Prius briefly starting ICE while braking
Discussion in 'Gen 3 Prius Main Forum' started by Dead12VBattery, Jan 23, 2018.
  1. Dead12VBattery
    Dead12VBattery Junior Member
    Amsterdam
    I've noticed that my 2010 Prius sometimes starts up the ICE briefly while braking. It seems to happen almost 100% on the time when passing about 70 kph (43 mph) when exiting the highway on my commute home, which means under the following circumstances:
    • About 30 min of driving 120-140 kph (75-87 mph).
    • Approach exit driving about 120 kph (75 mph).
    • Release throttle to slow down to approximately 100 kph (62 mph).
    • Gently brake to 50 kph (31 mph), with constant pressure on the brake pedal and not touching the throttle.
    • While braking, the ICE starts up at about 70 kph (43 mph) and immediately shuts down again. It can feel this, hear it, and see the fuel usage indicator go up for a brief moment. The car continues to decelerate normally though.
    Is this normal? It seems fairly pointless (though probably harmless). The car is in normal mode (that is, not eco, pwr or EV).
    SFO likes this.
    52,803
    what level is the battery at when it happens?
  3. Dead12VBattery
    Amsterdam
    Usually as full as it gets from normal driving (I think it is 7 bars or so? it's one bar missing)
    52,803
    it could be burning off some excess charge, but i would think it would be full bars.
  5. Dead12VBattery
    Amsterdam
    That's an interesting thought, but then I wouldn't expect it to always happen at the exact same speed. It's also noteworthy that this is the same speed that seems to be the maximum for driving purely electric.
  6. bisco
    52,803
    when i had a regular commute in my 2008, at the end of the highway run, fully warmed engine in summer, the last mile on a back road at 20 mph or so would always see the engine come on every time. but the battery was full from the highway.
    not sure if it relates to your situation at all though.
  7. Mendel Leisk
    42,293
    That's the max speed 3rd gen Prius will run without the engine kicking in. Happens to us everytime we coast down a steep hill.
    That's correct.
    m.wynn and Maarten28 like this.
  8. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    The ICE will always spin when you're faster than 70 km/h, the Prius injects some fuel (making it look like the ICE is starting up) while braking through that speed to let the transition from spinning ICE to ICE off go smoothly.
    This is perfectly normal.
    4est likes this.
  9. jack black
    jack black Active Member
    225
    142
    I
    isn't EV speed limit 46mph?
    for the record, I don't have that issue OP describes at 43mph.
  10. Mendel Leisk
    42,293
    Yeah. The one place I notice this is rolling down this hill.
    Pretty much foot off the gas (maybe a slight touch to defeat regen) the car will accelerate, and at the bottom of the hill the limits goes from 60 (kmh) to 80. Somewhere around 73~74 kmh, the engine kicks in. Always.
    Rough conversion from kmh to mph:
    74 x 5/8 = 46
    #10 Mendel Leisk, Jan 24, 2018
  11. Maarten28
    415
    224
    Netherlands
    What the exact speed is is not really interesting. Especially while braking you can not say it will happen at exactly that speed, and european speedometers also have about 8% offset in speed.
    It may also not be so noticable on MPH speedometers because of how the consumption gauge works. On european cars it is usually in liter / 100 km and will indicate nothing when the foot is off the gas and it will blip a few bars when the ICE is turned off.
    On US cars the gauge will stay full bars when the foot is off the gas (99 mpg) and will probably not dip a single bar because the mileage will not drop below 99 mpg.
    zybrkat likes this.
  12. douglasjre
    douglasjre Senior Member
    2,247
    751
    Null, NL
    Your battery pack is dying
  13. 4md
    4md Member
    97
    55
    Sofia, BG
    Mine does the exact same thing, but I'm not sure about the speed, I thought it was at different speed every time, I'll start to observe it.
    I'm pretty sure that's not connected with the battery condition, because mine was dying and I've replaced it and it continued to start the ICE for 1-2 seconds.
  14. Maarten28
    415
    224
    Netherlands
    No. This is absolutely no indication that the battery pack is dying.
  15. b100
    b100 Member
    145
    75
    Netherlands
    He's joking maarten:p
  16. Mendel Leisk
    42,293
    The Dutch uncles comparing notes. ;)
