Prius C 4 with 16" rims - want to convert to 15"
Discussion in 'Prius c Main Forum' started by Rainking, May 28, 2013.
  1. mahout
    mahout Active Member
    655
    116
    NC
    You'll hasve to replace the steering rack at the least but thee's no reasonto do so.
  2. Drdiesel
    Drdiesel Active Member
    585
    152
    Monterey CA
    This is a misnomer and it's very self contradicting too :eek:
  3. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    They changed the rack because for some reason they decided to go with a wheel that has a different back spacing. You can go get an aftermarket 16" with the correct backspacing and not have this issue... you'll just have to go with a thinner wheel or it will stick out past the fenders.
  4. mahout
    655
    116
    NC
    As long as you keep the diameter of
    your tires to no more than 23.67" or less, by as much as 1/4 inch, there will be no problem with mpg. And your turning diamete will be same as OEM with 15" tires.
