Prius Battery Replacement (GenII) Like you've never seen - NEW Cylindrical Cells
Discussion in 'Gen 2 Prius Main Forum' started by 2k1Toaster, Jul 17, 2017.
  1. George W
    George W Senior Member
    911
    514
    San Antonio
    it comes down to battery management. airlines don't use cheap batteries, but bad management has brought a jumbo jet down
    offib, TomB985 and Prodigyplace like this.
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    All sold out again. The good news is the freight truck for this months shipment is due to arrive tomorrow morning so hopefully no problems. But I have been trying to keep some holdover from month to month just in case. Guess I need to up the order size yet again. :)
    James1964, VFerdman, offib and 5 others like this.
  3. TomB985
    TomB985 Member
    137
    68
    Isanti, MN
    Just out of curiosity, how many of these packs have you sold?
  4. Absalom
    Absalom Junior Member
    42
    42
    Denver
    It’s comments like these that have me nervous to go this route.
  5. Prodigyplace
    12,526
    11,747
    Central Virginia
    Comments from @2k1Toaster could be useful.
  6. hill
    8,789
    #526 hill, Jan 22, 2019
  7. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    It's like getting a haircut and complaining that your knee hurts. Your knee probably hurts but it has nothing to do with the haircut. Just bad timing. It's not possible for a battery to do what is described. Everyone who has replaced a battery knows what happens when the battery "goes bad". Mileage drops, and eventually you get sluggish response. Before that it just charges and discharges more and more quickly. That's it. The Prius is made to work with minimal battery. If other things are happening, it's not the battery's fault. But on a 15 year old car, it may be something else.
    Prodigyplace and TomB985 like this.
  8. sidecar
    sidecar Member
    342
    45
    Australia
    ultimately theyre all done
    but the need to find the best solution for the electric car is gearing up
    the research that is now producing fruit is the supercap and ultracapictors
    not really a battery as we know it its a device that accepts a charge much much quicker, its cheaper, lighter and has no memory issues
    and the country behind is seems to be India
  9. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Supercaps have terrible memory problems and are very expensive.
  10. Figster10
    Figster10 Member
    207
    61
    Sacramento
  11. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Sure... On what?
    We have lots in stock and ready to ship.
  12. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    I wonder if you do installs. It's not a thing I want to tackle myself, but a couple days' vacation in the Rockies sounds nice in summer.
    Prodigyplace and audiodave like this.
  13. T1 Terry
    T1 Terry Active Member
    929
    478
    Hi 2k1Toaster, have you ever experimented using LiFeP04 or the LYP or LTO cells? Also, have you ever experimented with increasing the size of the traction battery capacity?
    I've been thinking about the idea of a larger traction battery that can be charged from an external source as well as the regen that is already part of the Prius operations. The reasoning behind this idea is the Prius will prioritize battery/electric drive over ICE drive if the battery is sensed to be greater than 65% SOC (I think that is the level the top green bar comes on at) so that would result in a better MPG for the period the traction battery was sensed to be at greater than 65% SOC. If the battery capacity was increased there would be a greater range provided while the battery was sensed to be higher than 65% SOC. The reason for looking at one of the above chemistries is their inherent safety and the fact they hold a reasonably constant voltage through the useable capacity.
    My PHEV 2006 gen2 Prius gets its traction battery pack topped up frequently to maintain the 65% SOC and hold around 240vdc until the plug in pack is fully discharged, the Prius computer system does not see this charge current coming in yet it still operates the way a Prius with a 65% SOC traction battery normally does, priority electric drive. It will even use electric only at 100km/h or higher as long as the load isn't too great for the electric motors.
    T1 Terry
  14. Prodigyplace
    12,526
    11,747
    Central Virginia
    Toaster works with rechargeable batteries for a living so he may have already considered those options.
    audiodave likes this.
  15. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Oh yes... One of the reasons I bought the car way back then.
    This was an extremely common technique a decade ago. The contactor style kits that just output a boosted voltage from the LiFePO4 pack into the NiMH stock pack which made the Prius just think the battery was at a high SoC all the time. And it worked great. For even better performance you tricked the car to go into OOG mode (Out of Gas) and then you'd get max power and no engine even if you stomped the pedal. This was all new and exciting pre-2010. I bought the Prius with the intention of retrofitting it into a PHEV. I worked quite a bit on decoding the CANBus in the Prius and getting the car into and out of OOG mode at the flick of a button. Did some tests with a mule pack and some custom hardware it all worked awesome. Then Nissan came out with the Leaf. In CO, for $16k you get a brand new 24KWh actual electric vehicle. You can't compete with that in your garage. So I bought a Leaf.
    The Prius is a great HEV. It's a terrible PHEV and even worse forced BEV that just carries around an extra thousand pound engine around for no reason. Back when there didn't exist any good PHEVs and only Tesla BEVs, the Prius was a good test mule and a good experimentation setup. You were one of the exerimentors. But the fact remains that using the Prius as a PHEV today is akin to the $800 rust bucket with a $10k sound system from the 1990's. You're going to take a $2k vehicle and put $10k of batteries in it to get a hacked Frankenstein style vehicle with no warranty and lots of quirks that works half as well as the commercial version you can just buy from Nissan for close to the same price. Or now, even just the PiP/Prime. There will always be someone to do it, but it is not worth it in 2019. It wasn't worth it since about 2012.
    Sorry to burst your bubble. :(
    Robert Holt, T1 Terry, Cyvan and 2 others like this.
  16. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Lol, not really. But I have done. I know some people who do.
    Some people know, I travel quite a bit. It is more rare than normal for me to actually be at my house Friday through Sunday. And during the week, if I am not travelling for other reasons I work very strange hours for all my various businesses.
  17. Prodigyplace
    12,526
    11,747
    Central Virginia
  18. T1 Terry
    929
    478
    Thanks for that reply 2k1Toaster, a clear thought path as to why it is not a practical solution these days. The new Hyundai range of all electric vehicles has certainly changed the DIY scene. It is really just a fun project these days rather than an economical thing I guess.
    Is that OOG mod the one that limits max speed to 85km/h (around 50mph) ? That is probably the "Ice Kill" mode I can select in my PHEV Prius. Still love the car though and the fact it can still drive in ICE mode if needed.
    T1 Terry
  19. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    The OOG mode doesn't limit anything itself. Because you're in D, the engine can still spin properly, there's just no fuel. So there's no over-revving problem you get when you just try to force the engine off or coast from low speed EV to higher speed which can damage the MGs and engine.
    The physical limit should be about 62mph in the Gen-2 Prius before you start revving over 10k on the MG which can cause damage. Note this was changed from Gen-1 to Gen-2 but the software wasn't, so you have to force it. The car will allow faster, and I think there are YouTube videos in the 70mph range. But it also takes a decade to get up to that speed, there just isn't enough power. You're trying to move a few thousand pound gigantic vehicle with 1950's motorcycle engine power levels.
    TomB985 likes this.
  20. T1 Terry
    929
    478
    Thank you 2k1Toaster. Is it a trade secret how to switch to the OOG mode? If not, is it something I could do myself with a bit of guidance from you?
    T1 Terry
