Prius Battery Replacement Kit (GenII/GenIII) with NEW custom cells
Discussion in 'Gen 2 Prius Main Forum' started by 2k1Toaster, Oct 13, 2017.
  1. eman08
    eman08 Active Member
    360
    192
    US
    I saw one that was taken apart as it looks like its plates stacked together.
    I did run across this company as it looks like they have been making this same kit for quite some time. NI-MH Power Technology Co.,Ltd
    Fred_H likes this.
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    As been described in this thread and other threads, the battery cells are different. It's a CEBA pack hardware and even my installation manual says just follow the CEBA videos for some extra detail. The new plastic bits, are from me that they now get to use (and are). That way I didn't have to pay for custom tooling on all the plastics. I do the mech design, they do the production and sell to others including me.
    My cells are not the same as the cells in the image. If you lok at the top of those batteries they should be stamped with "CEBA". Mine are not.
    The mechanical is the same. The chemical is different.
  3. Prodigyplace
    12,562
    11,778
    Central Virginia
    I also could not find a price for their battery pack.
    CEBA Battery likes this.
  4. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Looks like quite a deal to me. I wish I had a bad High Voltage battery to replace.
    Prodigyplace likes this.
  5. Prodigyplace
    12,562
    11,778
    Central Virginia
    I am sure somebody would let you adopt theirs, if you pay to replace it :D
    SFO likes this.
  6. Andyprius1
    2,327
    859
    Cool CA
    Adoption has problems, like, what is the state of the rest of the car ?
  7. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Everyone I have seen has been in the $870 to $1000 range advertised. I posted a photo of my CEBA invoice earlier for the pack I tested a while back. By the time it was shipped, custom duties, custom fees, bank wire transfer fees, transaction fess (5%!!!), etc it was over $1500 shipped to my commercial address.
    Fred_H likes this.
  8. Prodigyplace
    12,562
    11,778
    Central Virginia
    Are your cells higher capacity than CEBA?
    Fred_H likes this.
  9. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Mine say 6.5Ah and are measured 6.5Ah. The ones I got in my CEBA pack said 6.5Ah and I measured on average 3Ah. Using very generous slow testing methods, I got up to 4.5Ah, but using the same tests mine says 8Ah...
    Fred_H and Prodigyplace like this.
  10. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Also for comparison, my original cells (2006 Prius pulled originally around 138k miles in 2016 and then left to sit for over a year in my basement) measured between 2.6Ah and 3Ah
  11. eman08
    360
    192
    US
    Everything looks identically the same to me as I'm not sure what you actually mean by what you actually designed, regardless of the cell manufacture was used since they are all Chinese suppliers. Am I missing something? What part did you design?
    kenoarto likes this.
  12. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    The quote I got two days ago was $1050 for the kit plus $375 for all the shipping, duties and fees = $1425. If bought in groups of 5, the shipping goes down by $200 per unit = $1200.
  13. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    That sounds about right. But when UPS knocks on your door to deliver you will need to write them a cheque for customs brokerage fees and potentially extra shipping charges unless you have a commercial ups account with enough volume to where they waive some fees. In my case the brokerage fees they asked for were $33 before I put the charge on my account.
  14. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    If you look at a photo from last year of any of the kits they look nothing like that. There's a reason why...
    Also if you believe that everything manufactured within the same area is identical just because, I can't help you. China like every developed country is full of factories that will make what you want. If you want the lowest cost something, they will oblige. If you want something that meets certain requirements, they can do that too. The important part of a Prius battery pack is the battery. Mine, stamped with VERG ontop, are actual 6.5Ah cylindrical modules with 12 point welds between cells. Unlike the cells used in the other kits that are stamped 6.5Ah but are truthfully half that with random welds just to hold it together.
    SFO and Prodigyplace like this.
  15. SpaceCityHybrids
    38
    52
    Houston
    Received shipment today by a wet UPS and visibly irritated driver. Will try to install later and post results when it dries up.
  16. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Let me know if you need any install pointers. The only confusing part (I think) is what orientation for the modules. For a Gen-2, module #14 goes close to the electronics, and it counts in descending order to the end of the pack with module 01.
    Here is the interim manual: http://www.newpriusbatteries.com/Installation%20Manual/Installation_Manual_001B-WM.pdf
    The long original wire from the Prius is connected to the (-) terminal of the new cells and the shorter original wire from the Prius is connected to the (+) terminal of the new cells (close to electronics).
    This is the manual with the both the old plastic style pictures and new ones: http://www.newpriusbatteries.com/Installation%20Manual/Installation_Manual_001B-WM.pdf
    On page #47, you can see the modules lined up and the safety interconnect switch making contact on the third and fourth modules. Also that's the side with the 7-x sensors and the 8-x goes on the other side.
  17. notamechanic
    notamechanic New Member
    NYC
    Long time lurker here and I have a gen 3 in the process of installing the replacement.
    Am I missing something or does the wiring harness that comes with the cylindrical cells not fit the electronics section of the battery assembly of a gen 3? I attached an image which shows the original on the right and the replacement on the left. Could I use the original wiring harness on the cylindrical cells assuming the original is working properly? I read through the interim manual and I think the images show the battery electronics for a gen 2. I'll anxiously be awaiting a response and thanks for enabling this whole experiment in the first place :)
  18. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    There is definitely a different harness to the Gen-3 than Gen-2. I may have mistakenly shipped you a Gen-2 kit. I sent you a PM, lets get this sorted! :)
  19. Fredsimm
    Fredsimm Active Member
    188
    117
    Tupelo MS
    I'm lazy and don't want to read the last 10 pages, plus new info is more accurate than the previous posts. How many people here are actually using the new cells currently? And if possible the current status of your performance thus far. Any complaints no matter how small are much appreciated. And of course the praise is also helpful to us undecided lurkers. 2k1toaster's comments are also wanted also.
  20. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    There are a couple dozen in the US so far, of those I believe 8-10 are (active) PriusChat members.
    Everybody that has reported anything, has been unanimous in that it works like new and other than that boringly the same. Boring is good in this case. It means it does what it should, as it should.
    My complaint would be my factory takes too long to make, assemble, and test them! But so be it for good quality cells. :)
    As far as I know, nobody that has the pack has had an issue with it. One member (above) I accidentally sent a Gen-2 wiring harness to instead of a Gen-3 harness. I UPS Overnighted a brand new Gen-3 harness to them at my cost including a return label to send back the other harness also at my cost. So far, that's been the biggest problem I am aware of.
    The only other downside right now, is that there is no user manual. It is still in the drawing phase, expected to be first draft ready by mid-January. Printing and shipping puts the actual manuals around mid-February at the earliest. The thing with production, is that everything is on the timescale of months.
    But there is a post above (#196) that has all the basic information plus a cobbled together interim manual.
