Prius Battery Replacement (GenII) Like you've never seen - NEW Cylindrical Cells
Discussion in 'Gen 2 Prius Main Forum' started by 2k1Toaster, Jul 17, 2017.
  1. wrprice
    wrprice Active Member
    415
    308
    Houston, TX
    Four Touring
    My only concern, and it might have something to do with the prism shape of the original cells, is how it performs and transfers energy in a serious collision. The void resulting from the cylindrical shape and plastic clips might allow more flex in the pack than Toyota intended or that your cells would handle.
    Looks great overall, though. It's just lacking in failure mode testing.
    2k1Toaster likes this.
  2. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    In a serious collision, the pack is cutoff from the rest of the car except for at the pack itself. The main metal bars uptop as well as the metal frame below are untouched. The stock cells are not really very strong, but they require compression to not expand because of the way they are manufactured. That's why that compression is there.
    But yes very true that any modification to a vehicle can alter its crash performance as it isn't tested.
    rayluo, Fred_H and wrprice like this.
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,351
    Madison, Wisconsin
    If I get in an accident bad enough to damage the pack (Which is pretty buried in the car), I think I'll probably have many other things to worry about instead of the pack.
    rayluo, Blue Potato, Jfrench and 8 others like this.
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Zactly. An intrusion all the way to the rear seats would be such an massive impact as to be nearly unsurvivable.
  5. wrprice
    415
    308
    Houston, TX
    Four Touring
    I wouldn't be worried about the pack, either. I'd be worried about how the alterations change the flow of KINETIC energy and how that affects the dynamics of Toyota's crash-certified physical design.
  6. PeterPrius2007
    PeterPrius2007 Junior Member
    47
    Kitchener
    Very awesome. Curious: did you investigate making a new battery pack with lithium cells instead of NiMH? I guess the charge controller must be only designed for NiMH chemistry. But a lithium pack must end up being significantly lighter
    Montgomery likes this.
  7. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Very impressive! Thanks for posting! I have only 2 questions: (1) Would it work in my 2009 Gen II? (2) How would it react to being conditioned with a Hybrid Automotive Prolong Grid Charger? Thanks in advance, and apologies if those ?? have already been answered! ;)
  8. ericbecky
    4,443
    3,351
    Madison, Wisconsin
    No need to recondition a BRAND NEW battery.
    Personally, I would not hit this with a grid charger.
    Use Torque Pro app or Techstream to watch voltage over time. But hold off on charge/discharge.
  9. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    OK, I like the idea that all new cells in a new design are being tried. But, with the genuine Toyota batteries costing $2600 with a very real Toyota warranty, why would anyone be interested in a $2000 price with no warranty be appealing? $1000 seems more like the proper price.
  10. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Yes lithium would be lighter and smaller but it is a completely different animal. The project was to get brand new equivalent cells into my Prius. Panasonic will not sell you Tier 1 cells new, they only go to Toyota Motor Corp. It's sad because I have some nice Lithium Toyota cells at my work but I can't buy them :(
    But with Lithium you would need a bi-directional power board. To "translate" what the Prius requests into what you can use. Without significant custom hardware, it is not possible. It's a totally possible project, but I don't see many advantages now that you can buy EVs from a leading manufacturer. When that wasn't the case, lots of people on Priuschat including myself looked into it.
    offib and Fred_H like this.
  11. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    (1) Yes.
    (2) I don't know what it does to "condition" but if it is a standard discharge/charge/balance/repeat type conditioning there is no need to do that. These cells are brand new out of a factory. Not sitting around. There is nothing to condition. Now a few years from now, it would be the same advice that they give. Some people would prefer to have a car plugged in and balanced all the time. That's up to you to decide. I never did anything like that with my Prius, and it seemed to last a very long time under heavy abuse.
    Moving Right Along and Fred_H like this.
  12. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    You cannot even get a reconditioned late model year pack for $1000.
    If you look on eBay used pack prices go between $800 and $2000. This is a brand new pack.
    Montgomery and Fred_H like this.
  13. dolj
    dolj Senior Member
    8,604
    4,366
    Wellington, New Zealand
    Dream on Ken, you're in la la land.
  14. kenoarto
    398
    Chicago, IL
  15. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    So not for you then. But like I said, this pack has advantages over the stock pack, so it is actually an upgrade for less money. Also to get that $2150 price will require a core charge and refund.
    Also in the future, I would like the price point to be a few hundred cheaper. Right now this is bleeding edge and low volume.
  16. ericbecky
    4,443
    3,351
    Madison, Wisconsin
    There is a market for what 2K1Toaster is selling.
