1. The site is migrating to a new server this week, so there will likely be some downtime during that process. You can follow along here for updates.
Prius C 2012 front bumper interchangeable with facelift version?
Discussion in 'Prius c Accessories and Modifications' started by Bhu, Aug 16, 2016.
  1. Bhu
    Bhu New Member
    Mauritius
    Hi
    Is the front bumper for the 2012 prius c / aqua interchangeable with the facelift 2015 version?
    I know I'd need to get new grills and turn lights. I just want to be sure it fits smoothly. This is my first mod.
    Thanks
    Bhu
  2. TC400
    TC400 Active Member
    751
    168
    Pittsburgh, PA
    No you would need all new headlights too.
  3. djdawn
    djdawn Active Member
    255
    116
    Escondido, CA
    2014 Prius c
    Out of curiosity, are the headlights shaped differently? Or is it different mounting point issue? I'm wondering if led headlamps for the '15+ could be obtainable for cheap via junkyard/fleabay.
    With the front bumper, that would be cool if you could swap them out. It opens up the option for '15+ folks to get the '12/'14 front and the kits that are made for it. Not that I've tried hard, but I haven't seen any lip kits for the '15+ types.
  4. Bhu
    Bhu New Member
    Mauritius
    Thanks. I'm up for it as long as no drilling/reshaping is needed :)
    TC400 likes this.
  5. Squeakasaur
    Squeakasaur Member
    106
    35
    22
    Seattle
    2016 Prius c
    I don't think it would be as simple as plug and play though. The 15-16 headlights only have the one projector light which is used for both DRL and Headlights. Since the old ones have separate DRLs there might also be an issue with shape/size. Also the headlights are freaking expensive.
Loading...
