Prius at 3/4 when pump stops "full"
Discussion in 'Gen 2 Prius Main Forum' started by MilkyWay, May 24, 2019.
  1. MilkyWay
    MilkyWay Active Member
    823
    359
    23
    MI
    I have done the recalibration process 10 times does nothing.
    If I kill the battery and reconnect it it will go to full but next fillup it will read 3/4s at full.
    What is problem or what could be the problem and solution?
  2. Mendel Leisk
    41,928
    Likely the gas tank bladder.
    Raytheeagle likes this.
  3. MilkyWay
    823
    359
    23
    MI
    I'm seeing entire fuel tank assembly used for $40-$100. Maybe just change whole tank?
  4. Mendel Leisk
    41,928
    The replacement will most likely be the bladder style, might be no better. There is a version used in Europe, without bladder, fwiw.
    There are some strategies I think for getting it fuller. You need to be careful though, that it doesn't burp gas back out?
  5. Graeme1949
    Graeme1949 Member
    51
    47
    Atlanta, GA
    I have found that the recalibration procedure works best if the car is on an absolutely level piece of ground, and the driver is the only person in the vehicle. (Also take out any heavy cargo.)
    I have had to do that a couple of times. The first time I had a lot of trouble until I realized they really do mean LEVEL ground, and nothing heavy in the vehicle except me. I last did the recalibration about six months ago. The first time was something like 8 to 10 years ago.
    -Graeme-
    2004 Prius with >190,000 miles.
    Sent ?.
