Prius Battery Replacement Kit (GenII/GenIII) with NEW custom cells
Discussion in 'Gen 2 Prius Main Forum' started by 2k1Toaster, Oct 13, 2017.
  1. Prodigyplace
    12,547
    11,771
    Central Virginia
    I think you meant to reply to @ericbecky
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,431
    3,304
    Madison, Wisconsin
    I meant the Delta SOC when chosen from drop down menu in Torque does not display correctly. Perhaps it needs to be modified or adjusted. No big deal. Not that important for most of my uses.
    Raytheeagle likes this.
  3. Fredsimm
    Fredsimm Active Member
    188
    117
    Tupelo MS
    So, the oem pack has 14 modules containing 2 cells each I think. 2k1toaster pack has 7 with each containing 4 cells. Does the Prius computer and torque app still read them the same?
  4. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Not quite.
    The OEM pack has 28 modules containing 6 cells a piece. The Prius arranges this into 14 "blocks" that it monitors.
    My pack (like the CEBA pack that pioneered this form-factor) has 14 modules containing 12 cells a piece. The Prius also arranges this to 14 blocks, except in this case each block is a single module versus 2 modules making up a single block in the original design.
    This means the Prius treats it exactly the same.
    Robert Holt and Prodigyplace like this.
  5. ericbecky
    4,431
    3,304
    Madison, Wisconsin
    3000 miles on the pack since October.
    Nothing to report.
    Been driving with an extra transmission in stored in the hatch.
    Mpg same as always.
    <shrugs shoulders >
  6. Prodigyplace
    12,547
    11,771
    Central Virginia
    Many people carry a spare tire.
    Just sayin' :D
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    Geez, I thought keeping a few extra tools in the car would help me be ready for just about anything. I got nothin' on this.
  8. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Soon you'll just pull an entire Prius filled with extra packs and transmissions behind your driving-Prius for any spare part you may need!
  9. ericbecky
    4,431
    3,304
    Madison, Wisconsin
    This one is for a Honda Insight. Pretty sure it ain't going to work in the Prius.
  10. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    With enough dedication, it'll work. :D
    Raytheeagle and Prodigyplace like this.
  11. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    How much mpg are you getting with your prius, and this battery?
  12. Fredsimm
    188
    117
    Tupelo MS
    You never know when you're gonna need one.
  13. ericbecky
    4,431
    3,304
    Madison, Wisconsin
    The battery isn't really there to modify the gas mileage. It's the same as it ever was as far as I can tell. Buy to be honest I don't really pay much attention.
    This is my work Prius so there are times where it may sit powered on idling but not moving for long periods of time.
    Plus it is cold Wisconsin winter right now.
    My trips can range from high 30's to high 50's depending on the day. For instance, my drive home last night was 57 mpg. Last week the tank was at 42 mpg, but by the time I went to fill up I had hammered it down to 38 mpg due to idling with the heat on.
    Overall I'd say it is in line with my other two Prius, given the offset for extra idling, etc.
    2k1Toaster, mjoo, Raytheeagle and 2 others like this.
  14. gamma742
    gamma742 Member
    178
    73
    Luxury
    @epoch_time
    Would the Nimh volt Delta give the same information that we are looking to glean from these two gauges?
    Thanks~
    Prodigyplace likes this.
  15. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Just an FYI, 4 packs still unclaimed from this next shipment due to arrive that first week of January.
    Raytheeagle and m.wynn like this.
  16. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    And a big hammer. And maybe a sawz-all. That makes everything fit. ;)
  17. Prodigyplace
    12,547
    11,771
    Central Virginia
    Are you planning a Gen 1 Kit? I have seen a few use cases lately.
  18. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Nope. Technically it exists. CEBA makes the plastics for a Gen 1 kit already. But there's a double whammy in favour of the Toyota kit. The Gen 1 battery from Toyota is cheaper than the Gen2/Gen3 off the bat and it contains more modules. Meaning to buy a kit with my batteries, you'd end up paying the same amount after core refund. Just isn't worth it unless you want to try something new.
    kenoarto and Prodigyplace like this.
  19. ericbecky
    4,431
    3,304
    Madison, Wisconsin
    Delta SOC is not a voltage measurement.
    While not technically correct, think of it as a measure of the variability of the SOC. Large, quick swings in SOC is bad.
    A good rule of thumb is Delta SOC less than 20.
  20. Prodigyplace
    12,547
    11,771
    Central Virginia
    One reason I asked is in Private Sales somebody has listed a Gen 1 to part out but says they will sell it whole for $250. It needs a battery, among other things.
    For Sale - 2001 Prius Part-Out | PriusChat
