Prius Battery Replacement Kit (GenII/GenIII) with NEW custom cells
Discussion in 'Gen 2 Prius Main Forum' started by 2k1Toaster, Oct 13, 2017.
  1. bwilson4web
    16,424
    Late to the party, this is a terrific solution. Your models are the same as two, 7.2V modules tied together but with the advantage of much more surface area. Heat is the enemy and this solution suggests a much improved cooling flow.
    There are three temperature sensors in the OEM battery pack. Where do they go on this pack?
    Are there any intra-module, baffles to ensure the cooling air passes by all three cell strings?
    For @ericbecky, given past heat issues, I would recommend a through heat stress test in the future. It doesn't take high ambient temperatures but doing high-speed, maximum acceleration up and down a reasonably tall, steep hill and turning around and descending in "D". The hill climb will bring the SOC down and the descent in "D" will put a charge back in, the exothermic event. It is called 'heat pumping' and puts the maximum stress on the battery.
    I would recommend using something like TechStream to record the battery temperatures. If @2k1Toaster can point you to the cell data sheet, you can track the temperatures against the cell rating. It helps if the cooling fan comes on as a 'stopping point.'
    In an ideal world, every stick would be instrumented but that can be expensive. As a workaround, a non-contact, IR thermometer would work. Just have the top cover loosely attached so it can be quickly pulled. Heat pump the pack and then scan the sticks looking for the hot spot. Rig up a cell phone video recording on a duct-tape and sticks fixture and survey the pack.
    Kudos for the design and approach. Well done!
    depriusoto likes this.
  2. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Eric! Those pictures are cool. The deltas between individual blocks is just so tight. Nice one there.
    Can you make a graphic presentation using ithe tech stream or the hybrid assist app you're using?
  3. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Thankyou again for reporting back!
  4. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Same locations as the original pack. If you look at the blue-ish plastic rings, those accept the original temp sensors and then snap onto the cylindrical cell.
    No. But there is space between all the cells and then all the modules. No custom air directing baffles though.
    Where I live this is called "everyday driving". Go up and down 2000ft "hills" just to go home and out again. Pedal to the metal accelerations to merge into 85mph traffic on a short ramp. All this testing has been done. The fan comes on when the pack gets hot. With the original pack, the fan always came on. With this pack, I don't notice it nearly as often. But after some high speed mountain driving, it is on.
    All of this was done. Using a Fluke IR meter with video overlay both in the vehicle and on the bench. :)
    Thankyou, hopefully this keeps many Prii alive on the roads for much longer.
  5. Prodigyplace
    12,699
    11,841
    Central Virginia
    Are you limiting your speed due to the battery or something else?
  6. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,351
    Madison, Wisconsin
    No reason other than I'm just not much of a speeder and the roads I commute on have lower speed limits. Generally speed limit of 55 or 45.
    Occasionally I'll do some interstate driving. There the speed limit is 70. And you will generally see me in the right lane because... Well... I don't generally feel a need to go beyond the speed limit.
    Prodigyplace and Raytheeagle like this.
  7. offib
    offib Member
    162
    96
    Dublin
    Four Touring
    I know I'm being greedy here, but theoretically speaking, if there was a 2.0 version of these cells that would be able to have noticeably more Amp Hours or capacity, would that mess with the BMS and ECUs of the car - or would it be a viable way to improve our cars? Of which for the most part modding is incredibly restrictive outside of chassis and suspension.
    A man can dream, right?
    Prodigyplace likes this.
  8. Overworked9000
    Overworked9000 Junior Member
    47
    US and A
    The Prius ECU simply doesn’t care. It follows the same W-hr discharge and charge capacity range no matter the ability to go beyond that.
    offib likes this.
  9. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    I think that might be because of the battery chemistry(NIMH), or what?
    What then happens if its a Li-ion? Won't there be some impacts on the electronics? Aren't there a certain voltage/amp-hr thresholds for the BMS, etc?
  10. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    On the sidelones, is the voltage capacity of the newly installed pack motr than the stock one? What happens to the battery ECU, and all that? Can the hybrid system cope with the increased voltages and amp-hrs? I do know, more juice, equates to more range.
  11. Prodigyplace
    12,699
    11,841
    Central Virginia
    It is usually not good to change or mix battery chemistries. The charger is designed for a particular battery chemistry. Getting it wrong can let the magic fire & smoke out. :eek:
  12. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    I'm referring to the newly installed NIMH cylindrical modules.
    Is the newly designed pack of the same total voltage(301..volts) as the stock prismatic pack that was removed from the car? That's my concern
  13. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Yes they are identical.
    Nominal NiMH cells are 1.2v.
    There are 6 cells in each OE prismatic module, 28 modules in the vehicle: 1.2v * 6 * 28 = 201.6v
    There are 12 cells in each of these cylindrical modules, 14 modules in the vehicle = 1.2 * 12 * 14 = 201.6v
    The Prius will let the magic smoke out if you put 300v through the HV system.
  14. Prodigyplace
    12,699
    11,841
    Central Virginia
    Do you think you can mix your new modules along with OEM ones for those who like to play "Whack-a-mole"?
  15. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    You would need to replace a minimum of 4 OE modules with 2 of my modules to get the bus bars and wiring to line up in the first place. Also the problem with whack-a-mole in the modules is that you are taking a module with a different capacity from the rest of the pack and trying to make it play nice. Either it will be weaker than the rest or stronger than the rest. The Prius really doesn't care about overall capacity. Packs with 20% or less original capacity still deliver 50mpg to the user. The Prius really really really cares about mismatch. That's where codes get thrown.
    Putting a brand new full capacity module (or 2) in a pack that is degraded for more than a couple years, you are asking for trouble.
    So like most answers, yes it is possible. No it is not recommended. Also I don't currently sell individual modules, only the full kit. Partly to prevent this. :)
    toymo and Prodigyplace like this.
  16. Mendel Leisk
    42,052
    Could you sell/ship to customers in Canada?
    Raytheeagle and Prodigyplace like this.
  17. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Yes, on the website if you are outside of the CONUS it will automatically add UPS shipping. It's a 70lb 24x12x12 box. But as most of us Canadians know, shipping to a UPS store to hold for pickup right across the border is usually much cheaper than shipping it an hour across the border.
    Mendel Leisk and Prodigyplace like this.
  18. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Thanks for the reply. That was what I was thinking. Thought you had more cells in there, than the stock HV battery pack.
  19. voltech444
    voltech444 Junior Member
    28
    37
    Pontiac, MI
    Hey everyone, I haven't posted on here in a while. I have been doing mobile H/EV repairs for 2 years (10 years on ICE vehicles) and I am opening a shop December 1st. that only works on H/EV. I am very happy to see that someone has finally made this happen and I am very hopeful that it works well. I really hope this works because I have numerous customers every month that need packs installed and new OEM packs are just too expensive; it basically financially totals the vehicle. I will be ordering one of these for a gen 2 to experiment with. If all goes good you can count me in on this. Right now I get at least 5 inquiries per month for pack replacement. I rebuild packs but i've been looking for a good new module replacement for a while.
  20. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    That sounds excellent.
    If or when you work out a business model for installing these kits into customer vehicles, some people on here have been curious to know details. The basic question being how much would a shop charge to do such work versus a straight-up whole-pack replacement.
    Feel free to PM/Email me with any questions.
