Prius Burnout
Discussion in 'Gen 2 Prius Main Forum' started by morpheusx, May 31, 2007.
  1. BT Tech
    BT Tech New Member
    885
    South Florida
    Oops... Sorry that I missed your post/link... Yup.. that was the dyno run for the might Pri!! :) Here is the dyno printout.
    Thanks for the link!!
    <div class='quotetop'>QUOTE(theforce @ Jun 2 2007, 08:36 PM) [snapback]454121[/snapback]</div>
  2. richard schumacher
    7,683
    1,066
    United States
    <div class='quotetop'>QUOTE(glenk @ Jun 1 2007, 03:20 PM) [snapback]453489[/snapback]</div>
    Yes, unless the parking pawl is broken (the car puts itself into Park when you turn it off). Or maybe the big dummy left it in D and applied the parking brake?
  3. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    <div class='quotetop'>QUOTE(theforce @ Jun 2 2007, 05:36 PM) [snapback]454121[/snapback]</div>
    I didn't. I saw the graph and said it looked like the overall "curve" looked great despite what would seem likely. :)
  4. Tideland Prius
    16,680
    Here's the original copy of the dyno runs (5 runs). You can see the power drop as the battery drains.
    [attachmentid=8478]
  5. BT Tech
    BT Tech New Member
    885
    South Florida
    Great find Tideland. I have lost that dyno sheet long ago so I am glad that you were able to pull it up and post it!!!
    I remember what a PITA it was to get the Pri to just spin the rollers without throwing every error code on the dash to light up like a Christmas tree!! :)
    <div class='quotetop'>QUOTE(Tideland Prius @ Jun 3 2007, 02:01 PM) [snapback]454459[/snapback]</div>
  6. kjprius
    kjprius Junior Member
    Hello,
    Can you PLEASE share we me how you ever GOT the prius to ignore the ABS and stop freaking out and "CHUNKING" along?!?!?!? I tried to do this and just got stuck on the dyno. Is there a fuse (or fuses) that you have to lift? How did you do it????
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    You do know that this thread is almost two years old. You might be better off starting a new thread with your question.
    Tom
  8. bisco
    52,848
    and yet, no new thread.
  9. defrankond
    defrankond Member
    217
    23
    North Dakota
    the gen II has about 110hp however I am certain that is taking the electric motor into account as well. the Gen III is about 134hp.
