Prius burning oil
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Eaglenyne, Oct 31, 2019.
  1. Eaglenyne
    Eaglenyne New Member
    My 2008 Prius has started burning oil. Almost a quart every 10 days
    Dealer says will cost approx 4K to 6k to open the engine and put it back together!
    (I'm not sure if that will solve the issue)
    Anyone else ever faced this problem ? Any cheaper solution ? It's a perfectly maintained car - could it Toyota Corps problem? Any insight will be appreciated
  2. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    o_O
  3. ETC(SS)
    7,515
    1. This isn’t Toyota’s problem, and despite my lifelong dream of being featured on Grit’s Signature Hit parade I’ll let somebody else explain to you why an 11 year old car that burns a quart of oil every 10 days hasn’t been “perfectly maintained.”
    2. Others have faced this problem.
    3. ANY solution that doesn’t involve a dealer will be cheaper. MY recommendation would be to find an independent mechanic that will be able to verify that you’re burning enough oil to warrant an engine replacement - which should be closer to a $2,000 fix more or less.
    4. If you ARE burning 3 quarts of oil a month then you’d better get the mechanic to replace your catalytic converter too. On free soil this would normally be a $200 repair but One of the many MANY....ah...”interesting” things about living in the California is that catalytic converters are somewhat more expensive to repair.
    Good Luck!
    davecook89t and Merkey like this.
  4. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    How many miles are on your car?
    How many miles do you drive in ten days?
  5. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    How many kilometres has it done? And how many do you do in 10 days?
  6. Patrick Wong
    18,210
    6,517
    Have a used engine installed.
    The definition of “perfect“ seems to have flexibility to it.
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    After reading the posts in this thread, down at the bottom the system shows a list of "similar" threads.
    You should read through them before deciding what to do next.
    Gummed up rings seems to be a common problem ........with some fairly simple "chemical" fixes.
    While I don't generally like chemical fixes for most anything, in this case it can't really hurt anything since the engine is pretty useless in it's present condition.
    For instance.......somewhere near that range of the price you were quoted, you could get a NEW engine installed.....or almost new.
    You also could get a used car in good condition.
  8. bisco
    52,803
    welcome!
    how many miles on her?
    where are you in the great state?
    how many miles do you traverse in 10 days?
    try to find a non dealer mech who will install a low mile salvage engine.
    some have had luck for a couple grand all in.
    alanclarkeau likes this.
  9. Eaglenyne
    Ok will try to get a 2nd opinion from an independent . I had read that Toyota had similar engine problems with other models where the oil leaks into the combustion chamber - if I understand it correctly - and hence I wanted to see if I can get any valuable feedback from thi community.
    I appreciate your suggestions .
  10. Eaglenyne
    I have 120000 miles on it
    I drive approx 30 miles a day
    This is the first time I have had this problem - started with low engine oil pressure sign as per my wife who drives it more regularly
    Ok will look I to
    #10 Eaglenyne, Nov 1, 2019
  11. Patrick Wong
    18,210
    6,517
    So your engine uses one quart per 300 miles of driving? (30 miles/day * 10 days)
    That is quite bad.
    The low engine oil pressure warning means that the oil level dropped so low that oil pressure was not maintained. That will cause accelerated engine wear and allowed the engine to get to the point where it is burning oil at such a fast pace. At this point if you want to keep the car, the least cost solution would be for an independent to install a used engine. That might cost you $3K depending upon local labor rates.
    Merkey likes this.
  12. alanclarkeau
    7,045
    7,593
    Have a good mechanic check it over.
    Leaks? PCV? Compression test? It could be something simple - or terminal. Check the Oil Pressure sender (I've no idea where it is, but I had one which cracked on a car decades ago and leaked quite considerably).
    If it's happened suddenly - has the oil grade (or even brand) changed?
    Being almost 12 years old and 120,000 miles (almost 200,000 km) - TOYOTA won't come to your rescue.
