Prius base 2007
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TommySI, Apr 2, 2023.
  1. ChapmanF
    18,894
    Some shops might use those 'universal' programmable sensors, and program them with the same ID numbers the old ones had; then the car's TPMS ECU doesn't need to be told anything, because those are the same IDs it already knows.
    But one way or another, the sensor IDs and the IDs the ECU is expecting have to be the same. ;)
  2. TommySI
    TommySI Junior Member
    26
    Bronx
    I took the car to a shop an the mechanic checked the 4 sensors with a scanner; two were good, two were bad. Contacted the vendor, explained what happened and they sent two more sensors. I will replace the bad ones and see what happens.
  3. TommySI
    26
    Bronx
    Here’s a new problem, AC on a very hot day in heavy traffic did not work. I saw elsewhere that it could be due to a switch, dirty filters, lack of refrigerant, or the compressor. To my mechanic to see what we need to do to get the AC back.
    52,695
    make sure the cooling fans are coming on
  5. flim
    flim Active Member
    265
    191
    Huntington Beach, California
    2023 Prius Prime
    XSE Premium
    How much did it cost you to replace all 4 sensors?
    Toyota dealer was quoting me almost $400 for the job years ago. I never replaced them on the 2007 Prius.
  6. TommySI
    26
    Bronx
    Tire repair charges $20.00 each. Tire Rack charges $42.00 ea.
  7. TommySI
    26
    Bronx
    Sensors go for $42.00 ea. From Tire Rack. Tire repair charges $20.00 installed. Four $80.00
    flim likes this.
  8. flim
    flim Active Member
    265
    191
    2023 Prius Prime
    XSE Premium
    Thanks for the info.
  9. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    I bought a cheap 4 pack from Amazon. Chinese cheap. 1 didn’t work out of the box. boight one from Orielus. Had them replaced and never looked back. The price of not having the TMPS light on…. Worth it.
  10. TommySI
    26
    Bronx
    Anyone ever replace radiator and find a way to re install the fans? (2007 Prius base)
