Prius been sitting - won't start
Discussion in 'Gen 2 Prius Main Forum' started by Steelerfan2018, Mar 15, 2019.
  1. Steelerfan2018
    103
    42
    Pittsburgh
    Hi all,
    My 2008 prius has been sitting for a few weeks and now when I go to start it, I get blinking lights. The car was running perfectly before I parked it. When I bought it last year, it had a new 12v battery.
    I found a video on youtube showing how to do the jump/charge under the hood.
    I have a battery charger from Harbor Freight 4-in-1 Jump Starter with Air Compressor that I tried to use, but it didn't really work. Most likely the charger itself needed charging...
    Anyway, when the weather clears up I will hook up a trickle charge to it - any recommendations on how best to do this? What volt setting? How long?
    Also - any chance this will mess up the big battery? Making me paranoid...
    Thanks,
    Rob
  2. N3K X8
    N3K X8 New Member
    Maine
    Its the 12v battery. Don't worry its nothing huge. Just charge the battery overnight and you should be set in the morning.
    kenoarto likes this.
  3. Steelerfan2018
    103
    42
    Pittsburgh
    thanks for the quick response. Can I charge it from the connections under the hood? Or do I have to go directly to the battery in the trunk?
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Yes. Also, it's an AGM battery so use a charger designed to work with that type of battery. I think that some auto-detect and but with mine I have to select it myself.
    And be very sure you have the polarity right. Reversing it can be expensive on a Prius.
    But otherwise, it just like jumping or charging any other car's 12V. :D
    Skibob likes this.
  5. Steelerfan2018
    103
    42
    Pittsburgh
  6. jerrymildred
    11,517
    14,171
    Tampa, FL
    I would not use that charger. But this one would work and it costs a little less.
    EverStart 25A Smart Battery Charger - Walmart.com
    The jump start should be fine. It's not charging, just giving a quick boost. You could use the battery from a UPS to jump a Prius. It take very little power.
    Skibob likes this.
  7. Steelerfan2018
    103
    42
    Pittsburgh
    Thanks again. I will check out that charger.
    jerrymildred likes this.
  8. dolj
    dolj Senior Member
    8,652
    4,404
    Wellington, New Zealand
    I would not use a 25 A charger on an OEM 12 V battery. Find one that is a multi-stage model that does 3 - 4.3 A (max) and has an AGM setting.
  9. Leadfoot J. McCoalroller
    8,292
    7,808
    Pennsylvania
    2018 Prius c
    For a one-off boost charge that cen-tech charger would do just fine on the 2A setting.
    For regular charging there are better options.
    Skibob likes this.
  10. jerrymildred
    11,517
    14,171
    Tampa, FL
    It does have a 10A setting. But you're right that lower is preferred. In the 2007 OM, in the specifications area, it says that the max rate of charge is 3.5 amps. But it isn't clear if that's the max that the inverter puts into the battery or the max that the battery can absorb. I'm inclined to think, given the 120V inverters in use by many people, that the 3.5A is the max the battery should receive.
  11. jerrymildred
    11,517
    14,171
    Tampa, FL
    I stand corrected. Even that charger is too high powered as pointed out by @dolj. I didn't notice that it won't go below 10 amps. Too much current for your car's battery.
  12. Steelerfan2018
    103
    42
    Pittsburgh
    update - I was checking the ad for harbor freight and they had a charger with AGM on sale for $30. Picked it up yesterday.
    From what I can tell, I should have it set to AGM and 2a (trickle) - which I will do today.
    Thanks everyone for the help.
    Rob
    Skibob, Raytheeagle and jerrymildred like this.
  13. frodoz737
    frodoz737 Top Wrench
    4,809
    2,562
    33
    You can just jump start from "another vehicle" using positive on jump point under hood and a good ground for the negative. Doesn't need much to boot the boxes.
  14. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    It has a manual 2amp setting so it will work just fine. As long as the user remembers to set it at 2 amps that is.
