started by Ernie stires, Aug 18, 2022.
  1. Ernie stires
    Ernie stires Member
    107
    30
    Colorado
    I live In Denver Colorado and I am looking at driving West over two 10,000 passes, Loveland pass and Vail Pass on our way to Utah. While there is some down mostly, of course, I’ll be going up. My question is how does the HV battery manage long uphills like this? Will it somehow continue to provide power? Dr. Prius tells me no codes, everything within normal, typical around town driving sees me at 2-4 bars, sometimes higher. Ideas? Thanks!
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    "force charging" is your friend.
    Ernie stires likes this.
  3. Ernie stires
    Ernie stires Member
    107
    30
    Colorado
    Thanks for the reply, I’ll look that up. My question is I’m assuming my 2005 Prius, professionally reconditioned battery in 2020, with no codes and a “all good” report from Dr Prius should be ok on the trip, albeit not winning any races. Is that a fair assumption?
    52,803
    at 17 years, it could be a struggle, but there's no way ofknowing until you try. or don't
  5. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    If this is the original HV battery with matching serials, and it was reconditioned via 'grid charging' or with a hobby charger, it could be fine. If this is a replacement HV battery from a collection of random old used modules, then hard to say.
    How many miles are on the vehicle, or this "professionally reconditioned battery" ??
    Simple answer would be no. When climbing long distances, and when the HV battery SOC (state-of-charge) on the MFD (center screen) is shown to be low (2 bars or less), don't keep pushing the gas pedal expecting the vehicle to travel faster or for the HV battery to continue magically prodding along. Best to pull over (in a place that allows for easy reentry into traffic) and 'force charge' the HV battery, rinse and repeat as needed, which can be quite often, depending.
  6. fuzzy1
    10,690
    My memory from experienced other Colorado Gen2 drivers is that they simply aren't using battery power to climb those mountain passes at all. The battery just isn't big enough to be useful on those climbs, so ignore it. So just press the pedal down, all the way when needed, hold it there, and go climb strictly on ICE power. No pullovers for force charging, those simply won't last long enough to be useful.
    My Gen3 had no trouble to 13,000 feet, but it does have a larger ICE. We couldn't go to 14,000 feet that day due to snow closures, but others have been up there when the road was open. And I believe not just Gen3s, but Gen2s as well.
    jerrymildred likes this.
  7. nancytheprius
    nancytheprius Active Member
    365
    157
    iowa
    i have taken my 2006 prius with the original HV battery to breckenridge the past two summers. on the energy monitor screen the battery shows one purple bar the entire ascent. both trips was the only time i’ve ever heard the cooling fan before too. Just drive a little slower than you normally would and don’t worry too much. The high altitude makes my brakes do a little pop noise every stop too but as soon as i descended that pop went away. Enjoy the west!
  8. 9744rr
    9744rr Junior Member
    Seattle
    Four Touring
    Don't worry about the battery. You'll be using mostly your ICE and it will feel like you only have 25HP at that altitude.
  9. pasadena_commut
    pasadena_commut Senior Member
    3,030
    940
    Southern California
    On a long climb once the battery is drained I just slot in behind the trucks and crawl along. The car would probably go faster but these days I'm not in a hurry and even the longest grade I have encountered will be topped in 20 minutes or less. If I pushed the car it could be done in maybe 15 or 17, but I would rather not stress the motor or electrical components.
    Going down a long grade once the battery is full, turn on the lights, AC, stereo, and rear defroster. Of course use B mode if engine braking is needed on a steep section.
    Merkey likes this.
  10. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
    When using the Gen 2 ICE, what speed can you get after battery is exhausted and going upgrade? Are we talking 50mph or 25mph?
  11. nancytheprius
    365
    157
    iowa
    you can go 50, just take advantage of momentum when possible. and don’t overthink it
  12. fuzzy1
    10,690
    Would some Colorado Gen2 owners please chime In? I thought the experienced local folks were pretty much keeping up with traffic, even at their altitude, while the visitors were having greater troubles.
    ColoradoCrow likes this.
  13. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    HI I live in Colorado Springs. Just drive normal. The battery will run out and the ICE will run just fine. Ive driven to Breck a few times.. all good no issues.
    jerrymildred and fuzzy1 like this.
  14. Another
    1,819
    520
    Naples, Florida
    The other day I was parked using the AC and the battery was low when I started to get back on the freeway. I was surprised that I had no problems quickly getting up to 75mph on just the ICE, but it was flat terrain. I’ve never driven in the mountains.
  15. Rph74
    Rph74 Active Member
    292
    234
    Springfield,MO
    That’s pretty impressive that your original 2006 battery is still so strong!
    nancytheprius likes this.
  16. Another
    1,819
    520
    Naples, Florida
    Just a thought. When was the brake fluid last changed? Was the system bled properly?
  17. nancytheprius
    365
    157
    iowa
    dont think it was ever changed… probably overdue based on age. mileage is 98k
