Prius Bladder System-Tip to Restore Tank Capacity
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by hb06, Oct 24, 2006.
  1. cuong.v.nguyen
    cuong.v.nguyen New Member
    Connecticut
    Here is my opinion on this issue. The nozzle fit very snuggly with the Prius Gas tank opening, thus as you fill quickly the pressure build up fast. Result the gas nozzle will shut off. Thus pull the gas nozzle out and re-inserting it and pump slowly will allow you to continue to pump. As far as the bladder shrinkage, it should not shrink as much. Remember the blader is inside a tank tight as it attempt to shrink vaccuum will keep it from not able to collapse. So if there is any shrinkage it should be a very small amount. As far as attempting to rig up a hose that would defeat the safety feature of your car. And can cause a hazardous to you if you are in an accident. So I would just pull out the nozzle and let it rest for a few seconds then refill.
  2. SparkyFirefly
    SparkyFirefly Junior Member
    Chicago, Illinois
    1. My 07 Touring Prius will only take 6.5 gallons when the last bar is flashing and fuel light on. It'll take 6.7 gallons if I top off with 6 more 3 second clicks. Other Priuses I've driven take 8-9 gallons with a flashing bar. Can this be explained? How can I fix this? I tried stretching the bladder in warm weather with topping it off twice, but didn't want to do it more than that because of the overfill risks.
    2. How can we tell if the charcoal overfill is saturated? Can it be replaced?
    52,863
    open the cap and let it vent for a minute.
    pump as slowly as possible.
    try different pumps and stations.
    hold the nozzle at 90 and 180 degrees.
  4. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    How many miles are you driving on that amount? I wonder how different gen 2 and gen 3 tanks are? The cars themselves are not that different. Would a gen 3 tank bolt up in a gen 2?
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Take a look at post 33 in this thread. The second attachment discusses this exact situation and how to fix it.......................
