Prius AWD - What are the specifications?
Discussion in 'Gen 4 Prius Main Forum' started by Eug, Jan 22, 2016.
  1. Eug
    Eug Swollen Member
    956
    211
    Earth (for now)
    Technology
    Does anyone know the specs and design of the AWD in the 2016+ Prius model? I can't seem to find a good description of it. Even Wikipedia failed me here. No mention of AWD for the Prius.
    BTW, now that I know an AWD Prius exists, I'm probably less likely to buy a FWD Prius in the future. I can wait though, considering I just got a Plug-in Prius last year.
  2. Blizzard_Persona
    1,787
    944
    Pa.
    2023 Prius Prime
    XSE
  3. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    :ROFLMAO: I have that one on my tool box at work.
  4. Eug
    Eug Swollen Member
    956
    211
    Earth (for now)
    Technology
    #4 Eug, Jan 22, 2016
  5. Blizzard_Persona
    1,787
    944
    Pa.
    2023 Prius Prime
    XSE
    Japan only I believe...
  6. Eug
    Eug Swollen Member
    956
    211
    Earth (for now)
    Technology
    We know it's not coming to the US. I assume it's also not coming to Canada. do not know about Europe, but I'm guessing a no to Europe too.
    However, this does bode well for a future AWD Prius in non-Japan markets, since Japan is often a test bed before releasing to other markets.
    If those numbers are representative, and the fuel efficiency difference scales the same with real-world gas mileage, then it seems that AWD incurs a 5-6% fuel efficiency hit.
  7. Tideland Prius
    16,155
    The rear motor is pretty weak, especially compared to the one in the RAV4 Hybrid. I can see why TMS didn't bother offering it in the U.S.
    7hp, 40.5lb-ft.
    RAV4 Hybrid's 67hp rear motor (no idea what the torque measurement is)
  8. Eug
    Eug Swollen Member
    956
    211
    Earth (for now)
    Technology
    What purpose is a 7 HP rear motor?
  9. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    To get you unstuck, what purpose is two or three 0.7 HP humans? Answer, whatever works. ;)
  10. Eug
    Eug Swollen Member
    956
    211
    Earth (for now)
    Technology
    1) At what RPM is it measured, and would it be different at say 4500 rpm?
    2) IOW, how strong is it really, compared to the RAV4? The RAV4 is 67 HP / 103 ft-lb torque.
    3) If it isn't very strong, will it really get you unstuck if there is no traction on the front wheels? Or is it just a small aid for weakened traction to the front?
    I'm guessing it won't get you unstuck from a full stop if the front wheels are spinning, but it will help the front wheels maintain forward momentum that the car already has on a slippery road, or if the front wheels still have a fair amount of traction.
  11. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    7HP is far more than is needed to get a car unstuck provided the gearing is low enough.
    Unlike conventional 4WD, this rear wheel electric drive is separate from the front wheel drive. Provided the rear wheels have traction, it shouldn't matter what the front wheels are doing.
  12. Eug
    Eug Swollen Member
    956
    211
    Earth (for now)
    Technology
    I'm still having a hard time reconciling the spec difference from the RAV4 Hybrid AWD. Same setup with the independent rear electric motor, but on the RAV4 it's almost ten times the kW.
  13. energyandair
    905
    339
    Victoria BC Canada
    Different purpose I expect. Getting unstuck is one thing, climbing a rough steep muddy or snowy road where various wheels will slip as you move up the road is another. The little motor might get you there but it will be pretty slow. The RAV 4 should be able to handle that kind of use. The Prius does not have the ground clearance that is so often needed under those conditions
  14. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    I still think Toyota should have offered it as an option in the states, I would have expected it to sell well (not to be used off road, but to give an advantage in the snowy states).
  15. Eug
    Eug Swollen Member
    956
    211
    Earth (for now)
    Technology
    I wonder what the torque is for the Prius AWD's rear motor. It is supposedly 103 ft-lb for the RAV4 Hybrid.
  16. energyandair
    905
    339
    Victoria BC Canada
    I'm not so sure about that advantage. It has a lower ground clearance than the regular Prius. A photo in this forum showed the exhaust pipe ducking under the 4WD components and a cell phone leaning up against it. I suspect that the regular 2WD Prius with decent snow tires could go places this 4WD could not
  17. David Beale
    5,963
    1,981
    Edmonton Alberta
    The Prius AWD is shoehorned into the car. There is no room for the RAV4 type power range motor. The Prius eAWD system will work just fine on an icy or slightly snowy road to get you going when you otherwise would just spin the front wheels (slightly - traction control will intervene of course). Neither the Prius eAWD NOR the RAV4 eAWD system are intended for off-road use. From the owners manual. This also includes the Highlander Hybrid. And none of them work "at speed". RTFM.
    But it's a moot point, as none of us will see it, at least for the time being. It's offered because there are those in Japan who want it and are willing to pay. And pay. And pay. And to compete with the other manufacturers in Japan that Toyota's boss wanted to compete with, they had to add it.
  18. frodoz737
    4,297
    2,348
    33
    I'm still thinking Subaru if I need an AWD car...but that's me.
  19. Lee Jay
    Lee Jay Senior Member
    5,850
    4,024
    Westminster, Colorado
    I did the math in another thread but it'll provide 427 pounds of thrust at zero speed. You know how many people it would take on your rear bumper to provide that much thrust? Probably 6-8. I've pushed stuck cars out myself, and have done it many times with two people. This is plenty of power to get you unstuck or started up a slippery slope.
    This is not an off road vehicle. This motor is to help you get started, get you unstuck, and help you up places like your driveway.
    PriusC_Commuter likes this.
  20. Eug
    Eug Swollen Member
    956
    211
    Earth (for now)
    Technology
    Well in that case it would have been nice to have that option in North America.
