Prius Battery Replacement Kit (GenII/GenIII) with NEW custom cells
Discussion in 'Gen 2 Prius Main Forum' started by 2k1Toaster, Oct 13, 2017.
  1. waheed
    waheed Junior Member
    17
    jordan
    .13V difference that is great result, but what is the time from SOC 80% to 32% ?
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,351
    Madison, Wisconsin
    That's hard because it will vary a bit by load. A/C cycling on/off compared to running full blast for example.
    How long do you think it should take?
    I'll try to plan my time accordingly.
    Anything else you want to know before I do it?
  3. Overworked9000
    Overworked9000 Junior Member
    47
    US and A
    This is a small measure, but that seems to be within specification. It's rather difficult to discern anything. Only time will tell if they hold up.
    I think people want to know how do they maintain SOC from your own perspective. Anything much different from OEM? Accelerates the same, etc?
    kenoarto likes this.
  4. ericbecky
    4,443
    3,351
    Madison, Wisconsin
    Now have 300 miles on the battery pack.
    Took time to re-run the seat-of-the-pants test.
    Parameters:
    First, force charge car to 80%SOC (Parking brake on. Car in D, foot on accelerator, foot on brake)
    Then immediately begin test
    Car in Ready.
    Parking brake on.
    Transmission in Neutral.
    A/C on with fan on HI.
    Temperature set to MAX COLD.
    Front defroster and rear defogger on.
    45 degrees F outside temperature
    Allow car to drain the pack down to 32% SOC
    Voltage info at start of test:
    Highest battery block 17.86v
    Lowest battery block 17.65v
    0.21v difference
    Voltage info at end of test:
    Highest battery block 15.01v
    Lowest battery block 14.93v
    0.08v difference
    Elapsed time: 38 minutes
    Start: 11:10am
    End: 11:48am
    I did not have the headlights on this time, in order to remove the variation between HID and standard headlights.
    #64 ericbecky, Oct 25, 2017
    Fred_H, m.wynn and Prodigyplace like this.
  5. ThatOnePrius
    ThatOnePrius Junior Member
    23
    Central Texas
    I went ahead and ordered the kit. I'm getting the triangle of death and it's showing #9 module is bad. I'm looking forward to receiving the kit soon.
    I could have bought a used module and got the car going again, but would be replacing another one and another one ect months down the line. I'm taking a change on this new technology pack but it should work just fine and hopefully last a long time.
    Fred_H, fotomoto and Raytheeagle like this.
  6. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Clarification, is the elapsed time included the force charge or is it just the discharge cycle?
  7. ericbecky
    4,443
    3,351
    Madison, Wisconsin
    Good question.
    Just the discharge.
    I'll go back and make an edit.
    Edit: Or no I won't. Hasn't even been 24 hours, but seems editing option is no longer available.
  8. fotomoto
    5,639
    3,815
    So. Texas
    Just before calling it quits with my original battery, I did a stress test on it to see if it would throw more codes before making a long trip. So, I was more concerned about watching for dash lights than timing it but IIRC mine lasted about 15 minutes but that was also in a hot garage in July with headlights on (default setting) so apples to oranges.
    I'd like to try this again with the new pack but I'll have to wait a few months (Jan?) before getting 45f temps during the day. HAH!!!
  9. ericbecky
    4,443
    3,351
    Madison, Wisconsin
    Yeah. It's not a great test. But I had some folks ask me offline to do this so I thought I'd share the results publicly.
    Basically the car drives as it should and modules all play well with each other when driving.
    Not really much to report. <shrugs shoulders>. Which is a good thing I suppose.
    #69 ericbecky, Oct 26, 2017
    kenoarto, Raytheeagle and m.wynn like this.
  10. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Excellent test and thankyou for posting the results.
  11. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    That's exactly what I'd hope. :D
  12. Fredsimm
    Fredsimm Active Member
    188
    117
    Tupelo MS
    Thanks for the updates. Watching your journey closely.
  13. ericbecky
    4,443
    3,351
    Madison, Wisconsin
    Now is 400 miles since install.
    Nothing to report.
    Added a screenshot from Torque that shows block voltage, etc.
    05PreeUs, hill, Raytheeagle and 4 others like this.
  14. waheed
    17
    jordan
    38 min I think that's excellent time! Thanks for your test and effort
  15. hill
    8,979
    EB remember what most businesses post.
    "We reserve the right to refuse service to anyone"
    just sayin' ....
  16. Prodigyplace
    12,699
    11,841
    Central Virginia
    Unfortunately, that is not how it works in today's society. Somebody just needs to yell "discrimination!"
  17. benkhanobi
    benkhanobi Member
    123
    50
    SW Florida
    Glad to see an alternative battery swap, which could lead to better battery swap prices from Toyota dealers. When they have you over a barrel, the dealers could soak you.
    Moonpie likes this.
  18. ericbecky
    4,443
    3,351
    Madison, Wisconsin
    Aftermarket batteries have been available for Honda hybrids for many years. It has had little if any impact on the price of OEM batteries.
    Raytheeagle and Prodigyplace like this.
  19. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    The wholesale cost of a NiMh battery is about $500/kwh, Gen 2 HV batteries are about 1.3kwh as I recall, making the wholesale cost just under $1k. Since you *can* purchase a new HV battery for ~$2k and taking into consideration distribution costs and a fair profit, they are not WAY out-of-line.
    As you correctly point out however, there are some dealers that soak their customers, but that applies even to a water pump.
  20. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    On the road again!
    Just finished installing my new battery kit. A few pics...
    View from inside sliding the old battery up a board
    One new battery module installed
    Half done installing modules
    Well, that's it for the picture show. Installation is complete and I've got a grand total of 26 miles on the new battery. The MFD display started low, and quickly went to 7 green bars. Stayed there for the first 15 miles or so. Guess the battery ECU didn't know what to do with all that capacity. It seems to have adjusted to the new cells now. The display is in the high blue bars area now.
    Oh, and the triangle of death is off!
    toymo, gptx, bwilson4web and 9 others like this.
