Prius Battery Replacement Kit (GenII/GenIII) with NEW custom cells
Discussion in 'Gen 2 Prius Main Forum' started by 2k1Toaster, Oct 13, 2017.
  1. gamma742
    gamma742 Member
    178
    73
    Luxury
    I'm not sure that answers my question??? SOC ??? Where did that come from?
    I was asking if 'HVB Min V' and 'HVB Max V' were both being compared by the 'Nimh volt Delta'
    Please bear with me.. I'm very new to this sort of stuff.
    I am trying to verify if my HV Battery in nearing end of life. Somewhere I got the notion that if your HV Battery Blocks 1-14 ever get over 1 V out of balance from the rest, it will throw a code, 'Triangle of Death' and a few other warnings. This Nimh Volt Delta looks as though it may show if this happens. The Needle doesn't help much because it's always moving about but it leaves a amber arrow of the lowest occurrence and the red arrow with the highest. The main focus is on the Round Dial type gauge.. The "Internal Resistance" screen doesn't seem to tell me anything.. or does it?
    Screenshot_2017-12-28-13-28-31.png Screenshot_2017-12-28-12-53-44.png Screenshot_2017-12-27-15-39-36.png Screenshot_2017-12-20-12-11-41.png
  2. gamma742
    gamma742 Member
    178
    73
    Luxury
    1st Pic,, I'm just driving normally.
    2nd Pic,, Heavy Braking
    3rd Pic,, I floored the accelerator.
    4th Pic,, Internal Resistance.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    Your photos do not match what you are saying. They show a current of zero for normal driving (fairly normal), and around 1.5 amps for heavy braking and heavy acceleration. Heavy braking should be around 60-100 amps peak regen and heavy accel should be 120+ amps peak. Heavy braking will show a voltage around 19 and heavy accel should show around 13 volts. I guess it depends on what you consider heavy.
    But, going by the numbers you show, I don't see anything you need to worry about currently. A bad module will typically show up on the IR as a higher value. If you see one module starting to diverge higher from the others, that's when you should start worrying. Like if one of the was a 0.029 or 0.031, it would be a good indicator that block has a module that is going to be an issue.
    SFO, SpaceCityHybrids and gamma742 like this.
  4. alaa al abki
    alaa al abki Junior Member
    2002 Prius
    I
    Yes this is true. To make sure from the battery and to know how much the different between the highest model and the lowest model put the car on the N position and then turn on the AC until the battery is full discharged you will hear a sound that mean the battery is low charge then take screen shot and but car in P position to charge .
    gamma742 likes this.
  5. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,351
    Madison, Wisconsin
    My mistake. I thought you were incorrectly referencing my discussion of Delta SOC. So my reply was answering a different question than what you asked
  6. epoch_time
    epoch_time Active Member
    236
    110
    las vegas
    Gamma your hv battery looks fine to me.
    Practically identical to my 2009 prius (hv battery) with 95k miles (i'm expecting at least twice that many miles).
    nimh-delta is the difference in max and min module voltages.
    Ericbecky is talking about something entirely different (soc delta). It's not the same a nimh delta..
    I've been monitoring nimh-delta for many years. I'm not sure if the math for nimh-delta is correct it could be showing .1 volt/units instead of volts. It's my understanding also that a 1 volt delta will set codes/alarms.
    My 2009 has displayed nimh of 1.5 units (peak) many hundreds of times (mostly in summer months) and never set any codes/alarms. nimh-delta is good reference but may not be accurate in unit-volts?
    But internal cell resistance IR is a better reference to cell capacity.
    As long as your IR's are somewhat equal your true nimh-delta will always be within tolerance and not set any codes.
    The strange thing about nimh-delta on my 2009 prius is that it peaks on 90 degree turns in the city.
    And I always take turns slowly. Nimh-delta never peaks with peak current from regen braking or hard acceleration (amp-loads).
    Nimh only peaks (on my prius) with practically no load and only while turning corners and i drive slow.
    Gamma If you could check your nimh-dela for similar or different results I would be interested in your results.
    SFO and gamma742 like this.
  7. gamma742
    gamma742 Member
    178
    73
    Luxury
    Yes I know, I was only focused on the Yellow and Red arrows on the 'Nimh volt Delta' Sorry for the confusion. When I Shapped the Screen Shot, I was stopped.
    Thanks for your reply.. I will check for the peak in the 90* turn for you. I won't be able to screen shot the info but I understand what you are looking for.
    That's good news, that my car looks similar to yours. It spent it's life in Houston, TX until 3 years ago when I acquired it with 86K miles. It now has 117K miles and has an easier life here in San Diego temperature wise. My concern is that it is spending more time in the Green than usual (around 7 bars) it will make it to 8 green bars on a 100-150 drop in elevation when coming to a stop. As with before, maybe 6 months ago, I didn't make it into the Green as much and almost never went full (8 Green Bars). So I figured the battery was getting weak and I should consider either a Grid Charger or these new custom cells.
  8. gamma742
    gamma742 Member
    178
    73
    Luxury
    I was unable to duplicate your problem making right or left turns.
  9. SpaceCityHybrids
    38
    52
    Houston
    Brief update
    750 miles. No issues. 41 MPG. Two 130 mile+ road trips and 2 bouts of freezing during this time.
    WHCSC, Prodigyplace and Raytheeagle like this.
  10. Larryy
    Larryy Active Member
    104
    113
    florida
    I'll take one. Email me la***a@****
    #310 Larryy, Jan 12, 2018
    SFO likes this.
  11. Prodigyplace
    12,626
    11,808
    Central Virginia
    You can either PM him or follow the link in my signature to his website.
    #311 Prodigyplace, Jan 12, 2018
  12. dolj
    dolj Senior Member
    8,522
    4,324
    Wellington, New Zealand
    You shouldn't post your personal email (or any other personal details) in a public forum. Sure fire way to end up on an email spam list. Use "Start a Conversation" (to the left under the user's username) to speak privately to the user.
    #312 dolj, Jan 12, 2018
    Prodigyplace likes this.
  13. ericbecky
    4,443
    3,351
    Madison, Wisconsin
    Good advice dolj.
    For me, my business phone and email are already all over the web so I don't worry about it any more.
    I let Jolly Roger phone company handle all my telemarketing and spam calls.
  14. Jaystation
    Jaystation New Member
    Asheville, NC USA
  15. Fredsimm
    Fredsimm Active Member
    188
    117
    Tupelo MS
    Status anyone? Those with 2k1toaster kits chime in please.
  16. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Nothing much to report. It just works. Battery level seems to be in the green or high blue area a lot more than I remember.
  17. Fredsimm
    188
    117
    Tupelo MS
    Thanks. Glad they are functioning as intended.
  18. ericbecky
    4,443
    3,351
    Madison, Wisconsin
    Nothing to report. Worked fine while installed.
    Removed unit at 4000 miles and 3 months.
    Sold car and bought a replacement 2008 Prius that had only 50,000. That car was a daily driver that went short distance daily so the pack was still fine.
    The cylindrical pack is in storage.
  19. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    How many miles did you get Rob on the orig?
    I have been supportive of 2K1's batt from the outset (looks like some of the earlier posts in the thread are gone now). So I restate that if a Prius is going to be the best green car, we need to stretch the longevity of the cars, so this does that.
  20. SpaceCityHybrids
    38
    52
    Houston
    1500 miles here, nothing to report. Operates just fine.
    m.wynn, Raytheeagle and Prodigyplace like this.
