Prius Battery Replacement Kit (GenII/GenIII) with NEW custom cells
Discussion in 'Gen 2 Prius Main Forum' started by 2k1Toaster, Oct 13, 2017.
  1. Tim Jones
    Tim Jones Senior Member
    1,753
    564
    SE Texas
    2011 Nissan LEAF
    Is that a Gen 2?
  2. George W
    George W Senior Member
    911
    514
    San Antonio
  3. Cobra3365
    Cobra3365 New Member
    New jersey
    I would go that route, but I have to cut all the voltage wires and splice all 20 of them into the original ECU harness connector. I can easily do that but trying to feel out my options before removing the harness connector.
  4. George W
    911
    514
    San Antonio
    Not sure if it's mentioned earlier in this thread, but if you go with cylinder batteries from 2K 1 toaster, he provides you a complete harness
  5. dolj
    dolj Senior Member
    8,391
    4,271
    Wellington, New Zealand
    If you have been following Cobra's posts, you will see he does not have a Prius, he has an Escalade. Therefore he needs 40 modules and 2k1toaser does not do a harness for the Escalade.
    Mavi and Tim Jones like this.
  6. Tim Jones
    1,753
    564
    SE Texas
    2011 Nissan LEAF
    I do remember now..... I read to many posts...... : )
  7. donbright
    donbright Active Member
    241
    151
    33
    oklahoma
    My 21ktoaster / NPB are 5 months in, 4500 miles, rock solid so far. I have been collecting data on it here Priscope
    Installation hint: if you fold your floor cover over itself, doubled over, and lay it across the spare tire hole, it will allow you to slide the battery out pretty good. Take care though.
  8. George W
    911
    514
    San Antonio
    I wish I knew how to interpret the data of those samples.
  9. donbright
    241
    151
    33
    oklahoma
    The main data i have been looking at is the temperatures and voltages of the Cylindrical batteries, then looking through these forums seeing what types of numbers Prismatic systems have. So far everything seems in roughly the same ballpark (disclaimer i likely have confirmation bias and i havent done any kind of rigorous study). Over the long term hopefully it can be compared with data from Prismatic systems to see if there is any measurable difference.
    Robert Holt and George W like this.
  10. eddieSoCal
    eddieSoCal New Member
    Chula Vista, California
    2005 prius with 160k miles. Replaced with newpriusbatteries set. Installed this past Thursday. At about 70 miles in, the red triangle came on and I limped home. Check the scanner and says code P3017, battery block 7 becomes weak. Any one else experience this?
  11. Tim Jones
    1,753
    564
    SE Texas
    2011 Nissan LEAF
    got 30,000 on mine......
    kenoarto likes this.
  12. dolj
    dolj Senior Member
    8,391
    4,271
    I have haven't heard of anybody reporting a similar experience.
    Your first port of call should be to newpriusbatteries.com.
    You should also double-check all your work, including checking that all bus bars are tightened to the correct torque using a torque wrench and that all sense wires are correctly connected.
    Let us know what you find out.
    ZBrink, Tim Jones, R-P and 1 other person like this.
  13. R-P
    R-P Active Member
    804
    288
    Netherlands
    Not to question your installment skills, but as Dolj said, I'd check all connections thoroughly first. A wrongly threaded or untorqued nut would be my first suspect.
    If everything is installed and torqued correctly, I'd obviously take this up with 2k1Toaster via official channels. If there really is a problem with block7 he has some work to do in finding where things went wrong in his supply chain, not to mention making things right with you.
    ZBrink, kenoarto and Tim Jones like this.
  14. eddieSoCal
    Thanks for the tips. I DID find some nuts not fully tightened down on the wiring connectors ending in odd numbers V7, V9, etc.
    I’m a DIYer also tired of the ‘whack-a-mole’ hijinx replacing singular cells. I’ll report back on the progress...
  15. ericbecky
    ericbecky Hybrid Battery Hero
    4,385
    3,250
    Madison, Wisconsin
    This is a great example of why it is important to have the right tools for this job.
    It is important to use an inch-pound torque wrench to properly tighten the battery module and contactor connections. Do not guess.
    donbright, YAWP, 2k1Toaster and 5 others like this.
  16. swoll001
    swoll001 Junior Member
    Dania
    Where can i buy these new batteries. it seems the old website doesnt work.
  17. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    offib, Prodigyplace and Tim Jones like this.
  18. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    The website should work, but this website (PriusChat) likes to make links to things automatically. And those links don't point to anything so look broken. If you just type in the website name or google it, it should pop right up.
    YAWP and Tim Jones like this.
  19. dpower
    dpower Member
    98
    48
    Katy Tx
    I just checked and the website is working.
  20. Prodigyplace
    12,488
    11,731
    Central Virginia
    How is stock? You still getting shipments?