    It is not for everyone, but no need for others to rain on the parade. If it is not for you then move on.
    Kenoarto, *Wholesale* prices of reputable NEW batteries are no where near $1,000. So there is no way that the consumer will see $1,000 *retail* price of NEW batteries. And this is after over a decade of battery production.
    In my neck of the woods $1,000 barely gets you a 12 year old junkyard battery out of a Gen 2 Prius.
    rayluo, Montgomery and Fred_H like this.
  17. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Yep. There was a time many years ago when you could get a 2-3 year old battery at a junkyard for $200 because nobody knew what to do with it. Now that they are in demand, price is an order of magnitude more expensive. The stock cells I bought to test out my battery rebuild from a reputable seller were 8 years old and cost well over $1000.
  18. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    Our battery got bent and we walked away. I was unscathed but wife needed some neck therapy. I would NOT want to have been in the back seat.
    By the way. @TampaPrius.com, have you seen this yet? Intriguing.
    snead_c, edthefox5 and fotomoto like this.
  19. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    Higher capacity would not necessarily mean better performance.
    The computers would have to be re-programmed with different battery parameters.
    While I hope this turns out good......a LOT of what was posted sounds a lot like hollow marketing claims.
    OF COURSE the people making anything new like this will claim that it is as good as the original or better........at a fraction of the price.
    Those claims often turn out to be a bit........exaggerated.
    kenoarto likes this.
  20. Mendel Leisk
    42,048
    No cover, lots of open space around each module, this pack will stay cooler I would think.
  21. bisco
    52,532
    2k1toaster is a long time, well respected member here, with a ton of ev cars and electronic knowledge and experience.
    Jfrench, snead_c, Montgomery and 5 others like this.
  22. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Curious what you think are "hollow marketing claims". I'd love to rebut. I am an engineer, and I work with batteries and power systems on a daily basis. I sell other consumer electronic, industrial, and automotive devices that I have custom designed to both small and large businesses. In some of those I require batteries and I have contacts in a few plants that make me various types of batteries of a very high quality. I have tested packs from big-brand automotive companies and have millions of dollars worth of equipment at my disposal. Testing my old original cells plus newly refurbished cells plus newer cells in the 2013 Prius C we have, I got a pretty good idea of how these cells perform. The cells that we have produced exceed all these parameters and the like-for-like comparison puts these cells ahead of the Toyota cells. Will they last a decade like the Toyota ones? Nobody knows at this point. However the magic-8-ball says "all signs point to yes".
    In addition the mechanical and electrical design of these cells in superior that can be seen with just quick observation. I have 14 battery modules in a pack versus 28 battery modules. If any one of those faults, the entire car is inoperable. By actually pairing 2 modules into 1 larger module, you make inbalances between pairs much less likely to occur as they are all factory and production matched unlike the smaller cells that are paired way down the assembly line in pack construction. Another reason they are serialized, you know exactly where they should go and there is no chance that they get separated in production.
    In addition these cells are physically larger in cross-section, i.e. thicker/wider current paths. The internal resistance is lower compared like-to-like. Look up anything on wire gauge and it is the same principle. The wider the current channel, the lower the internal resistance. There is 1 less bus bar connection for each of the 14 modules. And that bus bar connection commonly corrodes, as it is an open air contact to a piece of metal secured by a threaded nut. That will never be as good as a welded sealed connection, it is not possible to be. And the lower the internal resistance, the lower the internal heating, the lower the overall pack heating, ergo longer life due to less heat. And that leads us to...
    And the final big one is the size and shape itself. We all know that pack-heat is one of the main killers of hybrid batteries. That's why mountainous driving and high ambient air temperature driving accelerates the aging. With the packs all squeezed together the surface area for all the heat dissipation was just the skinny side, not the large flat side for all cells except the very 2 ends in the battery sandwich. With this design there is airflow around each and every individual cell. Right there that will allow for even distribution of heat. Most Toyota packs have known failures inside the pack. Rarely do we see a failing in Block 1 or Block 14. It is always inside. My hypothesis is heat. It exacerbates the problem and there is no way to get the heat out. A cylindrical cell allows for the air gaps because of its design, it's why your pressurized tanks are all round. Instead of needing to linearly squeeze the cells, the cell casings themselves maintain the pressure required to charge and discharge without expanding.
    If you have any specific questions about what you feel are downsides in the design, I am all ears. But as an engineer in this field, I can tell you this was designed to be superior and all testing points to it being superior.
    rayluo, Blue Potato, Jfrench and 9 others like this.
