Prius Brake pump running every 55 seconds ( Brazil)
Discussion in 'Gen 3 Prius Main Forum' started by heltonsc, Feb 14, 2021.
  1. heltonsc
    heltonsc Junior Member
    42
    23
    brazil
    Hi! I'm from Brazil and I have a 2013 Prius (only 88.000 miles ) A few days ago I noticed that the brake accumulator is running every 55 seconds. Reading the priuschat I came to the conclusion that the ABS actuator is having some problem. My doubt would be to know if I should bleed the brake and change the fluid before changing the actuator?
    Here we have a small supply of used Gen 3 parts, only 750 cars have been imported to Brazil.
    And the new ABS actuator costs 30% of the car's value,
    I may have to import the part from the USA, but I'm not sure if they are the same. The Brazilian prius is the same sold in Spain
    Video in portuguese, sorry...
    marcoshenz likes this.
  2. PriusCamper
    PriusCamper Senior Member
    13,299
    5,375
    Pacific Northwest, USA
    Not certain if Spain and US vehicles are the same...
    But keep a close eye on how long actuator goes before starting up to refill again... Once it gets down to every few seconds is when you aren't going to be able to safely drive it and that could take a while.
    heltonsc likes this.
  3. heltonsc
    42
    23
    brazil
    Currently running every 50 seconds, how long will it take until the warning lights? 1 year? or less ?
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    my son's 2005 pump ran every 9 seconds (ran 3 seconds then off for 6 seconds) for months before it finally started giving low pressure codes a couple weeks ago. Now it throws a code every now and then, but it's basically sitting while waiting to have the pump replaced.
    #4 TMR-JWAP, Feb 14, 2021
    PriusCamper and heltonsc like this.
  5. heltonsc
    42
    23
    brazil
    The bomb is currently running every 35 seconds, but today. I found a solution, I don't know if temporary or permanent,
    I changed the brake fluid from dot 3 to dot 4 and miraculously the pump doesn't run alone anymore,
    Soluction by @TMR-JWAP In another forum post C1256/1391--anyone ever try using DOT4 brake fluid? | PriusChat
    1- I disconnected the 12v battery
    2- I pressed the brake several times to empty the accumulator.
    3- I drained all the fluid from the tank
    4- I added 1 bottle of dot 4 fluid
    5- I connected the 12v battery
    And at the same time the car was perfect! the brake pump no longer runs alone! it's like a new car!
    greetings from Brazil to all friends of priuschat
  6. Solman636
    Solman636 Member
    99
    37
    Florida Panhandle
    Very interesting experiment and successful too! If I understand correctly this would be like using a "high mileage" oil in a leaky old engine? What is the result now a year later?
  7. Solman636
    Solman636 Member
    99
    37
    Florida Panhandle
    Since the difference in the 3 and 4 is related to water absorbency mostly then your change of fluid brings up a question. Was the good result from the change due to the brake fluid from dot 3 to dot 4? Or was it more a matter of flushing the old fluid out which perpaps contained contaminants, water, grit etc that could have affected the seals in the ABS actuator etc??
    PriusCamper likes this.
  8. PriusCamper
    13,299
    5,375
    Maybe a little bit of both? Of course for how long? Many a great idea that doesn't last long on PriusChat doesn't get a follow up because most people are less excited to talk about being clever and then failing than they are about being clever and not failing.
    #8 PriusCamper, Jul 3, 2022
    Mr. F likes this.
  9. rjparker
    rjparker Tu Humilde Sirviente
    10,792
    6,773
    Texas Hill Country
    It will last a day or two.
  10. nicoj36
    nicoj36 Active Member
    518
    162
    Do this and let us know if it stops your excessive actuator
  11. JSB_99
    JSB_99 Member
    66
    48
    Houston
    Mine was running every 15 seconds so I did the same thing a few months ago. It immediately started making the same barking noise when applying the brakes my 2008 was when I got rid of it. Thoroughly flushed the brakes and it still did and eventually got worse so I had the pump and booster replaced since it was also leaking internally.
  12. Mr. F
    Mr. F Active Member
    389
    263
    Washington
    It won't.
  13. rjparker
    10,792
    6,773
    Texas Hill Country
    A complete $150 flush will fix it for a day or two
  14. qdllc
    qdllc Senior Member
    1,377
    400
    If you aren’t losing brake fluid, it’s a mechanical issue and not a leak.
    When was the last time the system was flushed (drain master cylinder reservoir then fill with fresh fluid and replace fluid to each wheel)? That should be done every few years, and contamination working its way into the lines can compromise line pressure.
    You can do a flush and see if that solves the problem because it’s cheap and easy. If you will break open the system to replace brake system parts, you don’t bother bleeding/flushing the system first.
  15. nicoj36
    518
    162
    It has for me. Mine used to come on all the time and after performing the reset. It came on less.
  16. Mr. F
    Mr. F Active Member
    389
    263
    Washington
    Many factors can cause the apparent frequency of operation to decrease. Mine went from 3 s to 12 s (temporarily) without my doing anything at all except driving in warmer weather.
    The one thing anybody can rule out as having an effect is the steps of the video, because it only reads stored DTCs.
  17. nicoj36
    518
    162
    Mine used to come on every 5th brake. After performing the reset, it only came on every 9th brake.
  18. ChapmanF
    18,836
    There's nothing in the ECU down there counting uses of the brake. It's just going to run the pump whenever enough fluid has left the accumulator that it needs pumping up again.
    Some fluid does leave the accumulator every time you brake, but it's not a fixed amount. It depends on how hard you brake, and how far the caliper pistons return when you're done, and the rotor runout and whether the car is moving (if it is, runout increases the piston return), and so on. If there are any unbled bubbles in the system, they also increase the amount of fluid used each time you brake.
    Which all goes to say that if you pay close attention over a longer period, you're likely to see "number of brake uses between pump runs" to be pretty variable, enough to be careful what you read into it. About the most we usually say is if the pump's running every few-to-several times you use the brake, that's about right.
    But there's a separate issue about how often the pump runs if you're not using the brake. The pressure should hold up for hours then. If the pump is cycling, as in the title of this thread, every 55 seconds with nobody touching the brake, then nobody needs to do any counting of brake uses to spot the problem.
    Solman636 and Bill Norton like this.
  19. Solman636
    Solman636 Member
    99
    37
    Florida Panhandle
    Mr. Chapman. If my actuator runs every 10 seconds most of the time would I be wise to just bite the bullet and install a new OEM actuator? Or just wait? Don't want to get stranded on a road trip someday 165,000 miles. Actuator seems to be run even more lately, but not sure how consistent it has been in this pattern.
  20. ChapmanF
    18,836
    The period between runs of the pump will be hours for a good actuator in good condition, when the brakes are not being used.
    So the large number of PriusChat threads where people intently discuss the prognosis for a system that's pumping every 55 seconds or 20 seconds or 12 seconds or 3 seconds amount to a lot of words being spent trying to pin down the exact difference between really bad and plain awful, and it's kind of understandable to want to put off replacing an expensive part. But honestly, seeing any of those shortened periods tells you it's done for, and it's just a matter of scheduling when it'll be convenient to do the work. Maybe at 55 seconds you can treat the scheduling as a little less urgent than you can at 10 seconds, but that's what it all boils down to.
    Fix My Prius, CR94 and Solman636 like this.
