Prius C 2015 - very little to know usage/maintenance inquiry
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by TimoSpenter56, Sep 5, 2024.
  1. TimoSpenter56
    TimoSpenter56 Junior Member
    Chicago, IL
    2015 Prius c
    Hello. I just moved to a city where I can get around everywhere with public transportation, and my car battery keeps dying because I don't drive it enough. The battery is about 3 years old, and I am at a point where I need to jump start it every 4 days just to drive around the block for maintenance sake.
    I still want to keep the car just in case, and looking for advice on proper way to maintain it.
    1) I've looked into trickle charging, but I live in a condo where AC plug (power source) is not available. Is there any possible alternative solution?
    2) If I decide not to drive the car at all (say a year or two), would I still be able to jump start it when I need to? Is it possible for a battery die to a point where jump starting won't work? And should I be aware of any other complication if I let my car sit for a year or two without driving?
    Thank you in advance for your help and insight!
  2. Leadfoot J. McCoalroller
    8,293
    7,808
    Pennsylvania
    2018 Prius c
    Well, the hybrid batteries tend to go bad with age whether you use them or not, and they typically cost a few thousand bucks to replace. Letting the car sit could be seen an an expensive choice vs. selling it off and buying again when it is time to drive more.
    So there is that drawback to letting the car sit.
    Now as far as the 12v battery goes, the one that just boots the car up into READY mode? those are obviously a lot cheaper, but they need frequent usage or supplementary charging in order to work. They can die to the point where a jump won't work but is rare outside of subzero temps, and the particulars of what you're using to do the jump. Some jump-start packs have a reverse polarity protection feature (which is nice) but if the target battery is absolutely dead it'll fake out the jump pack and you don't get a start. Others have an override system- if you know how to use it.
    Does your parking arrangement include any sunlight? You could install a solar battery tender, just to keep that 12v unit topped up from one trip to the next. You'd just have the panel on your dashboard or suction-cupped onto a window.
    After that it's the less convenient stuff, like removing the 12v battery from the car and putting it on a maintenance charger in your living space.
    TimoSpenter56 likes this.
  3. TimoSpenter56
    Chicago, IL
    2015 Prius c
    Thank you for your advice, this is great!
    I have a indoor garage so I don't get any sunlight. I guess that leaves the option to remove the 12v battery from car and putting it on a maintenance charger in living space. If I do that, and let the car sit for a year or two, will that do damage to the hybrid battery? Is the hybrid battery similar to the 12v battery, where if you don't use it, it goes bad faster?
  4. Leadfoot J. McCoalroller
    8,293
    7,808
    Pennsylvania
    2018 Prius c
    It's not that it runs down faster; it's mostly that it has different consequences. If the hybrid battery is allowed to rest long enough to fully discharge, there is no easy recovery path. Toyota will tow it in and charge you a few thousand bucks to replace it. Experienced hybrid mechanics (and DIYers) have a few cheaper tricks to get out of that jam, but it's still not a good situation.
    The real answer is to put the 12v battery back in there and use the car for a few hours every 3-4 months.
    Even with regular usage, the hybrid battery in the c seems to last "around 10 years." So it's possible you might be carefully storing this thing until the moment when it needs an expensive replacement anyway.
    Don't forget to use gasoline stabilizer as well.
    A hybrid is a little bit like getting an ice cream cone while walking through a park on a hot day: you don't have to eat the ice cream, but there's no such thing as saving it for later.
  5. TimoSpenter56
    Chicago, IL
    2015 Prius c
    Ok. I think I can manage to put the 12v battery back in the car once a quarter and drive it around for few hours, and in put it in maintenance charger in living room when not in use.
    You mentioned the hybrid battery lasts "around 10 years." I've also read it lasts atleast 100k miles, and I only have 50k miles on the car. Do you think it's more number of years or mileage usage?
    Thanks for the advice!
  6. Leadfoot J. McCoalroller
    8,293
    7,808
    Pennsylvania
    2018 Prius c
    Just from my own observations, hybrid battery lifetime is much more related to age than use.
    pasta4breakfast likes this.
  7. pasta4breakfast
    131
    67
    Anaheim, CA
    2020 Prius Prime
    I agree that age seems to be more important than miles. I think most of the prius batteries will last 11-15 years, regardless of miles, even over 200k miles. My 2013 prius C battery is still going strong with 156,000 miles on it. I heard that low mileage hybrid batteries unused for long stretches of time actually fail sooner. In fact, this hybrid battery shop says that if you don't drive your car for more than 45 days, it will void the warranty for their remanufactured batteries.
    Warranty Ace Hybrid Tech
    Our Warranties will become null and void if any of the following occurs...If you let your car sit for more than 45 days without driving it
    To me it sounds like a waste of the hybrid technology to have a prius C and not drive it. Personally, I would sell it and if I absolutely needed a car for infrequent use, buy a used subcompact gas vehicle with decent mpg and reliability (assuming you could get one for well cheaper than your prius C). You can pocket the difference and then rebuy a hybrid if you need to drive regularly again. Though, I guess if you think you are only going to be in this situation for year or two, maybe you don't want to do this. However, don't expect the hybrid battery to last more than 15 years because it only has xyz miles on it.
  8. Mendel Leisk
    42,373
    Not having the ability to hook up a charger leaves you with a quandary when you’re low usage, and driving just to charge the battery is kinda crazy, when you think about it. And short, round the block drives aren’t t going to help much.
    maybe consider a cut-off switch for the 12 volt. It’s like a shock treatment for the car, you lose various memories, but it eliminates the phantom draw.
  9. BiomedO1
    BiomedO1 Senior Member
    4,637
    2,434
    Left Coast
    Don't know it Tim is still reading this thread.
    IMHO; he should trade-in that Prius for a gas only corolla or equivalent. Used car prices are still pretty high so great resale value. I'm sure sooner or later someone will notice a parked Prius that doesn't move too often - ripe target for disappearing CAT. Now that the battery is being pulled, no alarm either.
    Just my paranoia and 2-cents......
