Prius Battery Replacement Kit (GenII/GenIII) with NEW custom cells
Discussion in 'Gen 2 Prius Main Forum' started by 2k1Toaster, Oct 13, 2017.
  1. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    About 10 years?
    toymo, Prodigyplace and bisco like this.
    51,935
    i might not have that long.
    Raytheeagle, m.wynn and Mendel Leisk like this.
  3. hill
    8,805
    Yeah, you & i will still be here. We just won't realize we're still here.
    edthefox5, SpaceCityHybrids and bisco like this.
    51,935
    not sure i realize it now. especially aft the second glass.
    edthefox5 and hill like this.
  5. hill
    8,805
    2 glasses? That's a lot ....1 is my limit
  6. Mendel Leisk
    41,457
    Yeah, gotta stop buying the razor packs at costco.
  7. RobH
    RobH Senior Member
    2,385
    991
    70
    Ah, decision under uncertainty. It will be 10 years before we are certain that this battery will last for that long. I made an educated guess that it was worth the risk. Actually, I made an educated guess that I could install it without killing myself.
    It will be worth it to me if the $1600 unit lasts 4 or 5 years. I'll probably upgrade to a newer car before that, so it doesn't make much difference whether it lasts 5 years or 10.
    kenoarto, bisco, Prodigyplace and 2 others like this.
  8. Fred_H
    Fred_H Misoversimplifier
    558
    482
    28
    Germany
    Hi SpaceCityHybrids. Welcome to PriusChat!
    I am looking forward to hearing about your experience with a Toaster kit when you get one.
    _________________
    about one more week
    Like you, Toyota also didn't wait ten years before deciding to use the Panasonic batteries.
    ___________________
    Accelerated ageing tests can approximately predict battery life.
    Also, a major reason for the relatively long life of Prius batteries is not only the batteries themselves, but also the battery management system. The Prius' conservative battery management ensures that although you need a good quality battery cell designed for extra long life, a super magical battery is not necessary for long battery life.
    dolj and bisco like this.
  9. Kenrico
    Kenrico Member
    82
    52
    Call em Ceylon Cells as they come from a frakking Toaster :)
    Kenny
  10. ericbecky
    ericbecky Hybrid Battery Hero
    4,440
    3,308
    Madison, Wisconsin
    1,500 miles.
    No issues.
    I had taken it out but after some prodding from some members I put it back in for now.
    Two pics from today.
    The second pics had a bit of lag on the Max/Min voltages but you get the idea.
    gta_, m.wynn, 2k1Toaster and 4 others like this.
  11. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Gotta love peer pressure:)!
    But great data and performance (y).
    gta_ and m.wynn like this.
  12. JC91006
    16,768
    8,565
    I haven't read all the posts but I did have a question on liability.
    Let's say there's a bad module and the battery pack catches fire somehow. Who would be responsible? The shop that sells this? Manufacturer? Importer?
  13. ericbecky
    4,440
    3,308
    Madison, Wisconsin
    No matter who might be at fault, I'm sure everyone up and down the line would get roped into that kind of lawsuit.
    That's why you have to carry liability insurance as well as keep things inside a business entity to protect your personal assets.
  14. RobH
    RobH Senior Member
    2,385
    991
    70
    Hopefully the temperature sensors would shut everything down before it reaches that stage. Assuming they're actually connected...
  15. JC91006
    16,768
    8,565
    You read about laptop fires and phone fires originating from batteries. Surely that can come up in car batteries that are faulty
    Where does the temperature sensors get attached on these modules?
    #155 JC91006, Nov 16, 2017
  16. Mendel Leisk
    41,457
    I seem to recall mention of clips, back a few pages.
    JC91006 likes this.
  17. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Yes the temperature sensors would limit power if that happens. You can see it with the original packs. Even a new Prius around here, the fan kicks on when doing mountain passes and after a full day of mountain-ing, the pack is hot enough that your power drops.
    Prii have caught on fire before, as have ICE only vehicles, sometimes it just happens. But what you're talking about, laptops and phones, are Lithium-Ion batteries. They are prone to thermal runaway. Meaning there comes a point it gets so hot, that it actually makes it hotter. Like a snowball effect, except with fire and not snow. Fireball effect? NiMH is more protected from thermal runaway than lithium by chemistry design. It can happen though. But if the battery gets up to that temp, there has been a failure in the hybrid ECU not shutting the pack off.
    There are little rings that the probes attach to that then clip onto the cells.
    Exactly. What tends to happen is you throw a huge wide net trying to catch as many defendants as possible. Hopefully you catch one with deep pockets if that is what you are after. Generally though the manufacturer holds the blame. When your blender goes up in smoke, you don't sue WalMart because they sold it to you, or Visa because they financed it on a credit card. You sue the blender manufacturer. They might then in turn sue their motor distributor if that was the cause of the problem.
    JC91006 likes this.
  18. RobH
    RobH Senior Member
    2,385
    991
    70
    Lithium batteries really are a fire hazard. The nickel-metal hydride ones used in this kit are much less of a hazard. Abused, they will explode, but even then it's just a meltdown, not a fire.
    There are three temperature sensors attached to the middle bottom of the modules in the center and both ends. See my post #80 - the sensors are attached to the separate blue clips next to the blue stack that hold the 3 tubes vertically.
  19. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    So when are we going to have a kit for the Gen1 Prii? I've priced out rebuilding with Gen2 or Gen 3 modules, but new modules would be the best. Inquiring minds need to know!
    Prodigyplace likes this.
  20. Prodigyplace
    12,562
    11,778
    Central Virginia
    Another option would be a wrecked Gen 4 Trim Two. A couple of people have put those modules in Gen 2.
