Prius Backup Camera Harness Wires
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Andrew19, Jan 30, 2022.
  1. Andrew19
    Andrew19 New Member
    Bay Area (California)
    So I recently purchased and tried to install an aftermarket head unit for my 2010 Prius, and I got every wire in the right place, except I can't seem to figure out where the backup camera wires connect to the harness. Does anyone know how to do this?
  2. PriusCamper
    PriusCamper Senior Member
    13,345
    5,395
    Pacific Northwest, USA
    Which aftermarket backup camera system did you buy?
  3. Andrew19
    Andrew19 New Member
    The head unit was a Sony XAV-AX1000, but all I need to figure out is where the backup camera wires connect with the pins on the harness.
  4. ChapmanF
    18,894
    If my notes on the 2010 original 7" nav unit hold, the camera connections originally were pins 21 through 24 of the L37 connector, with 22 being + power (red), 23 − power (black), 24 the composite video signal (white), and 21 being a shield over the other three.
    PriusCamper likes this.
  5. Andrew19
    Andrew19 New Member
    Apparently there is an additional harness that is required, specifically for the backup camera. So I ordered one and will see if that solves the issue.
  6. zdaughtry1
    zdaughtry1 Junior Member
    Tampa
    Which harness did you end up getting? I'm going to be wiring up my Atoto S8 this weekend (hopefully) and I was just going to try to do waht you originally suggested and basically make my own harness