    But - as engines age, they will use more oil, though a quart every 300 miles sounds excessive.
  13. alanclarkeau
    7,045
    7,593
    Not sure - if there is an internal fault in the engine, the oil pressure gauge can read low even when there is plenty of oil. It doesn't read the oil level, just whether oil pressure is maintained.
    BUT YES - if the oil LEVEL is low, the oil pressure will be too.
  14. mikey_t
    371
    391
    Los Angeles
    You could have a mechanic check it out just to be safe. Although I've seen around here some members ended up driving on low or nearly no oil and their engines ended up just being fine after catching it soon enough, so don't worry too much yet. Top off the oil and see what a mechanic says.
    Raytheeagle likes this.
  15. EternalPrius
    EternalPrius Junior Member
    Pasadena, CA
    Three Touring
    First make sure the oil isn't leaking out. If it isn't, you should try doing several cheap oil changes over the next thousand miles or so using Seafoam. Change the PCV valve as well (easy)
    Put a half can of seafoam into the crankcase with the oil and drive it for 50-100 miles. then change the oil. then do it again in a few hundred miles. do this 2-3 times. it should help clean up the piston rings.
    or use the Toyota engine additives instead of seafoam, 2-3 times. someone has a link on this site or just use google. it's made for cases like this.
    Many will say not to do this, but in my opinion there is only benefit for your engine at this point. my 2nd gen has 208k miles. according to dealer records they have done the Toyota brand engine flush at the dealer at least 2-3 times for the previous owner. My Prius burns almost ZERO oil at 208k miles, and the (synthetic) oil looks very clean after 4000 miles.
    Going forward, use synthetic oil and make sure to change every 4-5000 miles max. There is certainly a good amount of blowby at this point, which is diluting the oil and making it a poor lubricant. With your kind of problem I wouldn't go longer than 3000 miles on an oil change until it's resolved or the car dies.
    #15 EternalPrius, Nov 2, 2019
  16. mikey_t
    371
    391
    Los Angeles
    I'd recommend using BG EPR rather than multiple seafoam-oil changes to flush the engine. Pour one can into the crank case, put the car into maintenance mode and run the engine idle for 20mins, then change the oil. That'll clean things up real nice. Add BG MOA into the clean oil afterwards for better lubrication and your engine should be good. I've done this recently and so far my consumpton has been drastically reduced. Though it all depends on why your engine was consuming so much in the first place. If it was clogged up piston rings, the BG products should help. Your mechanic should clarify the issue for you first.
    Raytheeagle and EternalPrius like this.
  17. EternalPrius
    Pasadena, CA
    Three Touring
    this is also good advice. It's likely you will need a new engine because the rings have deteriorated to the point that so much oil is being flushed into the combustion chamber. but if that's the case there is no reason not to go all out and try to save it with some detergents.
    you can get really crazy and seafoam through the vacuum line, idle it in maintenance mode with the engine going until all the white smoke is cleared from the tailpipe. there will be a LOT if its as bad as it sounds. it will blow by the rings where the gunk is. Then you MUST do an oil change.
    Your engine may and should stall if you feed the engine cleaning solution through the vacuum line fast enough. when I've done this on normal combustion engines it's actually normal and you're supposed to do it until the engine stalls, but I have never done it on a Prius. Hopefully someone else can chime in.
    #17 EternalPrius, Nov 2, 2019
  18. alanclarkeau
    7,045
    7,593
    As I suggested in Post #12 above - get it assessed by a good mechanic, particularly a compression test, and for leaks.
  19. sam spade 2
    7,035
    2,804
    2017 Prius c
    Oh come on Alan.......doing it right is no fun.
    Taking wild guesses and dumping snake oil into every opening in the engine is much more adventuresome.
    :eek:
  20. Classic Car Guy
    Classic Car Guy Active Member
    501
    135
    Northwest, USA
    Okay man who pulled out the plug there for a moment. :cry:
    #20 Classic Car Guy, Nov 3, 2019
